查看: 1841|回复: 8
[求助] 使用hyper-v安装,出现问题求大老解答
发表于 2023-8-23 15:15:01 | 显示全部楼层 |阅读模式
在Windows10上使用hyper-v安装homeassistant,使用官方github的镜像安装,在启动页点击蓝色圈圈看日志,一直卡主一个地方,也没有报错,已经一个多小时了
[05:45:10] INFO: Using udev information from host
[05:45:11] INFO: Starting local supervisor watchdog...
23-08-23 05:45:23 INFO (MainThread) [__main__] Initializing Supervisor setup
23-08-23 05:45:23 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-08-23 05:45:25 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-08-23 05:45:25 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.08.1
23-08-23 05:45:25 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-08-23 05:45:27 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-08-23 05:45:27 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 05:45:27 INFO (MainThread) [__main__] Setting up Supervisor
23-08-23 05:45:29 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-08-23 05:45:29 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-08-23 05:45:29 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-08-23 05:45:30 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-23 05:45:30 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-23 05:45:31 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-23 05:45:32 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-08-23 13:45:33 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-08-23 13:45:33 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-08-23 13:45:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0
23-08-23 13:45:33 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-08-23 13:45:38 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0 - 172.30.32.5
23-08-23 13:45:38 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-08-23 13:45:38 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-08-23 13:45:39 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-08-23 13:45:44 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-08-23 13:45:44 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-08-23 13:45:44 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-08-23 13:45:44 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0
23-08-23 13:45:45 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-08-23 13:45:50 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0 - 172.30.32.4
23-08-23 13:45:50 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-08-23 13:45:50 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-08-23 13:45:52 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-08-23 13:45:57 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-08-23 13:45:57 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-08-23 13:45:57 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-08-23 13:45:58 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-08-23 13:46:02 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-08-23 13:46:02 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-08-23 13:46:03 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-08-23 13:46:04 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
23-08-23 13:46:04 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
23-08-23 13:46:04 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-08-23 13:46:04 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-08-23 13:46:04 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-08-23 13:46:05 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-08-23 13:46:08 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-08-23 13:46:08 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 10.5 / BootSlot A
23-08-23 13:46:08 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-08-23 13:46:08 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-08-23 13:46:08 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-08-23 13:46:14 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Could not resolve host: github.com
23-08-23 13:46:14 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / a0d7b954
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
23-08-23 13:46:14 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': Could not resolve host: github.com
23-08-23 13:46:14 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 5c53de3b
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
23-08-23 13:46:14 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': Could not resolve host: github.com
23-08-23 13:46:14 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
23-08-23 13:46:14 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-08-23 13:46:14 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-08-23 13:46:14 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-08-23 13:46:14 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-08-23 13:46:14 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 13:46:14 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-08-23 13:46:14 INFO (MainThread) [__main__] Running Supervisor
23-08-23 13:46:14 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-08-23 13:46:14 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-08-23 13:46:14 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-08-23 13:46:14 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-08-23 13:46:14 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-08-23 13:46:14 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-08-23 13:46:14 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-08-23 13:46:14 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-08-23 13:46:14 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-08-23 13:46:14 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.8.3
23-08-23 13:46:14 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.8.3.
23-08-23 13:46:14 INFO (MainThread) [supervisor.host.info] Updating local host information
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-23 13:46:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-23 13:46:14 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-23 13:46:14 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-23 13:46:15 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-23 13:46:15 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.DNS_SERVER_IPV6_ERROR - ContextType.DNS_SERVER / dns://192.169.0.1
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 13:46:22 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-23 13:46:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 13:46:23 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-23 13:46:23 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
s6-rc: info: service legacy-services: stopping
[06:07:19] INFO: Watchdog restart after closing
23-08-23 14:07:19 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
23-08-23 14:07:19 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
23-08-23 14:07:19 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
23-08-23 14:07:19 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
23-08-23 14:07:19 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
23-08-23 14:07:19 INFO (MainThread) [supervisor.core] Supervisor is down - 0
23-08-23 14:07:19 ERROR (MainThread) [asyncio] Task was destroyed but it is pending!
task: <Task pending name='Task-519' coro=<HomeAssistantWebSocket._process_queue() running at /usr/src/supervisor/supervisor/homeassistant/websocket.py:186>>
/usr/local/lib/python3.11/asyncio/base_events.py:678: RuntimeWarning: coroutine 'HomeAssistantWebSocket._process_queue' was never awaited
self._ready.clear()
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
23-08-23 14:07:19 INFO (MainThread) [__main__] Closing Supervisor
s6-svwait: fatal: timed out
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[06:08:59] INFO: Using udev information from host
[06:08:59] INFO: Starting local supervisor watchdog...
