查看: 1523|回复: 4
[求助] 小爱音箱mini无法连接网络
发表于 2023-9-23 00:04:51 | 显示全部楼层 |阅读模式
各位大佬,小爱音箱mini无法连接网络,通电后出现的最后字符是:[   13.968595] CONFIG-ERROR) dhd_conf_set_intiovar: force_wme_ac setting failed -23,请问是固件坏了吗?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2023.09.22 21:31:43 =~=~=~=~=~=~=~=~=~=~=~=
    HELLO! BOOT0 is starting!
boot0 version : 4.2.0
boot0 commit : a1ae6c20d88d561753072492191f817d9ff10a36
fel_flag = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
DRAM DRIVE INFO: V1.7
DRAM Type =3 (2DR2,3DR3,6PDDR2,7PDDR3)
DRAM zq value: 00003bfbDRAM CLK =552 MHZ
ID CHECK VERSION: V0.1
using ic R16
USE PLL DDR0
USE PLL NORMAL
PLL FREQUENCE = 552 MHZ
DRAM master priority setting ok.
Auto calculate timing parameter!
para_dram_tpr0 = 0047214f
para_dram_tpr1 = 01c2294b
para_dram_tpr2 = 00061043
tcl = 6,tcwl = 4
DRAM TIMING PARA0 = 0b0e180b
DRAM TIMING PARA1 = 0003040f
DRAM TIMING PARA2 = 0406050a
DRAM TIMING PARA3 = 0000400c
DRAM TIMING PARA4 = 05020405
DRAM TIMING PARA5 = 05050403
DRAM TIMING PARA8 = 90003310
DRAM PHY INTERFACE PARA = 02040102
DRAM VTC is disable
DRAM dynamic DQS/DQ ODT is on
DRAM DQS gate is PD mode.
DRAM one rank training is on,the value is 91003587
DRAM work mode register value = 004318c4
DRAM SIZE =128 M
set one rank ODTMAP
DRAM simple test OK.
dram size =128
NAND_ClkRequest, nand_index: 0x00001000
Reg 0x01c20080: 0x00053de3
Reg 0x01c20060: 0x00053dd6
Reg 0x01c202c0: 0x00053dd6
NAND_SetClk, nand_index: 0x0000000a
Reg 0x01c20080: 0x00053de7
NB0 : nand phy init ok
block from 4 to 39
nand block 4 is bad
nand block 5 is bad
nand block 6 is bad
nand block 7 is bad
current block is 8 and last block is 39.
current block is 9 and last block is 39.
current block is 10 and last block is 39.
current block is 11 and last block is 39.
current block is 12 and last block is 39.
current block is 13 and last block is 39.
current block is 14 and last block is 39.
sum=69e8b1f9
src_sum=69e8b1f9
The file stored in start block %u is perfect.
Ready to disable icache.
Jump to secend Boot.
[      0.469]
U-Boot 2011.09-rc1-00000-g2701bad-dirty (Apr 28 2018 - 22:11:21) Allwinner Technology
[      0.479]version: 1.1.0
[      0.481]uboot commit : 2701bad684727964760cfd03f426f8c02bbf2558
[      0.488]pmbus:   normal or secure os
ready
[      0.493]PMU: AXP221
[      0.495]PMU: AXP22x found
bat_vol=0, ratio=100
[      0.500]PMU: dcdc3 1200
[      0.503]PMU: pll1 1008 Mhz,PLL6=600 Mhz
AXI=336 Mhz,AHB=200 Mhz, APB1=100 Mhz
dcdc1_vol = 3000
dcdc2_vol = 1100
dcdc3_vol = 1200
dcdc4_vol = 0
dcdc5_vol = 1500
aldo2_vol = 2500
aldo3_vol = 3000
find power_sply to end
vbus not exist
fel key new mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[      1.627]DRAM:  128 MiB
relocation Offset is: 061f1000
save config for small mem_size
sunxi spi ws2812 is initing...
spi0 gpio cfg done
read CCM_AHB1_RST_REG0[0x6040]
read enable CCM_AHB1_RST_REG0[0x106040]
read s CCM_AHB1_GATE0_CTRL[0x106040]
SPI clock source :0x23c34600
spi spic->sclk =0xd0130b
spic_set_clk:mclk=0xd0130b
sunxi spi init OK
workmode = 0
[      1.722]NAND: NAND_UbootInit
NAND_UbootInit start
NB1 : enter NAND_LogicInit
uboot:nand version: 3 5011 20180329 16671134
nand : get id_number_ctl fail, 1
uboot:nand info: 9500f1ec ffffff42 4000008c 0 0
nand : get sorting_flag fail, a
nand : get CapacityLevel fail, 46b96d6a
not burn nand partition table!
