查看: 2964|回复: 4
[求助] nodered报错
发表于 2023-9-19 09:54:13 | 显示全部楼层 |阅读模式
不知道从什么时候开始,nodered的调试信息栏一直弹报错信息
"Deprecated API warning: Calls to RED.util.evaluateJSONataExpression must include a callback. This will not be optional in Node-RED 4.0. Please identify the node from the following stack and check for an update on npm. If none is available, please notify the node author."
Error:
    at Object.evaluateJSONataExpression (/opt/node_modules/@node-red/util/lib/util.js:775:18)
    at JSONataService.evaluate (/config/node-red/node_modules/node-red-contrib-home-assistant-websocket/dist/common/services/JSONataService.js:58:39)
    at TypedInputService.getValue (/config/node-red/node_modules/node-red-contrib-home-assistant-websocket/dist/common/services/TypedInputService.js:58:85)
    at EventsState.getTypedInputValue (/config/node-red/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:134:39)
    at /config/node-red/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:138:32
    at Array.forEach (<anonymous>)
    at EventsState.setCustomOutputs (/config/node-red/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:137:20)
    at EventsState.output (/config/node-red/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/events-state/controller.js:121:18)
    at EventsState.on...
安装方式是通过ha里的加载项安装,应该是更新到最新的
有大佬知道怎么处理吗?
报错信息
报错信息
ha版本
ha版本
nodered版本
nodered版本
HomeAssistant
发表于 2023-9-19 10:01:34 | 显示全部楼层
新版本bug,haos的话,还原到上一个版本吧
 楼主| 发表于 2023-9-19 10:10:26 | 显示全部楼层
armbian里docker装的ha
HomeAssistant
发表于 2023-9-19 10:25:17 | 显示全部楼层
893213 发表于 2023-9-19 10:10
armbian里docker装的ha
https://bbs.hassbian.com/thread-22753-1-1.html  大佬有分享解决方法,不过我直接还原的上一个版本。加载项是可以还原的,配置-系统-备份,然后找到addon_xxx_nodered_14.4.5, 选中后点击RESTORE就行了
 楼主| 发表于 2023-9-19 10:33:11 | 显示全部楼层
DDDear 发表于 2023-9-19 10:25
https://bbs.hassbian.com/thread-22753-1-1.html  大佬有分享解决方法,不过我直接还原的上一个版本。加 ...
感谢指路
原来这个报错没影响吗,那我还是暂时不管了
GMT+8, 2025-12-16 15:39 , Processed in 1.061064 second(s), 13 queries , MemCached On.
