楼主: 冬瓜HA
填坑:魔百盒CM311-1a、M401a、unt403a刷冬瓜HAOS指南(已停更)
f@me 手机认证
发表于 2024-11-18 14:55:43 | 显示全部楼层
qq779123 发表于 2024-11-18 14:21
这是详细提示,咋回事
[supervisor.docker.interface] Can't install m.fashgh.com/home-assistant/odroid ...
core版本不对,日志贴全一点
发表于 2024-11-18 17:35:47 | 显示全部楼层
f@me 发表于 2024-11-18 14:55
core版本不对,日志贴全一点
大佬麻烦帮看下
hassio-supervisor
INFO: Using udev information from host
INFO: Starting local supervisor watchdog...
[__main__] Initializing Supervisor setup
[supervisor.bootstrap] Setting up coresys for machine: odroid-c4
[supervisor.docker.supervisor] Attaching to Supervisor m.fashgh.com/home-assistant/aarch64-hassio-supervisor with version 2024.11.2
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.wghaos.com/s905l ... 2024.11.2&arch=
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-cli with version 2024.09.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.manager] Cleaning hassio_cli application
[supervisor.docker.cli] Starting CLI m.fashgh.com/home-assistant/aarch64-hassio-cli with version 2024.09.0 - 172.30.32.5
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.manager] Cleaning hassio_dns application
[supervisor.docker.dns] Starting DNS m.fashgh.com/home-assistant/aarch64-hassio-dns with version 2024.04.0 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.manager] Cleaning hassio_audio application
[supervisor.docker.audio] Starting Audio m.fashgh.com/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-observer with version 2023.06.0
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.manager] Cleaning hassio_multicast application
[supervisor.docker.multicast] Starting Multicast m.fashgh.com/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] Attaching to m.fashgh.com/home-assistant/odroid-c4-homeassistant with version landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.docker.manager] Starting homeassistant
[supervisor.os.manager] Detect Home Assistant Operating System 13.2 / BootSlot A
[supervisor.store.git] Loading add-on /data/addons/git/fb59d657 repository
[supervisor.store.git] Loading add-on /data/addons/git/d6faf732 repository
[supervisor.store.git] Loading add-on /data/addons/core repository
[supervisor.store.git] Loading add-on /data/addons/git/b9a594eb repository
[supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image m.fashgh.com/home-assistant/odroid-c4-homeassistant:landingpage to m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11
[supervisor.docker.interface] Downloading docker image m.fashgh.com/home-assistant/odroid-c4-homeassistant with tag 2024.11.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.host.manager] Host information reload completed
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
[supervisor.docker.interface] Can't install m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11: 404 Client Error for http+docker://localhost/v1.47/images/create?tag=2024.11&fromImage=m.fashgh.com%2Fhome-assistant%2Fodroid-c4-homeassistant&platform=linux%2Farm64: Not Found ("manifest for m.fashgh.com/home-assistant/odroid-c4-homeassistant:2024.11 not found: manifest unknown: manifest unknown")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
发表于 2024-11-18 17:38:27 | 显示全部楼层
core版本不对,日志贴全一点
hassio-supervisor
发表于 2024-11-18 17:54:45 | 显示全部楼层
qq779123 发表于 2024-11-18 17:38
hassio-supervisor
s6-rc: info: service s6rc-one ...
你这个core docker 镜像 tag不对啊,应该是2024.11.2 标签不对,先重启,观察一下,如果下载还不对,再多重启几次,别着急,core镜像比较大,下载成功的情况,下载过程也会比较慢
发表于 2024-11-18 18:08:12 | 显示全部楼层
你 ...
感谢回复 , 一下午了 , 一直在报那个30内重试,  一直循环这个。  纯小白,  搞2天了 , 现在卡在这最后一步。。。。。
发表于 2024-11-19 10:05:22 | 显示全部楼层
微信图片_20241119100441.png 微信图片_20241119100447.png 大佬 已经没法ota了吗
发表于 2024-11-19 10:54:28 | 显示全部楼层
wangyi 发表于 2024-11-19 10:05
大佬 已经没法ota了吗
私信冬瓜大佬,远程处理吧~,你这个版本有点老了
 楼主| 发表于 2024-11-19 14:46:56 | 显示全部楼层
大佬 已经没法ota了吗
联系我吧
发表于 2024-11-25 08:39:47 | 显示全部楼层
感谢大佬分享
发表于 2024-12-19 09:46:28 | 显示全部楼层
摩拜大佬
GMT+8, 2026-1-20 06:29 , Processed in 0.537516 second(s), 14 queries , MemCached On.