NB1 : nftl num: 1
init nftl: 0
NB1 : NAND_LogicInit ok, result = 0x0
[      2.101]sunxi flash init ok
In:    serial
Out:   serial
Err:   serial
--------fastboot partitions--------
-total partitions:9-
-name-        -start-       -size-
env         : 1000000       100000
kernel1     : 1100000       600000
rootfs1     : 1700000       2000000
kernel2     : 3700000       600000
rootfs2     : 3d00000       2000000
misc        : 5d00000       100000
private     : 5e00000       100000
crashlog    : 5f00000       100000
UDISK       : 6000000       0
base bootcmd=run setargs_second boot_second
bootcmd set setargs_nand
key 0
cant find rcvy value
cant find fstbt value
misc partition found
flag_try_sys1_failed=0
flag_try_sys2_failed=0
flag_ota_reboot     =0
flag_last_success   =1
os index:1
to be run cmd=run setargs_second boot_second
sunxi_serial: sn_filename is not exist
serial is: 2847882c8243ffffef78
Net:   usb_etherWarning: failed to set MAC address
WORK_MODE_BOOT
board_status_probe
sunxi_bmp_logo_display
[      2.238]Hit any key to stop autoboot:  0
fatload partition name: kernel2 -> 3
## Booting kernel from Legacy Image at 43800000 ...
   Image Name:   ARM OpenWrt Linux-3.4.39
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3361680 Bytes = 3.2 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
[      2.525][mmc]: MMC Device 2 not found
[      2.529][mmc]:  mmc 馃?馃?馃?馃?馃?馃?馃鍫疐 not find,so not exit
NAND_UbootExit
NB1 : NAND_LogicExit
nand release dma:0
dma 0x46bb11d4 int is not used yet
dma 0x46bb11d4 int is free, you do not need to free it again
dma 0x46bb11f0 int is not used yet
dma 0x46bb11f0 int is free, you do not need to free it again
reload config to 0x43000000
[      2.536]
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Linux version 3.4.39 (jenkins@0fb9f76662d9) (gcc version 5.2.1 (OpenWrt/Linaro GCC 5.2-2015.11-2 2016-11-07) ) #1 SMP PREEMPT Tue Jul 17 05:13:09 UTC 2018
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun8i
[    0.000000] Initialized persistent memory from 43080800-430907ff
[    0.000000] cma: CMA: reserved 32 MiB at 46000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 32768
[    0.000000] free_area_init_node: node 0, pgdat c06b0040, node_mem_map c06f0000
[    0.000000]   Normal zone: 288 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 32480 pages, LIFO batch:7
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 7 pages/cpu @c0823000 s6464 r8192 d14016 u32768
[    0.000000] pcpu-alloc: s6464 r8192 d14016 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32480
[    0.000000] Kernel command line: boot_type=0 uboot_hash=2701bad684 uboot_version=1 disp_para=1 fb_base=0x0 config_size=40960 boot.serialno=2847882c8243ffffef78 boot.hardware=sun8i console=ttyS0,115200 root=/dev/nande rootwait init=/sbin/init ion_cma_list=8m,32m,64m,128m,256m loglevel=8 partitions=env@nanda:kernel1@nandb:rootfs1@nandc:kernel2@nandd:rootfs2@nande:misc@nandf:private@nandg:crashlog@nandh:UDISK@nandi
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 128MB = 128MB total
[    0.000000] Memory: 89576k/89576k available, 41496k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc062e000   (6296 kB)
[    0.000000]       .init : 0xc062e000 - 0xc0659940   ( 175 kB)
[    0.000000]       .data : 0xc065a000 - 0xc06b0da0   ( 348 kB)
[    0.000000]        .bss : 0xc06b1c24 - 0xc06efd20   ( 249 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:416
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000198] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000217] pid_max: default: 4096 minimum: 301
[    0.000355] Security Framework initialized
[    0.000432] Mount-cache hash table entries: 512
[    0.001260] CPU: Testing write buffer coherency: ok
[    0.001484] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001494] [sunxi_smp_prepare_cpus] enter
[    0.001531] Setting up static identity map for 0x4049fb00 - 0x4049fb58
[    0.006142] CPU1: Booted secondary processor
[    0.006208] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.010000] CPU2: Booted secondary processor
[    0.010000] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.010341] CPU3: Booted secondary processor
[    0.010341] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.010453] Brought up 4 CPUs
[    0.010453] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.014390] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.014768] pinctrl core: initialized pinctrl subsystem
[    0.021185] NET: Registered protocol family 16
[    0.021891] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.021891] script_sysfs_init success
[    0.021891] sunxi_dump_init success
[    0.022804] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.024149] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.024149] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl
[    0.024149] persistent_ram: uncorrectable error in header
[    0.024149] persistent_ram: no valid data in buffer (sig = 0x43474344)
[    0.032060] console [ram-1] enabled
[    0.032521] [sunxi-module]: [sunxi-module.0] probe success
[    0.032666] ###########nand crash handler registered
[    0.032805] script config pll3 to 297 Mhz
[    0.033043] script config pll4 to 300 Mhz
[    0.033194] script config pll6 to 600 Mhz
[    0.033432] script config pll8 to 408 Mhz
[    0.033570] script config pll9 to 480 Mhz
[    0.033699] script config pll10 to 297 Mhz
[    0.033926] sunxi_default_clk_init
[    0.034050] try to set pll6ahb1 to 200000000
[    0.034216] try to set ahb clk source to pll6ahb1
[    0.034447] set ahb clk source to pll6ahb1
[    0.034575] try to set ahb1 to 200000000
[    0.034702] try to set apb1 to 100000000
[    0.040232] bio: create slab <bio-0> at 0
[    0.040506] [ARISC] :sunxi-arisc driver v1.02
[    0.059222] [ARISC] :arisc version: [v0.1.33]
[    0.065953] [ARISC] :sunxi-arisc driver v1.02 startup succeeded
[    0.066181] pwm module init!
[    0.067849] usbcore: registered new interface driver usbfs
[    0.067849] usbcore: registered new interface driver hub
[    0.067849] usbcore: registered new device driver usb
[    0.067849] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.067849] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.067849] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.070171] Linux video capture interface: v2.00
[    0.070025] [axp22_init_chip] read axp22 ic type=0x6
[    0.071765] current_limit = 700000
[    0.080264] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.080922] Bluetooth: Core ver 2.16
[    0.081209] NET: Registered protocol family 31
[    0.081334] Bluetooth: HCI device and connection manager initialized
[    0.081462] Bluetooth: HCI socket layer initialized
[    0.081693] Bluetooth: L2CAP socket layer initialized
[    0.081832] Bluetooth: SCO socket layer initialized
[    0.082275] cfg80211: Calling CRDA to update world regulatory domain
[    0.082998] Switching to clocksource arch_sys_counter
[    0.083524] FS-Cache: Loaded
[    0.083748] CacheFiles: Loaded
[    0.087015] hci: ERR: get ehci1 abh clk failed.
[    0.087253] hci: ERR: clock_init failed
[    0.087391] hci: ERR: get ohci1 abh clk failed.
[    0.087517] hci: ERR: clock_init failed
[    0.089159] NET: Registered protocol family 2
[    0.089526] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.090314] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.090514] TCP bind hash table entries: 4096 (order: 3, 49152 bytes)
[    0.090816] TCP: Hash tables configured (established 4096 bind 4096)
[    0.091048] TCP: reno registered
[    0.091430] NET: Registered protocol family 1
[    0.092096] [pm]aw_pm_init!
[    0.092228] standby_mode = 1.
[    0.092458] wakeup src cnt is : 3.
[    0.092585] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.092818] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x80
[    0.092946] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x0
[    0.093179] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.093411] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x280
[    0.093539] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x0
[    0.093772] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.094004] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x284
[    0.094234] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x0
[    0.094395] sunxi_reg_init enter
[    0.095089] audit: initializing netlink socket (disabled)
[    0.095243] type=2000 audit(0.090:1): initialized
[    0.096448] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.096732] jffs2: version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
[    0.097252] msgmni has been set to 238
[    0.098536] io scheduler noop registered
[    0.098668] io scheduler deadline registered
[    0.098966] io scheduler cfq registered (default)
[    0.099236] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.099474] sw_uart_get_devinfo()1503 - uart1 has no uart_regulator.
