查看: 7201|回复: 9
[技术探讨] (已解决)Docker版HA Supervisor官方已放弃?不再更新?
发表于 2023-8-25 22:36:20 | 显示全部楼层 |阅读模式
我用的主机是N1,使用docker的方式安装的HA supervisor,现在HA官方已经把HAOS和supervisor更新到2023.08.1了,但是docker版一直未更新,supervisor最新版依然是老版本2023.06,官方2个多月未更新docker版supervisor了
发表于 2023-8-25 22:44:38 | 显示全部楼层
还想着转成docker的
 楼主| 发表于 2023-8-25 22:53:42 | 显示全部楼层
我在github上转了一圈,发现同样有人发现这个问题了,但作者并未明确答复,只说了参阅2023.7的发行说明,我跟提问者一样一头雾水,发行说明中并未提及为什么不更新docker镜像的原因
发表于 2023-8-26 06:02:27 | 显示全部楼层
现在更新在ghcr.io上,不在hub.docker上
参与人数 1金钱 +10 收起 理由
623305170 + 10 高手,这是高手!
发表于 2023-8-26 06:09:15 | 显示全部楼层
https://www.home-assistant.io/bl ... 7/#breaking-changes
Home Assistant Container (Docker)
If you use the Home Assistant Container installation method, for example, using Docker, please make sure you are using our official (multi-platform) images.
The correct and preferred image to use for our stable releases is:
ghcr.io/home-assistant/home-assistant:stable
Although not the preferred location by the Home Assistant project, the image is also available on DockerHub:
homeassistant/home-assistant:stable
The reason for mentioning this in this breaking change section is that we have seen usage of our internal, intermediate, platform build images. These images are not meant for use directly, and using the above listed images is strongly recommended.
As of this release, we no longer publish our intermediate platform images to DockerHub. This means that if you are using these images, you will no longer receive updates. Please use the above-listed images instead.
 楼主| 发表于 2023-8-26 17:27:22 | 显示全部楼层
感谢,已成功更新
发表于 2023-9-8 22:23:08 | 显示全部楼层
你好,楼主,我也是N1,能分享一下拉取代码吗?
发表于 2023-9-10 20:53:59 | 显示全部楼层
对的 ,但是ghcr.io 的拉取速度真的一言难尽
发表于 2023-9-10 20:56:35 | 显示全部楼层
docker pull ghcr.io/home-assistant/qemux86-64-homeassistant:2023.9.0
docker pull ghcr.io/home-assistant/amd64-hassio-supervisor:2023.08.3
我这是x86 的 你自己改一下
发表于 2023-9-10 22:48:12 | 显示全部楼层
docker pull ghcr.io/home-assi ...
好的,非常感谢!!
GMT+8, 2026-1-16 14:20 , Processed in 0.612236 second(s), 9 queries , MemCached On.