23-08-23 06:09:08 INFO (MainThread) [__main__] Initializing Supervisor setup
23-08-23 14:09:08 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-08-23 14:09:08 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.08.1
23-08-23 14:09:08 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-08-23 14:09:08 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 14:09:08 INFO (MainThread) [__main__] Setting up Supervisor
23-08-23 14:09:10 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-08-23 14:09:10 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-08-23 14:09:10 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-08-23 14:09:10 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-23 14:09:10 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-23 14:09:13 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-23 14:09:13 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-08-23 14:09:13 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-08-23 14:09:13 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0
23-08-23 14:09:13 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-08-23 14:09:13 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_cli application
23-08-23 14:09:17 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0 - 172.30.32.5
23-08-23 14:09:17 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-08-23 14:09:17 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-08-23 14:09:17 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
23-08-23 14:09:23 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-08-23 14:09:23 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-08-23 14:09:23 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0
23-08-23 14:09:24 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-08-23 14:09:24 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_audio application
23-08-23 14:09:28 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0 - 172.30.32.4
23-08-23 14:09:28 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-08-23 14:09:28 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-08-23 14:09:29 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-08-23 14:09:29 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
23-08-23 14:09:33 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-08-23 14:09:33 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-08-23 14:09:34 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-08-23 14:09:34 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-08-23 14:09:35 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-08-23 14:09:35 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-08-23 14:09:35 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning homeassistant application
23-08-23 14:09:37 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-08-23 14:09:37 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 10.5 / BootSlot A
23-08-23 14:09:37 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-08-23 14:09:37 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-08-23 14:09:37 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-08-23 14:09:43 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
23-08-23 14:09:43 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / a0d7b954
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
23-08-23 14:09:43 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
23-08-23 14:09:43 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 5c53de3b
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
23-08-23 14:09:43 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
23-08-23 14:09:43 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
23-08-23 14:09:43 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-08-23 14:09:43 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-08-23 14:09:43 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-08-23 14:09:43 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-08-23 14:09:43 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 14:09:43 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-08-23 14:09:43 INFO (MainThread) [__main__] Running Supervisor
23-08-23 14:09:43 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-08-23 14:09:43 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-08-23 14:09:43 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-08-23 14:09:43 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-08-23 14:09:43 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-08-23 14:09:43 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-08-23 14:09:43 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-08-23 14:09:43 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-08-23 14:09:43 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-08-23 14:09:43 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.8.3
23-08-23 14:09:43 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.8.3.
23-08-23 14:09:43 INFO (MainThread) [supervisor.host.info] Updating local host information
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-23 14:09:43 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-23 14:09:43 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-23 14:09:43 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-23 14:09:43 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-23 14:09:43 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.DNS_SERVER_IPV6_ERROR - ContextType.DNS_SERVER / dns://192.169.0.1
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-23 14:09:44 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
[06:31:45] INFO: Using udev information from host
[06:31:45] INFO: Starting local supervisor watchdog...