[    0.100081] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.100318] sw_uart_pm()890 - uart0 clk is already enable
[    0.100454] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.293278] console [ttyS0] enabled
[    0.391988] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    0.494267] loop: module loaded
[    0.593501] [NAND]panic_buff_handle 0xc6200000 ,0x46200000
[    1.041783] [NAND][NAND]nand init start, nand0_used_flag is 1
[    1.048381] [NAND]nand_cache_level err! 0[NAND]nand_capacity_level err! 0
[    1.056163] regisger ISP =====================
[    1.061345] [NAND]nand init start
[    1.065135] NandHwInit: Start Nand Hardware initializing .....
[    1.071837] kernel:nand version: 3 5011 20180329 16671134
[    1.078640] [NAND] channel cnt is 1
[    1.082634] ndfc version: 1
[    1.086046] ndfc dma mode: MBUS DMA
[    1.090041] pin count:19
[    1.093175] NAND_ClkRequest: get pll6 rate 600000000HZ
[    1.099275] nand:get voltage axp22_dcdc1 ok:c5a33840
[    1.104977] Reset NDFC 0
[    1.107903] NFC Randomizer start.
[    1.111925] NFC_ResetChip: 0x101, 0x100 0x10095
[    1.117065] NFC_ResetChip: 0xff, ch: 0
[    1.121409] [PHY_DBG] CH 0 Nand flash chip id is:0xec 0xf1 0x0 0x95 0x42 0xc6
[    1.129547] nand id of two channel is not the same, set to 1 channel mode
[    1.137313] [SCAN_DBG] Nand flash chip id is:0xec 0xf1 0x0 0x95 0x42 0xc6
[    1.144977] [SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xfffffdaf
[    1.153128] nand_para0, id_number_ctl, nand type err! 0
[    1.159039] _UpdateExtAccessFreqPara: no para.
[    1.164199] NFC_ResetChip: 0x1000101, 0x100 0x10095
[    1.169725] NFC_ResetChip: 0xff, ch: 0
[    1.174037] [PHY_DBG] CH 0 Nand flash chip id is:0x0 0x0 0x0 0x0 0x0 0x0
[    1.181704] NFC_ResetChip: 0x2000109, 0x100 0x10095
[    1.187229] NFC_ResetChip: 0xff, ch: 0
[    1.191621] wrong Rb connect Mode, chip = 2 ,RbConnectMode = 1
[    1.198328] [PHY_DBG] CH 0 Nand flash chip id is:0x0 0x0 0x0 0x0 0x0 0x0
[    1.205997] NFC_ResetChip: 0x3000109, 0x100 0x10095
[    1.211534] NFC_ResetChip: 0xff, ch: 0
[    1.215918] wrong Rb connect Mode, chip = 3 ,RbConnectMode = 1
[    1.222634] [PHY_DBG] CH 0 Nand flash chip id is:0x0 0x0 0x0 0x0 0x0 0x0
[    1.230301] Reset NDFC 0
[    1.233227] PageCachePool.PageCache0: 0xc599e000
[    1.238466] PageCachePool.PageCache1: 0xc5a4a000
[    1.243821] PageCachePool.PageCache2: 0xc5a4c000
[    1.249059] PageCachePool.PageCache3: 0xc5a4e000
[    1.254416] PageCachePool.PageCache4: 0xc5a78000
[    1.259652] PageCachePool.SpareCache: 0xc59917c0
[    1.264902] PageCachePool.TmpPageCache: 0xc5a7a000
[    1.270450] PageCachePool.TmpPageCache1: 0xc5a7c000
[    1.275980] PHY_ChangeMode: sclk0 will be changed! 10 -> 30
[    1.282395] PHY_ChangeMode: before check blank page, 0x101, 0x100, 0x10095, 0x21f
[    1.291597] _check_scan_data, it is a free page(type 1), block 4
[    1.298481] _check_scan_data, read error, block 4 !
[    1.304767] _check_scan_data, it is a free page(type 1), block 5
[    1.311664] _check_scan_data, read error, block 5 !
[    1.317940] _check_scan_data, it is a free page(type 1), bl
[    1.911915] [ND]partition->nand_disk[14].size :-1
[    1.917352] [ND]partition->nand_disk[14].type :-1
[    1.922691] [ND]partition->nand_disk[15].size :-1
[    1.928127] [ND]partition->nand_disk[15].type :-1
[    1.933469] [ND]partition->nand_disk[16].size :-1
[    1.938800] [ND]partition->nand_disk[16].type :-1
[    1.944248] [ND]partition->nand_disk[17].size :-1
[    1.949581] [ND]partition->nand_disk[17].type :-1
[    1.955028] [ND]partition->nand_disk[18].size :-1
[    1.960369] [ND]partition->nand_disk[18].type :-1
[    1.965805] [ND]partition->nand_disk[19].size :-1
[    1.971147] [ND]partition->nand_disk[19].type :-1
[    1.976479] [ND]partition->nand_disk[20].size :-1
[    1.981925] [ND]partition->nand_disk[20].type :-1
[    1.987257] [ND]partition->nand_disk[21].size :-1
[    1.992702] [ND]partition->nand_disk[21].type :-1
[    1.998033] [ND]partition->nand_disk[22].size :-1
[    2.003378] [ND]partition->nand_disk[22].type :-1
[    2.008814] [ND]partition->nand_disk[23].size :-1
[    2.014155] [ND]partition->nand_disk[23].type :-1
[    2.019595] [NE]partition_num: 0,size :0x36e00,cross_talk 0
[    2.025905] [NE]part mbr size: 0x8000 type: 0
[    2.030969] [NE]part env size: 0x800 type: 0
[    2.035820] [NE]part kernel1 size: 0x3000 type: 0
[    2.041188] [NE]part rootfs1 size: 0x10000 type: 0
[    2.046723] [NE]part kernel2 size: 0x3000 type: 0
[    2.052066] [NE]part rootfs2 size: 0x10000 type: 0
[    2.057599] [NE]part misc size: 0x800 type: 0
[    2.062555] [NE]part private size: 0x800 type: 0
[    2.067789] [NE]part crashlog size: 0x800 type: 0
[    2.073237] [NE]part UDISK size: 0x6e00 type: 0
[    2.078414] [ND]factory bad block:0,257 PartitionNO:0
[    2.084272] [ND]factory bad block:0,511 PartitionNO:0
[    2.089990] [ND]build 1 phy_partition !
