查看: 4178|回复: 4
[UI界面] 使用mushroom配置的dashboard
发表于 2023-8-14 16:55:33 | 显示全部楼层 |阅读模式
参考https://bbs.hassbian.com/thread-19349-1-1.html做的mushroom,请指教:
小米10浏览效果:
card情况:
battery-state-card
better-thermostat-ui-card
button-card
light-entity-card
lovelace-colorfulclouds-weather-card
lovelace-layout-card
mini-graph-card
stack-in-card
vertical-stack-in-card
code 实例:
type: custom:vertical-stack-in-card
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      margin: '-15px 0px 0px 0px;'
    cards:
      - type: custom:mushroom-title-card
        title: |-
          {% set time = now().hour %}
          {% if (time >= 18) %}
           Good  Evening!
          {% elif (time >= 12) %}
           Good Afternoon!
          {% elif (time >= 5) %}
           Good Morning!
          {% else %}
           Hello!
          {% endif %}
        subtitle: ''
        layout:
          margin: '-20px 0px -10px 0px;'
        cards:
          - type: custom:weather-card
            entity: weather.colorfulclouds
            number_of_forecasts: '5'
            details: false
            hourly_forecast: false
    layout:
      margin: 4px 0px 0px 0px;
    cards:
      - type: horizontal-stack
        cards:
          - type: custom:vertical-stack-in-card
            cards:
              - type: custom:mushroom-template-card
                entity: sensor.miaomiaoce_t2_17f7_temperature_humidity_sensor
                primary: 室内温度
                secondary: >
                  states('sensor.miaomiaoce_t2_17f7_temperature_humidity_sensor')
                  | round(0) }}°C
                icon: mdi:thermometer
                icon_color: green
                tap_action:
                  action: more-info
                layout_type: masonry
                layout:
                  width: 106
                  max_cols: 1
                  height: auto
                  padding: 0px
                  card_margin: var(--masonry-view-card-margin, -10px 8px 15px)
                cards:
                  - type: custom:mini-graph-card
                    entities:
                      - entity: sensor.miaomiaoce_t2_17f7_temperature_humidity_sensor
                        color: '#00bb33'
                    hours_to_show: 24
                    line_width: 3
                    animate: true
                    show:
                      icon: false
                      state: false
                      legend: false
                      fill: fade
                    card_mod:
                      style: |
                        ha-card {
                          background: none;
                          box-shadow: none;
                          --ha-card-border-width: 0;
            cards:
                entity: sensor.miaomiaoce_t2_17f7_relative_humidity
                primary: 室内湿度
                secondary: >
                  {{ states('sensor.miaomiaoce_t2_17f7_relative_humidity') |
                  round(0) }}%
                icon: mdi:water-percent
                icon_color: blue
                tap_action:
                  action: more-info
                layout:
                  width: 106
                  max_cols: 1
                  height: auto
                  padding: 0px
                cards:
                    entities:
                      - entity: sensor.miaomiaoce_t2_17f7_relative_humidity
                        color: '#2196f3'
                    hours_to_show: 24
                    line_width: 3
                    animate: true
                    show:
                      icon: false
                      state: false
                      legend: false
                      fill: fade
                    card_mod:
                      style: |
                        ha-card {
                          background: none;
                          box-shadow: none;
首页的空调code:
cards:
    layout:
      margin: 0px 0px 0px 0px;
    cards:
        title: Devices
        subtitle: ''
        layout:
          margin: '-20px 0px 0px 0px;'
        cards:
          - type: vertical-stack
            cards:
                cards:
                  - type: custom:mushroom-climate-card
                    entity: climate.lumi_mcn02_56bd_air_conditioner
                    hvac_modes:
                      - heat_cool
                      - heat
                      - cool
                      - fan_only
                      - dry
                    show_temperature_control: true
                    collapsible_controls: false
                    card_mod:
                      style: |
                        mushroom-shape-icon {
                          {% if is_state(config.entity, 'heat_cool') %}
                            --card-mod-icon: mdi:autorenew;
                            animation: spin 3s ease-in-out infinite alternate;
                          {% elif is_state(config.entity, 'heat') %}
                            --card-mod-icon: mdi:fire;
                            animation: heat 2s infinite;
                          {% elif is_state(config.entity, 'cool') %}
                            --card-mod-icon: mdi:snowflake;
                            animation: cool 6s ease-in-out infinite;
                          {% elif is_state(config.entity, 'dry') %}
                            --card-mod-icon: mdi:water-percent;
                            animation: dry 1.5s linear infinite;
                          {% elif is_state(config.entity, 'fan_only') %}
                            --card-mod-icon: mdi:fan;
                            animation: spin 1s linear infinite;
                          {% else %}
                            --card-mod-icon: mdi:air-conditioner;
                          {% endif %}
                          display: flex;
                        @keyframes cool {
                          0%, 100% { transform: rotate(25deg); }
                          25% { transform: rotate(-25deg); }
                          50% { transform: rotate(50deg); }
                          75% { transform: rotate(-50deg); }
                        @keyframes heat {
                          0%, 100% { --icon-color: rgba(var(--rgb-red), 1); }
                          10%, 90% { --icon-color: rgba(var(--rgb-red), 0.8); }
                          20%, 80% { --icon-color: rgba(var(--rgb-red), 0.6); }
                          30%, 70% { --icon-color: rgba(var(--rgb-red), 0.4); }
                          40%, 60% { --icon-color: rgba(var(--rgb-red), 0.2); }
                          50% { --icon-color: rgba(var(--rgb-red), 0); }
                        @keyframes dry {
                          0%, 100% { --icon-symbol-size: 21px; }
                          10%, 90% { --icon-symbol-size: 22px; }
                          20%, 80% { --icon-symbol-size: 23px; }
                          30%, 70% { --icon-symbol-size: 24px; }
