查看: 9547|回复: 19
[技术讨论] ESPHome 2023.8.0更新支持 LD2410人体存在
发表于 2023-8-22 23:25:15 | 显示全部楼层 |阅读模式
ESPHome 2023.8.0 - 16th August 2023LD2410
The LD2410 component has had a massive upgrade thanks to @regevbr! It now supports settings most if not all configuration parameters via switches / numbers and selects and exposes more data via various sensors. This includes breaking changes that mean the existing gate configuration options have been moved to the number platform.
该传感器允许您使用LD2410传感器执行不同的测量。ld2410
这下方便使用
为了校准您的传感器,请执行以下操作:ld2410
  • 启用工程模式
  • 监控gX_move_energy和gX_still_energy 传感器
  • 更改阈值并重复步骤 2,直到满意为止。
  • 禁用工程模式
number:
  - platform: ld2410
    timeout:
    light_threshold:
      name: light threshold
    max_move_distance_gate:
      name: max move distance gate
    max_still_distance_gate:
      name: max still distance gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
  - platform: ld2410
    light:
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
esp8266 D1开发板简单实例
esphome:
  friendly_name: LD2410-D1
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "2YFuHY0XtEzld9q4WIcwkKRbGF2Tg15sR6ikHCA="
ota:
  password: "846afe79f95f0d951b42bd7c1f2b2d8c"
# Example configuration entry
mqtt:
  broker: 192.168.2.1
  username: mqtt
  password: mqtt
wifi:
  ssid: "mqtt"
  password: "mqtt"
  ap:
    ssid: "Ld2410-D1 Fallback Hotspot"
    password: "kp1KoFJe4QZO"
uart:
  tx_pin: GPIO1   #使用D1 mini RX
  rx_pin: GPIO3   #使用D1 mini TX
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
number:
  - platform: ld2410
    timeout:
    light_threshold:
    g0:
      move_threshold:
      still_threshold:
    g1:
      move_threshold:
      still_threshold:
    g2:
      move_threshold:
      still_threshold:
    g3:
      move_threshold:
      still_threshold:
    g4:
      move_threshold:
      still_threshold:
    g5:
      move_threshold:
      still_threshold:
    g6:
      move_threshold:
      still_threshold:
    g7:
      move_threshold:
      still_threshold:
    g8:
      move_threshold:
      still_threshold:
  - platform: ld2410
    light:
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
      still_energy:
    g1:
      move_energy:
      still_energy:
    g2:
      move_energy:
      still_energy:
    g3:
      move_energy:
      still_energy:
    g4:
      move_energy:
      still_energy:
    g5:
      move_energy:
      still_energy:
    g6:
      move_energy:
      still_energy:
    g7:
      move_energy:
      still_energy:
    g8:
      move_energy:
      still_energy:
  - platform: dht
    pin: GPIO2   #使用D1 mini D4针脚
    temperature:
      name: "Living Room Temperature"
    humidity:
      name: "Living Room Humidity"
    update_interval: 60s
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
    out_pin_presence_status:
      name: out pin presence status
学习摸索阶段不对之处还请指正
esphome的操作步骤这个写的详细;https://blog.csdn.net/qq_31400983/article/details/129054636
参与人数 2金钱 +11 收起 理由
tomsunday + 1
隔壁的王叔叔 + 10
发表于 2023-8-23 08:37:21 | 显示全部楼层
太感谢了,正需要这个,用以前的配值文件最新版esphome报错
发表于 2023-8-23 09:10:48 | 显示全部楼层
感谢,回头试试
发表于 2023-8-23 11:37:10 | 显示全部楼层
连接TX和RX,VCC和GND也需要连接吧?
请教大佬接入homeassistant之后,都显示未知是什么问题?
 楼主| 发表于 2023-8-23 18:30:13 | 显示全部楼层
vcc 你看下ld2140 是3.3v 还是 5V 有没接错 ,多刷一次覆盖一下呢,我 这个刷了后这几天观察 感觉有些不稳定 经常掉线 ,我正在用esp32-c3合宙板尝试看稳定不。
发表于 2023-8-23 18:32:47 | 显示全部楼层
敬轩 发表于 2023-8-23 18:30
vcc 你看下ld2140 是3.3v 还是 5V 有没接错 ,多刷一次覆盖一下呢,我 这个刷了后这几天观察 感觉有些不 ...
确实是5v,用他们海凌科调试的app各个参数没有问题,不行我也换一个板子试试
发表于 2023-8-23 19:36:22 | 显示全部楼层
silas3082 发表于 2023-8-23 18:32
确实是5v,用他们海凌科调试的app各个参数没有问题,不行我也换一个板子试试 ...
我换了nodemcu数据就出来没问题了
发表于 2023-8-24 17:41:38 | 显示全部楼层
不好用,而且接uart口后,数据量剧增
发表于 2023-8-26 09:19:59 | 显示全部楼层
sxrcm 发表于 2023-8-24 17:41
不好用,而且接uart口后,数据量剧增
有数据了,但是存在状态时断时续的
发表于 2023-8-27 17:31:09 | 显示全部楼层
看不懂怎么弄,大佬有没有适合新手的教程
GMT+8, 2026-1-20 22:02 , Processed in 0.091076 second(s), 15 queries , MemCached On.