[    2.094367] [ND]nand_info->type :0
[    2.098357] [ND]nand_info->SectorNumsPerPage :8
[    2.103506] [ND]nand_info->BytesUserData :16
[    2.108355] [ND]nand_info->ageNumsPerBlk :64
[    2.113415] [ND]nand_info->BlkPerChip :512
[    2.118071] [ND]nand_info->FirstBuild :0
[    2.122650] [ND]nand_info->FullBitmap :1610612883
[    2.127983] [ND]nand_info->bad_block_addr.Chip_NO :0
[    2.133619] [ND]nand_info->bad_block_addr.Block_NO :0
[    2.139444] [ND]nand_info->mbr_block_addr.Chip_NO :0
[    2.145075] [ND]nand_info->mbr_block_addr.Block_NO :0
[    2.150908] [ND]nand_info->no_used_block_addr.Chip_NO :0
[    2.156913] [ND]nand_info->no_used_block_addr.Block_NO :23
[    2.163227] [ND]nand_info->new_bad_block_addr.Chip_NO :0
[    2.169233] [ND]nand_info->new_bad_block_addr.Block_NO :0
[    2.175449] [ND]nand_info->new_bad_page_addr :65535
[    2.180984] [ND]nand_info->partition_nums :1
[    2.185833] [ND]sizeof partition:2384
[    2.190122] [ND]nand_info->partition:0:
[    2.194489] [ND]size:0x36e00
[    2.197795] [ND]cross_talk:0x0
[    2.201408] [ND]attribute:0x0
[    2.204813] [ND]start: chip:0 block:23
[    2.209084] [ND]end  : chip:0 block:511
[    2.213567]  check_phyisc start.
[    2.221643] uboot->sys_mode 0
[    2.225144] uboot->use_lsb_page 0
[    2.229029] uboot->copys 4
[    2.232358] uboot->uboot_len 901120
[    2.236436] uboot->total_len 933888
[    2.240524] uboot->uboot_pages 440
[    2.244611] uboot->total_pages 456
[    2.248593] uboot->blocks_per_total 8
[    2.252874] uboot->page_offset_for_nand_info 440
[    2.258310] uboot->uboot_block
[    2.261818]  8 16 24 32 0 0 0 0 0 0 0
[    2.267313]  0 0 0 0 0 0 0 0 0 0
[    2.272218]  0 0 0 0 0 0 0 0 0
[    2.342638] nand_read_uboot_one ok 0
[    2.412535] nand_read_uboot_one ok 1
[    2.482414] nand_read_uboot_one ok 2
[    2.552430] nand_read_uboot_one ok 3
[    2.556606]  check_phyisc end.
[    2.560324] [NAND]nand_probe
[    2.563767] [NAND]nand type err!
[    2.567667] [ND]nand_partition0
[    2.571364] [ND]nftl start:489,50
[    2.575227] [ND]first
[    2.582439] _ReadCheckSpare: filled invalid page(0,42,0)...
[    2.588962] _ReadCheckSpare: filled invalid page(0,43,0)...
[    2.596933] _ReadCheckSpare: filled invalid page(0,50,0)...
[    2.615020] _ReadCheckSpare: filled invalid page(0,103,0)...
[    2.622645] _ReadCheckSpare: filled invalid page(0,108,0)...
[    2.629707] _ReadCheckSpare: filled invalid page(0,111,0)...
[    2.666658] _ReadCheckSpare: filled invalid page(0,248,0)...
[    2.674859] [ND]bad block: 234
[    2.679703] _ReadCheckSpare: filled invalid page(0,263,0)...
[    2.686439] _ReadCheckSpare: filled invalid page(0,264,0)...
[    2.693296] _ReadCheckSpare: filled invalid page(0,266,0)...
[    2.700247] _ReadCheckSpare: filled invalid page(0,268,0)...
[    2.707537] _ReadCheckSpare: filled invalid page(0,272,0)...
[    2.716286] _ReadCheckSpare: filled invalid page(0,282,0)...
[    2.724037] _ReadCheckSpare: filled invalid page(0,288,0)...
[    2.730773] _ReadCheckSpare: filled invalid page(0,289,0)...
[    2.737616] _ReadCheckSpare: filled invalid page(0,291,0)...
[    2.744351] _ReadCheckSpare: filled invalid page(0,292,0)...
[    2.751653] _ReadCheckSpare: filled invalid page(0,296,0)...
[    2.759720] _ReadCheckSpare: filled invalid page(0,303,0)...
[    2.766575] _ReadCheckSpare: filled invalid page(0,305,0)...
[    2.773985] _ReadCheckSpare: filled invalid page(0,309,0)...
[    2.785548] _ReadCheckSpare: filled invalid page(0,332,0)...
[    2.792286] _ReadCheckSpare: filled invalid page(0,333,0)...
[    2.799128] _ReadCheckSpare: filled invalid page(0,335,0)...
[    2.807210] _ReadCheckSpare: filled invalid page(0,342,0)...
[    2.814066] _ReadCheckSpare: filled invalid page(0,344,0)...
[    2.820811] _ReadCheckSpare: filled invalid page(0,345,0)...
[    2.828100] _ReadCheckSpare: filled invalid page(0,349,0)...
[    2.834839] _ReadCheckSpare: filled invalid page(0,350,0)...
[    2.843697] _ReadCheckSpare: filled invalid page(0,361,0)...
[    2.850661] _ReadCheckSpare: filled invalid page(0,363,0)...
[    2.857950] _ReadCheckSpare: filled invalid page(0,367,0)...
[    2.885219] _ReadCheckSpare: filled invalid page(0,460,0)...
[    2.893204] _ReadCheckSpare: filled invalid page(0,467,0)...
[    2.902406] _ReadCheckSpare: filled invalid page(0,479,0)...
[    2.910377] _ReadCheckSpare: filled invalid page(0,486,0)...
[    2.918679] _ReadCheckSpare: filled invalid page(0,494,0)...
[    2.928692] [ND]bad block: 488
[    2.932311] [ND]before second 487 439.
