查看: 2063|回复: 4
[求助] G10S无法集成到homeassistant core。求解答
发表于 2023-10-4 10:35:31 | 显示全部楼层 |阅读模式
Logger: homeassistant.components.number
Source: runner.py:186
Integration: 数值输入器 (documentation, issues)
First occurred: 2023年10月1日 下午9:06:28 (19 occurrences)
Last logged: 上午10:30:47
Setup of number platform roborock is taking over 10 seconds.
Source: components/roborock/sensor.py:53
First occurred: 2023年10月1日 下午9:06:18 (19 occurrences)
Last logged: 上午10:30:37
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 495, in async_add_entities
    tasks = [
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 495, in <listcomp>
    tasks = [
  File "/usr/src/homeassistant/homeassistant/components/roborock/sensor.py", line 157, in <genexpr>
    if description.value_fn(coordinator.roborock_device_info.props) is not None
  File "/usr/src/homeassistant/homeassistant/components/roborock/sensor.py", line 53, in <lambda>
    value_fn=lambda data: data.consumable.main_brush_time_left,
AttributeError: 'NoneType' object has no attribute 'main_brush_time_left'
Logger: roborock.cloud_api
Source: /usr/local/lib/python3.11/site-packages/roborock/api.py:313
First occurred: 2023年10月1日 上午6:00:32 (118 occurrences)
Last logged: 上午6:01:40
[石头G10S] Client or broker did not communicate in the keepalive interval.
 楼主| 发表于 2023-10-4 10:53:43 | 显示全部楼层
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/connection.py:268
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 2023年10月1日 23:56:29 (1 occurrences)
Last logged: 2023年10月1日 23:56:29
[281472996245312] Error handling message: extra keys not allowed @ data['rocorock']. Got None (invalid_format) zhuiqiu from 192.168.3.94 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Safari/537.36 Edg/117.0.2045.43)
发表于 2023-10-4 11:23:49 | 显示全部楼层
如果不需要石头那个摄像头对话功能的话,直接改成小米app接入扫地机,然后用miot auto插件接入很方便
 楼主| 发表于 2023-10-4 15:59:46 | 显示全部楼层
wdmywm3 发表于 2023-10-4 11:23
如果不需要石头那个摄像头对话功能的话,直接改成小米app接入扫地机,然后用miot auto插件接入很方便 ...
好的,谢谢
 楼主| 发表于 2023-10-4 16:28:21 | 显示全部楼层
我没动它,它自己集成了,目前显示1个设备22个实体,功能应该是还不够齐全
GMT+8, 2025-12-17 07:22 , Processed in 1.004662 second(s), 6 queries , MemCached On.
