楼主: sorrypqa
[新奇玩法] HassOS用起来感觉有点碍手碍脚,今天彻底换Debian+Docker
 楼主| 发表于 2023-10-10 23:13:15 | 显示全部楼层
skiong 发表于 2023-10-10 22:51
怎么解决mdns问题,docker下ha和nodered如何访问局域网内mdns域名解析
都用HOST网络不行吗?
发表于 2023-10-10 23:15:49 | 显示全部楼层
docker下面好像没法用cf的tunnels穿透外网访问,
发表于 2023-10-10 23:25:09 | 显示全部楼层
奇怪,刚试了下又可以了
发表于 2023-10-10 23:43:57 | 显示全部楼层
docker安装的ha没有add-on(加载项)
 楼主| 发表于 2023-10-11 06:50:33 | 显示全部楼层
add-on也是Docker镜像呀,add-on里有的Docker都有,Docker有的add-on不一定有,用Debian+Docker会更加自由,而且不会因为墙的问题add-on经常抽风,
发表于 2023-10-11 07:49:31 | 显示全部楼层
sorrypqa 发表于 2023-10-11 06:50
add-on也是Docker镜像呀,add-on里有的Docker都有,Docker有的add-on不一定有,用Debian+Docker会更加自 ...
能贴一下docker部署命令吗?我的docker版ha里面没有add-on
没有add-on,装不了mqtt,terminal,vscode
 楼主| 发表于 2023-10-11 08:00:27 | 显示全部楼层
没有add-on,装不了mqtt,terminal,vscode ...
我喜欢用docker-compose:
version: '3'
services:
  esphome:
    container_name: esphome
    image: esphome/esphome:2023.9.3
    volumes:
      - /root/esphome/config:/config
      - /etc/localtime:/etc/localtime:ro
    devices:
      - "/dev/ttyUSB0:/dev/ttyUSB0"
    restart: always
    privileged: true
    network_mode: host
  emqx:
    container_name: emqx
    image: emqx/emqx:5.3.0
    restart: unless-stopped
    privileged: true
    volumes:
      - /root/emqx/data:/opt/emqx/data
      - /root/emqx/log:/opt/emqx/log
    network_mode: host
    environment:
      - TZ=Asia/Shanghai
  frigate:
    container_name: frigate
    privileged: true # this may not be necessary for all setups
    image: ghcr.io/blakeblackshear/frigate:0.12.1
    shm_size: "512mb" # update for your cameras based on calculation above
    environment:
      - TZ=Asia/Shanghai
    network_mode: host
    devices:
      - /dev/bus/usb:/dev/bus/usb # passes the USB Coral, needs to be modified for other versions
#      - /dev/apex_0:/dev/apex_0 # passes a PCIe Coral, follow driver instructions here https://coral.ai/docs/m2/get-started/#2a-on-linux
      - /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
    volumes:
      - /root/frigate/config/config.yml:/config/config.yml
      - /root/frigate/media:/media/frigate
      - /root/frigate/config:/db
      - type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
        target: /tmp/cache
        tmpfs:
#    ports:
#      - "5000:5000"
#      - "8554:8554" # RTSP feeds
#      - "8555:8555/tcp" # WebRTC over tcp
#      - "8555:8555/udp" # WebRTC over udp
    environment:
      FRIGATE_RTSP_PASSWORD: "password"
  node-red:
    container_name: node-red
    image: nodered/node-red:3.1.0
    environment:
      - TZ=Asia/Shanghai
#    ports:
#      - "1880:1880"
    network_mode: host
    volumes:
      - /root/nodered/data:/data
  zigbee2mqtt:
    container_name: zigbee2mqtt
    image: koenkk/zigbee2mqtt:1.33.0
    privileged: true
    volumes:
      - /root/zigbee2mqtt/data:/app/data
      - /run/udev:/run/udev:ro
    ports:
      # Frontend port
      - 8080:8080
    environment:
      - TZ=Asia/Shanghai
#    devices:
      # Make sure this matched your adapter location
#      - /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED3DDF-if00:/dev/ttyACM0
发表于 2023-10-11 09:58:57 | 显示全部楼层
sorrypqa 发表于 2023-10-11 08:00
我喜欢用docker-compose:
version: '3'
谢谢分享
发表于 2023-10-12 20:38:11 | 显示全部楼层
高手都直接docker玩,就是麻烦些
发表于 2023-10-12 20:56:41 | 显示全部楼层
sorrypqa 发表于 2023-10-10 23:13
都用HOST网络不行吗?
改成host也没办法实现mdns域名访问
GMT+8, 2025-11-30 17:22 , Processed in 1.336218 second(s), 7 queries , MemCached On.