[    3.061249] [NE]smart->version:aaaaaa01;
[    3.065719] [NE]smart->total_recv_read_sectors:3900514;
[    3.071750] [NE]smart->total_recv_write_sectors:509332;
[    3.077660] [NE]smart->total_real_read_pages:536507;
[    3.083397] [NE]smart->total_real_write_pages:94135;
[    3.089016] [NE]smart->total_recv_discard_sectors:28160;
[    3.095137] [NE]smart->total_real_discard_sectors:28160;
[    3.101155] [NE]smart->total_recv_read_claim_pages:0;
[    3.106873] [NE]smart->total_gc_times:0;
[    3.111452] [NE]smart->total_gc_pages:0;
[    3.115914] [NE]smart->total_wl_times:0;
[    3.120388] [NE]smart->total_real_read_error_pages:0;
[    3.126211] [NE]smart->total_real_write_error_pages:0;
[    3.132035] [NE]smart->total_normal_power_cycles:47;
[    3.137761] [NE]smart->total_unusual_power_cycles:0;
[    3.143391] [NE]smart->max_block_erase_times:0;
[    3.148634] [NE]smart->min_block_erase_times:0;
[    3.153781] [NE]smart->max_block_used_counter:0;
[    3.159016] [NE]smart->min_block_used_counter:0;
[    3.164366] [NE]smart->read_reclaim_utc:1531805787;
[    3.169892] [NE]smart->cross_talk_times:0;
[    3.214700] [NE]recover_phy_page_mapping no used page 33!!
[    3.220916] [ND]recover 284 33
[    3.224422] [ND] nand3.5 version:0001 date:Mar 29 2018 15:10:47
[    3.231219] [ND]zone->nand_chip->blk_per_chip: 489
[    3.236743] [ND]zone->nand_chip->bytes_per_page: 4096
[    3.242672] [ND]zone->nand_chip->pages_per_blk: 64
[    3.248196] [ND]zone->nand_chip->max_erase_times: 3000
[    3.254221] [ND]zone->nand_chip->support_read_reclaim: 0
[    3.260335] [ND]zone->test: 0
[    3.263834] [ND]zone->zone_no: 0
[    3.267727] [ND]zone->zone_attr: 0
[    3.271718] [ND]zone->blocks: 487
[    3.275604] [ND]zone->bad_block: 2
[    3.279692] [ND]zone->logic_cap_in_sects: 224768
[    3.285033] [ND]zone->backup_cap_in_sects: 24576
[    3.290376] [ND]zone->free_block_num: 137
[    3.295140] [ND]zone->gc_strategy.start_gc_free_blocks: 9
[    3.301348] [ND]zone->gc_strategy.stop_gc_free_blocks: 32
[    3.307651] [ND]zone->gc_strategy.gc_page: 0
[    3.312607] [ND]zone->gc_strategy.process: 1
[    3.317657] [ND]zone->prio_gc.prio_type : 0
[    3.322518] [ND]zone->zone_start_phy_block->phy_block.Block_NO: 0
[    3.329489] [ND]zone->zone_end_phy_block->phy_block.Block_NO: 487
[    3.336576] [ND]zone->zone_phy_page_map_for_gc: c5a92c00
[    3.342690] [ND]zone->current_block.user_info: c5a51400
[    3.348805] [ND]zone->current_block.block_info: c5a9a7f0
[    3.354918] [ND]zone->current_block.block_info->phy_block.Block_NO: 284
[    3.362585] [ND]zone->current_block.page_used: 33
[    3.368014] [ND]zone->current_block.block_info->block_used_count: 1495
[    3.375583] [ND]zone->read_reclaim_complete: 0
[    3.380731] [ND]zone->temp_page_buf: c58ee000
[    3.385877] [ND]zone->max_erase_num: 6
[    3.390254] [ND]zone->cache.cache_totals: 0
[    3.395210] [ND]zone->cfg->nftl_dont_use_cache: 0
[    3.400648] [ND]zone->cfg->nftl_use_cache_sort: 1
[    3.406076] [ND]zone->cfg->nftl_support_gc_read_reclaim: 1
[    3.412485] [ND]zone->cfg->nftl_support_wear_leveling: 1
[    3.418587] [ND]zone->cfg->nftl_need_erase: 0
[    3.423744] [ND]zone->cfg->nftl_min_free_block_num: 19
[    3.429654] [ND]zone->cfg->nftl_gc_threshold_free_block_num: 8
[    3.436450] [ND]zone->cfg->nftl_min_free_block: 4
[    3.441889] [ND]zone->cfg->nftl_gc_threshold_ratio_numerator: 2
[    3.448772] [ND]zone->cfg->nftl_gc_threshold_ratio_denominator: 3
[    3.455757] [ND]zone->cfg->nftl_max_cache_num: 20
[    3.461301] [ND]zone->cfg->nftl_max_cache_write_num: 1
[    3.467211] [ND]zone->cfg->nftl_cross_talk: 0
[    3.472263] [ND]zone->cfg->nftl_read_claim_interval: 1296000
[    3.478859] [NE]smart->version:aaaaaa01;
[    3.483333] [NE]smart->total_recv_read_sectors:3900514;
[    3.489349] [NE]smart->total_recv_write_sectors:509332;
[    3.495269] [NE]smart->total_real_read_pages:536605;
[    3.501005] [NE]smart->total_real_write_pages:94135;
[    3.506626] [NE]smart->total_recv_discard_sectors:28160;
[    3.512747] [NE]smart->total_real_discard_sectors:28160;
[    3.518754] [NE]smart->total_recv_read_claim_pages:0;
[    3.524584] [NE]smart->total_gc_times:0;
[    3.529047] [NE]smart->total_gc_pages:0;
[    3.533521] [NE]smart->total_wl_times:0;
[    3.538091] [NE]smart->total_real_read_error_pages:0;
[    3.543817] [NE]smart->total_real_write_error_pages:0;
[    3.549630] [NE]smart->total_normal_power_cycles:47;
[    3.555364] [NE]smart->total_unusual_power_cycles:0;
[    3.560996] [NE]smart->max_block_erase_times:0;
[    3.566240] [NE]smart->min_block_erase_times:0;
[    3.571388] [NE]smart->max_block_used_counter:0;
[    3.576727] [NE]smart->min_block_used_counter:0;
[    3.581974] [NE]smart->read_reclaim_utc:1531805787;
[    3.587499] [NE]smart->cross_talk_times:0;
[    3.592269] [ND]nftl ok!
[    3.595190] [ND] panic block 271!
[    3.598979] [ND] panic block 40!
[    3.602786] [ND] panic block 98!
