查看: 2737|回复: 1
[求助] ha接入巴法的mqtt,configuration.yaml出错。
发表于 2023-8-28 02:13:22 | 显示全部楼层 |阅读模式
以下是我的mqtt的配置,但是一直报错,请问具体原因是什么?
# mqtt服务设置
mqtt:
  broker: bemfa.com
  port: 9501
  #客户端ID
  client_id: 45331dce8c00477ebbecb3986c35997a
  # 心跳设置
  keepalive: 60
报错信息如下:
重新启动 Home Assistant 失败
[color=var(--primary-text-color)]The system cannot restart because the configuration is not valid: Invalid config for [mqtt]: The 'broker' option near /config/configuration.yaml:21 has been removed, please remove it from your configuration for dictionary value @ data['mqtt']. Got {'broker': 'bemfa.com', 'port': 9501, 'client_id': '45331dce8c00477ebbecb3986c35997b', 'keepalive': 60}. (See /config/configuration.yaml, line 21).
我参照的是巴法提供的文档写的自己的配置,原文件地址如下:https://bemfa.blog.csdn.net/arti ... G91ZC5iZW1mYS5jb20v
发表于 2023-8-28 14:21:23 | 显示全部楼层
https://blog.csdn.net/weixin_45211901/article/details/130451277
我也是升级后就不能使用了,官方改了mqtt的使用规则,门前网上就看见这篇文章
GMT+8, 2025-12-16 23:19 , Processed in 0.536630 second(s), 6 queries , MemCached On.
