楼主: bugensui
[技术探讨] esphome红外遥控接收到的编码很长并且每次都不一样?
 楼主| 发表于 2023-9-7 11:26:08 | 显示全部楼层
gky008 发表于 2023-9-7 11:12
大佬,求分享esphome红外接收发射红外遥控器的详细配置
你首先要配置好esphome的固件,然后客户在设备的web界面,可以直接接收编码的,然后调用服务就可以发送编码了
发表于 2023-9-7 11:41:38 | 显示全部楼层
bugensui 发表于 2023-9-7 11:26
你首先要配置好esphome的固件,然后客户在设备的web界面,可以直接接收编码的,然后调用服务就可以发送编 ...
对啊,就是求esphome的配置文件
 楼主| 发表于 2023-9-7 12:40:09 | 显示全部楼层
gky008 发表于 2023-9-7 11:41
对啊,就是求esphome的配置文件
esphome:
  friendly_name: ufo-r1
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  services:
    - service: send_raw_command
      variables:
        command: int[]
      then:
        - remote_transmitter.transmit_raw:
            code: !lambda 'return command;'
            carrier_frequency: 38kHz
    - service: send_nec_command
      variables:
        address: int
        command: int
      then:
        - remote_transmitter.transmit_nec:
            address: !lambda 'return address;'
            command: !lambda 'return command;'
    - service: send_samsung_command
      variables:
        command: string
      then:
        - remote_transmitter.transmit_samsung:
            data: !lambda 'return strtoll(command.c_str(), NULL, 16);'
ota:
  password: "5*****************************8"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Ufo-R1"
    password: "********"
button:
  - platform: template
    icon: "mdi:power-standby"
    on_press:
          code: [4503, -4495, 555, -557, 574, -1684, 552, -1685, 579, -1685, 553, -578, 549, -558, 575, -555, 550, -581, 555, -577, 550, -1686, 550, -1713, 550, -1686, 552, -581, 550, -582, 549, -555, 577, -555, 551, -581, 549, -581, 550, -1686, 553, -1711, 549, -555, 579, -554, 549, -582, 549, -583, 551, -1684, 577, -1685, 549, -558, 576, -555, 575, -1687, 553, -1683, 577, -1687, 547, -1690, 576]  #这个code改成自己识别到的raw码
    icon: "mdi:volume-plus"
    on_press:
          data: 0x707028D7
          nbits: 32
    icon: "mdi:volume-minus"
    on_press:
          data: 0x7070A857
          nbits: 32
switch:
  - platform: gpio
    pin: GPIO4  #D4
    icon: "mdi:lightbulb"
web_server:
  port: 80
captive_portal:
remote_receiver:
  pin:
    number: GPIO5
    inverted: true
    mode: INPUT_PULLUP
  dump: all
  idle: 80ms
remote_transmitter:
  pin: GPIO14
  carrier_duty_percent: 50%
GMT+8, 2026-1-16 14:16 , Processed in 0.582272 second(s), 5 queries , MemCached On.
