查看: 3298|回复: 3
[技术探讨] 求助esphome
发表于 2023-8-15 20:01:50 | 显示全部楼层 |阅读模式
esphome esphome_config/ dashboard的时候无法打开配置页面,一直卡住,请问这个怎么解决啊
(base) C:\Users\Administrator>esphome esphome_config/ dashboard
2023-08-15 19:55:53,115 WARNING Calling ESPHome with the configuration before the command is deprecated and will be removed in the future.
2023-08-15 19:55:53,115 WARNING Please instead use:
2023-08-15 19:55:53,115 WARNING    esphome dashboard esphome_config/
2023-08-15 19:55:53,260 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir esphome_config/...
发表于 2023-8-15 21:34:19 | 显示全部楼层
是在windows上本机部署的吗?如果是的话尝试一下http://127.0.0.1:6052
 楼主| 发表于 2023-8-15 21:51:18 | 显示全部楼层
谢谢大佬,可以了
Awe7 手机认证
发表于 2023-8-17 23:18:56 | 显示全部楼层
我想问问esphome pwm默认是占空比可变固定频率的,如何让它固定占空比50,频率可调呢?50hz--700hz
GMT+8, 2025-12-24 04:20 , Processed in 0.358539 second(s), 12 queries , MemCached On.
