查看: 3641|回复: 4
[硬件DIY] esp8266接门禁开关,烦请大佬检查一下
发表于 2023-9-19 21:13:55 | 显示全部楼层 |阅读模式
用esp8266-01s连接门禁开门控制线,用于远程开门。目前功能正常,但实际使用还是担心出问题,烦请各位大佬查看一下代码是否正确。另外这个esp8266-01s继电器通电瞬间会跳动,有没有什么办法可以改善呢?
小白一枚,感谢各位
esphome:
  friendly_name: esp8266-1fdoor
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "***cx2HT+N/aJTp5NZuCwc1TCGkh4="
ota:
  password: "****68be26a"
wifi:
  ssid: "****"
  password: "****"
  power_save_mode: none
  manual_ip:
    static_ip: 192.168.2.32
    gateway: 192.168.2.1
    subnet: 255.255.255.0
    dns1: 192.168.2.1
    dns2: 223.5.5.5
  ap:
    ssid: "Esp8266-1Fdoor Fallback Hotspot"
    password: "****"
# Example configuration entry
web_server:
  port: 80
  auth:
    username: "root"
    password: "****"
captive_portal:
switch:
  - platform: gpio
    pin: 0
    icon: "mdi:gate"
    inverted: True
    on_turn_on:
    - delay: 100ms
    - switch.turn_off: relay
binary_sensor:
  - platform: gpio
    pin: GPIO2
    device_class: opening
    filters:
      - delayed_on_off: 100ms
    on_state:
      then:
        - switch.toggle: relay
发表于 2023-9-20 02:59:14 | 显示全部楼层
esp8266-01s继电器通电瞬间会跳动 要加個100uf的電容
 楼主| 发表于 2023-9-20 15:51:44 | 显示全部楼层
有详细的说明或图示吗?谢谢
发表于 2023-9-20 16:15:36 | 显示全部楼层
 楼主| 发表于 2023-9-21 21:18:44 | 显示全部楼层
george65 发表于 2023-9-20 16:15
https://www.arduino.cn/thread-99053-1-1.html
非常感谢
GMT+8, 2026-1-16 11:00 , Processed in 1.005015 second(s), 12 queries , MemCached On.