[    3.606533] [ND]max_erase_times = 60000
[    3.611015] [NAND]nand_dev add mbr
[    3.614902] [NAND]nand_dev add env
[    3.619758]  nanda: unknown partition table
[    3.624843] [NAND]nand_dev add kernel1
[    3.629697]  nandb:
[    3.632458] [NAND]nand_dev add rootfs1
[    3.637283]  nandc: unknown partition table
[    3.642232] [NAND]nand_dev add kernel2
[    3.647131]  nandd:
[    3.649725] [NAND]nand_dev add rootfs2
[    3.654528]  nande: unknown partition table
[    3.659437] [NAND]nand_dev add misc
[    3.663951]  nandf: unknown partition table
[    3.668860] [NAND]nand_dev add private
[    3.673680]  nandg: unknown partition table
[    3.678593] [NAND]nand_dev add crashlog
[    3.683223]  nandh: unknown partition table
[    3.688247] [NAND]nand_dev add UDISK
[    3.692869]  nandi: unknown partition table
[    3.697868] [NAND]nand init end
[    3.701814] [rf_pm]: select module num is 10
[    3.706668] [rf_pm]: module power1 name axp22_dldo1
[    3.712218] [rf_pm]: module power1 vol 3300000
[    3.717367] [rf_pm]: module power2 name axp22_dldo2
[    3.722905] [rf_pm]: module power2 vol 3300000
[    3.728054] [rf_pm]: module power3 name axp22_aldo1
[    3.733592] [rf_pm]: module power3 vol 3300000
[    3.738637] [rf_pm]: mod has no power_switch gpio
[    3.744085] [rf_pm]: mod has no chip_en gpio
[    3.748936] [rf_pm]: lpo_use_apclk: losc_out
[    3.754009] [rf_pm]: set axp22_dldo1 to 3300000 v
[    3.759454] [rf_pm]: enable axp22_dldo1.
[    3.764472] [rf_pm]: set axp22_dldo2 to 3300000 v
[    3.769996] [rf_pm]: enable axp22_dldo2.
[    3.775004] [rf_pm]: set axp22_aldo1 to 3300000 v
[    3.780435] [rf_pm]: enable axp22_aldo1.
[    3.785049] [rf_pm]: mod info power switch -1
[    3.790103] [rf_pm]: set losc_out 32k out
[    3.794776] scene_lock_init name=rf_pm
[    3.799302] [wifi_pm]: wifi gpio init is OK !!
[    3.804438] [rfkill]: mod has no ls_int gpio
[    3.809397] [rfkill]: mod has no pcm_ch gpio
[    3.814505] [rfkill]: rfkill set power 0
[    3.830057] AW2013_led_init start
[    3.833994] aw2013_detect: adapter->nr = 0
[    3.838653] aw2013_detect: addr = 45
[    3.842906] twi_start()434 - [i2c0] START can't sendout!
[    3.849268] twi_start()434 - [i2c0] START can't sendout!
[    3.855536] twi_start()434 - [i2c0] START can't sendout!
[    3.861911] twi_start()434 - [i2c0] START can't sendout!
[    3.868169] twi_start()434 - [i2c0] START can't sendout!
[    3.874541] twi_start()434 - [i2c0] START can't sendout!
[    3.880822] twi_start()434 - [i2c0] START can't sendout!
[    3.887187] twi_start()434 - [i2c0] START can't sendout!
[    3.893455] twi_start()434 - [i2c0] START can't sendout!
[    3.899667] detect ret -1
[    3.902693] aw2013_detect:I2C connection might be something wrong
[    3.909668] aw2013_detect: adapter->nr = 1
[    3.914441] aw2013_detect: adapter->nr = 2
[    3.919100] [AW2013_led_init] Success to register AW2013 i2c driver.
[    3.926965] sunxi_spi_chan_cfg spi_para:spi0 i:0 type:1 item.val:1
[    3.933961] sunxi_spi_chan_cfg spi_used_mask:00000001
[    3.939788] sunxi_spi_register_spidev()2005 - [spi]: Found 1 spi devices in config files
[    3.948897] sunxi_spi_register_spidev()2014 - boards_num       modalias         max_spd_hz       bus_num  cs   mode
[    3.960721] sunxi_spi_register_spidev()2056 - 0                ws2812           25000000         0        0    0
[    3.972697] sunxi_spi_probe()1676 - [spi-0]: cs bitmap from cfg = 0x1
[    3.980530] sunxi_spi_clk_init()1490 - [spi-0] mclk 100000000
[    3.987123] spi spi0: master is unqueued, this is deprecated
[    3.993775] sunxi_spi_probe()1730 - allwinners SoC SPI Driver loaded for Bus SPI-0 with 1 Slaves at most
[    4.004534] sunxi_spi_probe()1731 - [spi-0]: driver probe succeed, base f1c68000, irq 97!
[    4.013759] module template loaded
[    4.017819] tun: Universal TUN/TAP device driver, 1.6
[    4.023552] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[    4.030748] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.058180] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.067316] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    4.076392] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    4.100037] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    4.100047] WRN2870(drivers/usb/sunxi_usb/udc/sunxi_udc.c):pdev is null
[    4.115098] hub 1-0:1.0: USB hub found
[    4.119494] hub 1-0:1.0: 1 port detected
[    4.124306] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.151366] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    4.160106] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2
[    4.168756] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    4.234459] hub 2-0:1.0: USB hub found
[    4.238855] hub 2-0:1.0: 1 port detected
[    4.243748] usbcore: registered new interface driver cdc_acm
[    4.250159] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.259305] usbcore: registered new interface driver cdc_wdm
[    4.265947] usbcore: registered new interface driver usbserial
[    4.272549] usbserial: USB Serial Driver core
[    4.277646] usbcore: registered new interface driver option
[    4.283992] USB Serial support registered for GSM modem (1-port)
[    4.291283] file system registered
[    4.296411] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    4.304291] android_usb gadget: Number of LUNs=3
[    4.309530]  lun0: LUN: removable file: (no medium)
[    4.315068]  lun1: LUN: removable file: (no medium)
[    4.320711]  lun2: LUN: removable file: (no medium)
[    4.326509] android_usb gadget: android_usb ready
[    4.332244] mousedev: PS/2 mouse device common for all mice
[    4.338636] sunxikbd_script_init: key para not found, used default para.
[    4.347021] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    4.354617] sunxi cedar version 0.1
[    4.358847] [cedar]: install start!!!
[    4.363174] [cedar]: install end!!!
[    4.369726] axp22_dcdc1: Failed to create debugfs directory
[    4.377126] Bluetooth: Virtual HCI driver ver 1.3
[    4.382565] Bluetooth: HCI UART driver ver 2.2
[    4.387716] Bluetooth: HCI H4 protocol initialized
[    4.393160] Bluetooth: HCILL protocol initialized
[    4.398557] usbcore: registered new interface driver btusb
[    4.404877] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    4.411606] axp22_dcdc3: Failed to create debugfs directory
[    4.420357] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.123 2017-01-11 15:04) Compiled in Jul 17 2018 at 05:13:02
[    4.432064] [mmc]: get mmc1's sdc_power failed
[    4.437102] [mmc]: MMC host used card: 0x2, boot card: 0x0, io_card 2
[    4.445240] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    4.457974] sunxi_leds_fetch_sysconfig_para leds is not used in config
[    4.465334] =========script_get_err============
[    4.471024] usbcore: registered new interface driver usbhid
[    4.477398] usbhid: USB HID core driver
[    4.481767] zram: num_devices not specified. Using default: 1
[    4.488331] zram: Creating 1 devices ...
