查看: 3667|回复: 4
[技术探讨] 小燕智能门锁支持 Homekit,请问可否反向接入 HA?
发表于 2023-9-7 16:42:18 | 显示全部楼层 |阅读模式
目前家用小燕门锁可以添加进homekit内,但联动功能太少而且时灵时不灵,请问可否反向加入进homeassistant内。之前试过HA内homekit的插件发现不了门锁设备,不知道是不是和门锁没有联网有关,请大神们支招一下,谢谢
AriY
发表于 2023-9-7 19:51:08 | 显示全部楼层
马克一下
发表于 2023-9-8 09:47:49 | 显示全部楼层
HA的插件发现不了是因为没有实现接入门锁设备
可以的话,把日志贴上来,我看看能不能加一下
在 /config/configuration.yaml 加上这段,重启HA,打开日志
logger:
  default: warning
  logs:
    custom_components.terncy: debug
 楼主| 发表于 2023-9-12 15:33:22 | 显示全部楼层
2023-09-12 07:20:51.132 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration conversation_assistant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:20:51.136 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:20:51.141 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration gree2 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:20:51.146 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:20:51.151 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration ha_file_explorer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:20:51.155 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration beoplay which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:20:51.159 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:20:51.163 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration terncy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:20:51.168 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration colorfulclouds which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-09-12 07:21:03.103 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-09-12 07:21:03.637 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=60 from 2023-09-10 12:23:31.605317)
2023-09-12 07:22:18.460 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: xiaomi_miot
2023-09-12 07:23:18.628 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: xiaomi_miot
2023-09-12 07:24:18.725 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: xiaomi_miot
2023-09-12 07:25:18.845 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: xiaomi_miot
请问是这样贴么
发表于 2023-9-12 17:03:22 | 显示全部楼层
lee233 发表于 2023-9-12 15:33
2023-09-12 07:20:51.132 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integratio ...
是的,还有更后面一点的吗?先确保 configuration.yaml 里加上了logger
GMT+8, 2026-1-16 11:00 , Processed in 0.765994 second(s), 13 queries , MemCached On.
