查看: 2900|回复: 1
[已解决] esphome编译窗口空白
发表于 2023-10-4 19:19:28 | 显示全部楼层 |阅读模式
已解决
是网络代理问题导致。
编译窗口中没有任何数据或内容,等了好几个小时一直这样。
基础内容编译也一样。
编译选项中任何选择都是这个结果~
Home Assistant 2023.9.3
Supervisor 2023.09.2
Operating System 10.5
前端版本: 20230911.0 - latestESPhome 版本:2023.9.3
ESPHome
s6-rc: info: service base-addon-banner: starting
 Add-on: ESPHome
 ESPHome add-on for intelligently managing all your ESP8266/ESP32 devices
 Add-on version: 2023.9.3
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.5  (amd64 / qemux86-64)
 Home Assistant Core: 2023.9.3
 Home Assistant Supervisor: 2023.09.2
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
[19:42:17] INFO: Configuring timezone (Asia/Shanghai)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service esphome: starting
s6-rc: info: service esphome successfully started
[19:42:23] INFO: Starting ESPHome dashboard...
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service discovery: starting
[19:42:24] INFO: Waiting for ESPHome dashboard to come up...
2023-10-04 19:42:39,421 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome...
[19:42:39] INFO: Starting NGINX...
[19:42:41] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
2023-10-04 19:42:50,188 INFO 200 GET / (0.0.0.0) 110.50ms
2023-10-04 19:42:50,309 INFO 304 GET /devices (0.0.0.0) 1.44ms
2023-10-04 19:42:58,434 INFO 304 GET / (0.0.0.0) 0.72ms
2023-10-04 19:42:58,523 INFO 304 GET /devices (0.0.0.0) 1.21ms
2023-10-04 19:43:07,990 INFO 304 GET /info?configuration=esp8266-menci.yaml (0.0.0.0) 1.93ms
2023-10-04 19:43:07,992 INFO 304 GET /devices (0.0.0.0) 2.55ms
 楼主| 发表于 2023-10-4 19:51:15 | 显示全部楼层
Logger: homeassistant.components.esphome.dashboard
Source: components/esphome/dashboard.py:37
Integration: ESPHome (documentation, issues)
First occurred: 19:41:26 (1 occurrences)
Last logged: 19:41:26
Dashboard unavailable; skipping reauth: Cannot connect to host 127.0.0.1:64337 ssl:default [Connect call failed ('127.0.0.1', 64337)]
以上是错误日志
GMT+8, 2025-12-17 07:22 , Processed in 1.305800 second(s), 8 queries , MemCached On.