[    4.493382] Linux telephony interface: v1.00
[    4.498508] usbcore: registered new interface driver snd-usb-audio
[    4.505752] Enter ac108_init
[    4.509078] ac108_i2c_detect:---1492, adapter-nr = 0
[    4.514601] ac108_i2c_detect:---1492, adapter-nr = 0
[    4.520323] ac108_i2c_detect:---1492, adapter-nr = 1
[    4.526671] ac108_i2c_probe ,line:1417
[    4.531367] get ac108 regulator name failed
[    4.536202] i2c_id->driver_data : 0
[    4.540368] ac108_i2c_probe,line:1447
[    4.553510] ac108_i2c_detect:---1492, adapter-nr = 1
[    4.559452] ac108_i2c_probe ,line:1417
[    4.564201] get ac108 regulator name failed
[    4.569038] i2c_id->driver_data : 1
[    4.573109] ac108_i2c_probe,line:1447
[    4.586326] ac108_i2c_detect:---1492, adapter-nr = 2
[    4.591751] ac108_i2c_detect:---1492, adapter-nr = 2
[    4.598272] [ audio ] err:try to get audio_pa_en failed!
[    4.604580] pa en request gpio failed!
[    4.609030] [ audio ] err:try to get audio_linein_detect failed!
[    4.616704] set pa ctrl gpio output okpa ctrl = 357
[    4.622368] pa val = 0
[    4.625171] set aw87183 off ------
[    4.630379] codec_set_bias_level,line:2273, SND_SOC_BIAS_STANDBY
[    4.639794] asoc: codec-aif1 <-> sunxi-codec mapping ok
[    4.646063] asoc: codec-aif2 <-> sunxi-codec-aif2-dai mapping ok
[    4.653024] asoc: codec-aif3 <-> sunxi-codec-aif2-dai mapping ok
[    4.663821] asoc: ac108-pcm0 <-> i2s0 mapping ok
[    4.669654] u32 classifier
[    4.672877]     Actions configured
[    4.676751] Netfilter messages via NETLINK v0.30.
[    4.682091] nf_conntrack version 0.5.0 (1911 buckets, 7644 max)
[    4.689061] ctnetlink v0.93: registering with nfnetlink.
[    4.695092] IPVS: Registered protocols ()
[    4.699780] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[    4.708137] IPVS: Creating netns size=840 id=0
[    4.713306] IPVS: ipvs loaded.
[    4.716944] IPv4 over IPv4 tunneling driver
[    4.722140] gre: GRE over IPv4 demultiplexor driver
[    4.727746] ip_gre: GRE over IPv4 tunneling driver
[    4.733615] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.739844] TCP: cubic registered
[    4.743639] Initializing XFRM netlink socket
[    4.748493] NET: Registered protocol family 17
[    4.753642] NET: Registered protocol family 15
[    4.758796] Bluetooth: RFCOMM socket layer initialized
[    4.764702] Bluetooth: RFCOMM ver 1.11
[    4.768961] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.774964] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.782249] ThumbEE CPU extension supported.
[    4.787101] Registering SWP/SWPB emulation handler
[    4.793821] Crash dumper registered, size: 131072
[    4.799142] otg_wakelock_init: No USB transceiver found
[    4.805177] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:00:07 UTC (7)
[    4.813901] ths_fetch_sysconfig_para: type err  device_used = 1.
[    4.821282] sunxi_cpu_budget_vftable_init: support only one vf_table
[    4.828806] CPU Budget:Register notifier
[    4.833370] CPU Budget:register Success
[    4.837727] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    4.850353] =========GPS========= :gsp not used in configuration
[    4.857131] ALSA device list:
[    4.860632]   #0: sndcodec
[    4.863732]   #1: sndi2s0
[    5.102619] VFS: Mounted root (squashfs filesystem) readonly on device 93:32.
[    5.111054] Freeing init memory: 172K
[    5.291788] init: Console is alive
[    5.296210] init: - preinit -
[    5.330055] ====codec_init_events===
/dev/by-name/UDISK: UUID="ebe84aa4-ffad-4ea8-b0a4-9653c68486ac" [    5.665409] mount_root: mounting /dev/root
NAME="EXT_JOURNAL" VERSION="1.0"[    5.671344] mount_root: loading kmods from internal overlay
TYPE="ext4"
/dev/by-name/UDISK already format by ext4
[    5.769874] block: attempting to load /etc/config/fstab
[    5.821537] block: extroot: not configured
[    7.028511] procd: - early -
[    7.220148] procd: - ubus -
[    7.223842] procd (1): /proc/106/oom_adj is deprecated, please use /proc/106/oom_score_adj instead.
[    7.274158] procd: - init -
Please press Enter to activate this console.
[    7.413072] dhd_module_init: in Dongle Host Driver, version 1.201.59.15 (r506368)
[    7.413083] Compiled in drivers/net/wireless/bcmdhd on Jul 17 2018 at 05:01:58
[    7.429794] ======== dhd_wlan_init_plat_data ========
[    7.435729] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[    7.441404] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = 359
[    7.447626] dhd_wlan_init_gpio: host_oob_irq: 7
[    7.452855] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[    7.458973] dhd_wifi_platform_load: Enter
[    7.463614] Power-up adapter 'DHD generic adapter'
[    7.469151] wifi_platform_set_power = 1
[    7.473675] ======== PULL WL_REG_ON(-1) HIGH! ========
[    7.479508] [wifi_pm]: wifi power on
[    7.790060] wifi_platform_bus_enumerate device present 1
[    7.796070] ======== Card detection to detect SDIO card! ========
[    7.803102] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.814424] [mmc]: sdc1 power_supply is null
[    7.840084] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.872379] [mmc]: *** sunxi_mci_dump_errinfo(L923): smc 1 err, cmd 52,  RTO !!
[    7.881654] [mmc]: *** sunxi_mci_dump_errinfo(L923): smc 1 err, cmd 52,  RTO !!
[    7.890100] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.902996] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.915229] [mmc]: *** sunxi_mci_dump_errinfo(L923): smc 1 err, cmd 8,  RTO !!
