查看: 2460|回复: 2
[流程系列] 求助,NodeRED老是报错
发表于 2023-9-23 15:56:16 | 显示全部楼层 |阅读模式
我家调光玻璃亮度值要注入60%-100%范围才有变化,60%以下肉眼不可见,所以就用Function转化一下数值再输出给KNX调光模块,目前虽然已经实现了我想要的功能,但调试窗口老是报错,感觉是语法不对,特请教大家我应该改哪里啊?
报错:
[{"id":"44cc64a8f6a918ad","type":"server-state-changed","z":"76bc1932a4eb7370","name":"左窗透明度","server":"1b7ace1.5629a32","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.liftwindow_2","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"data.attributes.brightness","propertyType":"msg","value":"","valueType":"eventData"}],"x":140,"y":220,"wires":[["c55832217da8baf1","4a32995d953ac4f6"]]},{"id":"c55832217da8baf1","type":"function","z":"76bc1932a4eb7370","name":"调整亮度到真实值","func":"var birg = msg.data.attributes.brightness.new_state.attributes.brightness;\nbirg = (birg * 0.41) + 150;\nvar birgint = birg.toFixed(0);\n{\n    if (birgint <= 151)\n        birgint = 1;\n    else\n        birgint = birgint;\n}\nmsg.data.attributes.brightness = birgint;\nreturn msg.data.attributes;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":220,"wires":[["1faecc8239b72c86","0b5b5d18a2b25b81"]]},{"id":"0b5b5d18a2b25b81","type":"debug","z":"76bc1932a4eb7370","name":"debug 18","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":570,"y":140,"wires":[]},{"id":"4a32995d953ac4f6","type":"debug","z":"76bc1932a4eb7370","name":"debug 21","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":310,"y":120,"wires":[]},{"id":"1faecc8239b72c86","type":"api-call-service","z":"76bc1932a4eb7370","name":"主窗输出","server":"1b7ace1.5629a32","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.outliftwindowtransparency"],"data":"{ "brightness":brightness }","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":620,"y":220,"wires":[["8a8ba3e2c4e89165"]]},{"id":"8a8ba3e2c4e89165","type":"debug","z":"76bc1932a4eb7370","name":"debug 22","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":890,"y":120,"wires":[]},{"id":"1b7ace1.5629a32","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiI3ZDM3NzYwODQyNTA0MzAwODBhYjU3MzYwNWRkMDhiOCIsImlhdCI6MTY5NDYxNzI3NywiZXhwIjoyMDA5OTc3Mjc3fQ.lKAjooB5SvuEVb0hQVRjEDvYT37RgYeVpqqdt77MyXk","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","areaSelector":"id","deviceSelector":"id","entitySelector":"id","statusSeparator":"","enableGlobalContextStore":false}]
 楼主| 发表于 2023-9-24 01:01:16 | 显示全部楼层
哦,原因找到了:homeassistant组件节点运行的Red版本是3.10。就是这恼人的提示挡着我看调试信息,有点烦。
https://community.home-assistant.io/t/node-red-4-0-warnings-have-taken-over-my-debug-window/615166/5
发表于 2023-10-9 16:28:03 | 显示全部楼层
现在可以升级一下homeassistant节点了。
请教一下,我是在PVE中LXC方式安装的NODE-RED,磁盘空间空间没几天就会被占满,有什么办法进行清理无用的数据吗?
GMT+8, 2025-12-3 07:38 , Processed in 0.066012 second(s), 15 queries , MemCached On.