23-08-23 06:31:52 INFO (MainThread) [__main__] Initializing Supervisor setup
23-08-23 14:31:53 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-08-23 14:31:53 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.08.1
23-08-23 14:31:53 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-08-23 14:31:53 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 14:31:53 INFO (MainThread) [__main__] Setting up Supervisor
23-08-23 14:31:55 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-08-23 14:31:55 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-08-23 14:31:55 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-08-23 14:31:55 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-23 14:31:55 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-23 14:31:56 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-23 14:31:56 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-08-23 14:31:56 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-08-23 14:31:56 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0
23-08-23 14:31:56 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-08-23 14:31:56 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_cli application
23-08-23 14:32:00 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0 - 172.30.32.5
23-08-23 14:32:00 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-08-23 14:32:00 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-08-23 14:32:00 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
23-08-23 14:32:07 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-08-23 14:32:07 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-08-23 14:32:07 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0
23-08-23 14:32:07 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-08-23 14:32:08 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_audio application
23-08-23 14:32:12 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0 - 172.30.32.4
23-08-23 14:32:12 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-08-23 14:32:13 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-08-23 14:32:13 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-08-23 14:32:13 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_multicast application
23-08-23 14:32:17 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-08-23 14:32:17 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-08-23 14:32:19 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-08-23 14:32:19 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-08-23 14:32:19 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-08-23 14:32:20 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-08-23 14:32:20 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning homeassistant application
23-08-23 14:32:22 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-08-23 14:32:22 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 10.5 / BootSlot A
23-08-23 14:32:22 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-08-23 14:32:22 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-08-23 14:32:22 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-08-23 14:32:27 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
23-08-23 14:32:27 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / a0d7b954
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
23-08-23 14:32:27 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
23-08-23 14:32:27 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 5c53de3b
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
23-08-23 14:32:27 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
23-08-23 14:32:27 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
23-08-23 14:32:27 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-08-23 14:32:27 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-08-23 14:32:27 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-08-23 14:32:27 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-08-23 14:32:27 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-08-23 14:32:27 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 14:32:27 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-08-23 14:32:27 INFO (MainThread) [__main__] Running Supervisor
23-08-23 14:32:28 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-08-23 14:32:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-08-23 14:32:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-08-23 14:32:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-08-23 14:32:28 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-08-23 14:32:28 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-08-23 14:32:28 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-08-23 14:32:28 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-08-23 14:32:28 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-08-23 14:32:28 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.8.3
23-08-23 14:32:28 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.8.3.
23-08-23 14:32:28 INFO (MainThread) [supervisor.host.info] Updating local host information
23-08-23 14:32:28 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-23 14:32:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-23 14:32:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-23 14:32:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-23 14:32:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-23 14:32:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-23 14:32:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-23 14:32:28 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-23 14:32:28 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-23 14:32:28 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-23 14:32:28 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.DNS_SERVER_IPV6_ERROR - ContextType.DNS_SERVER / dns://192.169.0.1
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-23 14:32:32 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
mitu 手机认证
发表于 2023-8-23 15:38:42 | 显示全部楼层
文明上网,科学上网。
 楼主| 发表于 2023-8-23 15:43:42 | 显示全部楼层
mitu 发表于 2023-8-23 15:38
文明上网,科学上网。
已经开clash了...
发表于 2023-8-23 15:55:23 | 显示全部楼层
hyper-v是虚拟机,为什么不用虚拟机安装
 楼主| 发表于 2023-8-23 16:07:42 | 显示全部楼层
您指的是docker嘛?
发表于 2023-8-23 16:11:59 | 显示全部楼层
lxy666 发表于 2023-8-23 16:07
您指的是docker嘛?
docker是docker,虚拟机是虚拟机
 楼主| 发表于 2023-8-23 16:15:06 | 显示全部楼层
基本就是这几行再重复
self._ready.clear()
23-08-23 15:32:27 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-23 15:32:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-23 15:32:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-23 15:32:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-23 15:32:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-23 15:32:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-23 15:32:30 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-08-23 16:32:29 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-08-23 16:32:30 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-23 16:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-23 16:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-23 16:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-23 16:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-23 16:32:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-23 16:32:33 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-08-23 16:39:08 INFO (MainThread) [supervisor.host.info] Updating local host information
23-08-23 16:39:08 INFO (MainThread) [supervisor.host.services] Updating service information
23-08-23 16:39:08 INFO (MainThread) [supervisor.host.network] Updating local network information
23-08-23 16:39:08 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-08-23 16:39:08 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-08-23 16:10:19 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-08-23 16:10:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-08-23 16:10:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-08-23 16:10:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-08-23 16:10:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-08-23 16:10:19 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DOCKER_CONFIG/ContextType.SYSTEM
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-08-23 16:10:20 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
 楼主| 发表于 2023-8-23 16:30:13 | 显示全部楼层
那是vm?
 楼主| 发表于 2023-8-24 13:51:00 | 显示全部楼层
下载10.2镜像安装后可以正常打开了。
10.5还是不行
GMT+8, 2025-12-16 15:39 , Processed in 1.273762 second(s), 11 queries , MemCached On.