[    7.923568] *******************Try sdio*******************
[    7.930225] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.950471] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    7.960890] [mmc]: sdc1 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    7.971520] [mmc]: sdc1 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    7.983533] mmc0: new high speed SDIO card at address 0001
[    7.990317] *******************sdio init ok*******************
[    8.006435] bcmsdh_register: register client driver
[    8.012090] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[    8.017667] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[    8.023104] bus num (host idx)=0, slot num (rca)=1
[    8.028528] found adapter info 'DHD generic adapter'
[    8.034281] sdioh_attach: set sd_f2_blocksize 128
[    8.039794] dhdsdio_probe : no mutex held. set lock
[    8.045517] F1 signature read @0x18000000=0x1541a9a6
[    8.053024] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[    8.061081] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[    8.068450] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[    8.074654] CFG80211-DEBUG) wl_cfg80211_attach :func c58dd608
[    8.081420] CFG80211-DEBUG) wl_setup_wiphy :Setting interface combinations for common mode
[    8.090930] CFG80211-DEBUG) wl_setup_wiphy :Registering custom regulatory)
[    8.098873] CFG80211-DEBUG) wl_setup_wiphy :Registering Vendor80211)
[    8.106549] CFG80211-DEBUG) wl_init_priv_mem :Enter
[    8.112424] CFG80211-DEBUG) wl_create_event_handler :Enter
[    8.118924] wl_create_event_handler(): thread:wl_event_handler:d5 started
[    8.118934] tsk Enter, tsk = 0xc4d21410
[    8.131029] CFG80211-DEBUG) wl_init_conf :Enter
[    8.136366] CFG80211-DEBUG) wl_link_down :In
[    8.141420] CFG80211-DEBUG) wl_setup_rfkill :Enter
[    8.147195] CFG80211-DEBUG) wl_rfkill_set :Enter
[    8.151880] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
[    8.151889] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
[    8.151897] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
[    8.151903] Going btcodex
[    8.151970] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
[    8.152419] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
[    8.152452] p2p0: P2P Interface Registered
[    8.196609] CFG80211-DEBUG) wl_rfkill_set :dhd_attach(): thread:dhd_watchdog_thread:d6 started
[    8.206522] RF unblocked
[    8.206539] dhd_attach(): thread:dhd_dpc:d7 started
[    8.215134] dhd_attach(): thread:dhd_rxf:d8 started
[    8.220711] dhd_deferred_work_init: work queue initialized
[    8.234445] Dongle Host Driver, version 1.201.59.15 (r506368)
[    8.234455] Compiled in drivers/net/wireless/bcmdhd on Jul 17 2018 at 05:01:58
[    8.249289] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
[    8.257101] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
[    8.264538] Register interface [wlan0]  MAC: 00:90:4c:11:22:33
[    8.264543]
[    8.272876] dhd_prot_ioctl : bus is down. we have nothing to do
[    8.279684] bcmsdh_oob_intr_unregister: Enter
[    8.284633] bcmsdh_oob_intr_unregister: irq is not registered
[    8.291223] dhd_txglom_enable: enable 0
[    8.295584] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0, txglom_bucket_size=0
[    8.304582] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[    8.313574] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[    8.322187] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=1
[    8.329821] sdioh_set_mode: set txglom_mode to multi-desc
[    8.335936] dhd_bus_devreset:  WLAN OFF DONE
[    8.340920] wifi_platform_set_power = 0
[    8.345284] ======== PULL WL_REG_ON(-1) LOW! ========
[    8.351013] [wifi_pm]: wifi power off
[    8.355274] dhdsdio_probe : the lock is released.
[    8.360693] dhd_module_init: Exit err=0
[    8.366014] =====ctp_fetch_sysconfig_para=====.
[    8.371283] ctp_fetch_sysconfig_para: ctp_power_ldo script_get_item err.
[    8.379014] ctp_fetch_sysconfig_para: ctp_power_ldo_vol script_get_item err.
[    8.387048] ctp_fetch_sysconfig_para: ctp_power_io script_get_item err.
[    8.394697] ctp_irq gpio number is 356
[    8.450197] i2c-core: driver [gt82x] using legacy suspend method
[    8.457070] i2c-core: driver [gt82x] using legacy resume method
[    8.463931] twi_start()434 - [i2c0] START can't sendout!
[    8.470294] twi_start()434 - [i2c0] START can't sendout!
[    8.476534] twi_start()434 - [i2c0] START can't sendout!
[    8.483600] twi_start()434 - [i2c0] START can't sendout!
[    8.489849] twi_start()434 - [i2c0] START can't sendout!
[    8.496164] twi_start()434 - [i2c0] START can't sendout!
[    8.502574] twi_start()434 - [i2c0] START can't sendout!
[    8.508847] twi_start()434 - [i2c0] START can't sendout!
[    8.515226] twi_start()434 - [i2c0] START can't sendout!
[    8.523905] xt_time: kernel timezone is -0000
[    8.610225] twi_start()434 - [i2c0] START can't sendout!
[    8.616501] twi_start()434 - [i2c0] START can't sendout!
[    8.622927] twi_start()434 - [i2c0] START can't sendout!
[    8.984170] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
[    8.991828] CFG80211-DEBUG) wl_cfg80211_netdev_notifier_call :Enter
crond[452]: crond (busybox 1.24.1) started, log level 5
all servers are OK
LED boot ok.
^C^CPlease press Enter to activate this console.
BusyBox v1.24.1 () built-in shell (ash)
  _____  _              __    __ __ ___ ___
|     ||_| ___  ___   |  |  |  |  |   |_  |
| | | || ||  _|| . |  |  |__|-   -| | |_| |_
|_|_|_||_||___||___|  |_____|__|__|___|_____|
Tina Linux (Neptune, 133)
imilab trunk version 0.5.6
 楼主| 发表于 2023-9-24 23:09:10 | 显示全部楼层
自己顶上去
 楼主| 发表于 2023-9-27 22:14:37 | 显示全部楼层
求救求救求救
 楼主| 发表于 2023-10-25 20:43:36 | 显示全部楼层
 楼主| 发表于 2023-10-25 21:00:35 | 显示全部楼层
[  163.070455] CONFIG-ERROR) dhd_conf_set_intiovar: force_wme_ac setting failed -23
[  181.107372] CONFIG-ERROR) dhd_conf_set_intiovar: force_wme_ac setting failed -23
[  183.656888] CONFIG-ERROR) dhd_conf_set_intiovar: force_wme_ac setting failed -23
有哪位大神解释一下, 这个是什么故障
GMT+8, 2025-12-18 14:09 , Processed in 0.075382 second(s), 8 queries , MemCached On.