                          40%, 60% { --icon-symbol-size: 25px; }
                          50% { --icon-symbol-size: 26px; }
                entity: climate.xiaomi_mc8_2b84_air_conditioner
                hvac_modes:
                  - heat_cool
                  - heat
                  - cool
                  - fan_only
                  - dry
                card_mod:
                  style: |
                      {% else %}
                      {% endif %}
                      display: flex;
                    @keyframes cool {
                    @keyframes heat {
                    @keyframes dry {
                cards:
                    entity: climate.xiaomi_mc8_4f0f_air_conditioner
                    hvac_modes:
                      - heat_cool
                      - heat
                      - cool
                      - fan_only
                      - dry
                    card_mod:
                      style: |
                          {% else %}
                          {% endif %}
                          display: flex;
                        @keyframes cool {
                        @keyframes heat {
                        @keyframes dry {
                cards:
                    entity: climate.xiaomi_mc8_f42b_air_conditioner
                    hvac_modes:
                      - heat_cool
                      - heat
                      - cool
                      - fan_only
                      - dry
                    fill_container: false
                    card_mod:
                      style: |
                          {% else %}
                          {% endif %}
                          display: flex;
                        @keyframes cool {
                        @keyframes heat {
                        @keyframes dry {
内页空调code:
type: custom:stack-in-card
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        style: |
          ha-card {
            padding-bottom: 1px !important;
        primary: 客厅空调
        secondary: >
          Currently: {{ state_attr('climate.lumi_mcn02_56bd_air_conditioner',
          'hvac_action') }}
        icon: |-
          {% set mode = states('climate.lumi_mcn02_56bd_air_conditioner') %}
          {% if mode == 'off' %}
          mdi:power
          {% elif mode == 'cool' %}
          mdi:snowflake
          {% elif mode == 'heat' %}
          mdi:fire
          {% elif mode == 'heat_cool' %}
          mdi:autorenew
          {% else %}
          mdi:home-thermometer
          {% endif %}
        icon_color: >-
          {% set status =
          state_attr('climate.lumi_mcn02_56bd_air_conditioner','hvac_action') %}
          {% if status == 'off' %}
          grey
          {% elif status == 'cooling' %}
          blue
          {% elif status == 'heating' %}
          red
          {% else %}
          grey
          {% endif %}
        tap_action: none
        cards:
          - type: custom:simple-thermostat
            style: |
              ha-card {
                --st-spacing: 0px;
              ha-card .current--value {
                color: #ffffff;
              header {
                margin-bottom: 12px !important;
                padding-bottom: 0px !important;
              ha-card .thermostat-trigger {
                color: #9e9e9e;
            header:
              icon: false
            decimals: '0'
            fallback: 'Off'
            hide:
              temperature: true
              state: true
            layout:
              mode:
                names: false
                icons: false
                headings: false
              step: row
            step_size: '1'
            control:
              hvac:
                'off': false
                heat: false
                cool: false
                heat_cool: false
  - type: custom:mushroom-chips-card
    style: |
      ha-card {
        --chip-box-shadow: none;
        --chip-background: none;
    alignment: justify
    chips:
      - type: template
        content: |
          {{ state_attr(entity, 'fan_mode') }}
        icon: mdi:fan
        icon_color: green
        tap_action: none
      - type: template
        content: '{{state_attr(entity, ''current_temperature'')}} °C'
        icon: mdi:home-thermometer
        tap_action:
          action: more-info
        icon_color: |-
          {% set state=states(entity) %}
          {% if state=='cool' %}
          blue
          {% elif state=='heat' %}
          red
          {% else %}
          grey
          {% endif %}
      - type: weather
        show_conditions: true
        show_temperature: true
      - type: template
        double_tap_action:
          action: none
        content: '{{ states(entity) }}% Humidity'
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
    style: |
      ha-card {
        --st-font-size-toggle-label: 6px
        --st-spacing: 0px;
        --st-default-spacing: 0px;
        --st-mode-background: #262626;
        margin-left: 12px;
        margin-right: 12px;
      ha-card .mode-item.active.off {
        background: #363636;
        color: #9e9e9e;
      ha-card .mode-item.active.cool {
        background: #1d3447;
        color: #2196f3;
      ha-card .mode-item.active.heat {
        background: #472421;
        color: #f44336;
      ha-card .mode-item.active.heat_cool {
        background: #493516;
        color: #ff9800;
      ha-card .mode-item.active {
        background: #263926;
        color: #4caf50;
      ha-card .mode-item.active:hover {
        color: #9e9e9e;
      ha-card .mode-item:hover {
        color: #9e9e9e;
      ha-card .mode-item {
        --st-spacing: 10px;
        border-radius: 10px;
      ha-card .modes {
        grid-gap: 12px
    header: false
    setpoints: false
    hide:
      temperature: true
      state: true
    layout:
      mode:
        headings: false
        icons: true
        names: false
      step: row
    control:
      hvac:
        'off':
        heat:
        cool:
        heat_cool:
  - type: grid
    square: false
    columns: 3
    cards:
      - type: custom:mushroom-entity-card
        primary_info: state
        secondary_info: name
        icon_color: green
        entity: sensor.colorfulclouds_wen_du
        primary_info: state
        icon_color: blue
        style: |
          ha-card {
            --st-spacing: 0px;
            --st-default-spacing: 1.3px;
            margin-right: 12px;
            color: #4caf50;
            color: #9e9e9e;
            color: #9e9e9e;
            --st-spacing: 6px;
          ha-card .modes {
            grid-gap: 12px
        header: false
        setpoints: false
        hide:
          temperature: true
          state: true
        layout:
          mode:
            headings: false
            icons: true
            names: false
          step: row
        control:
          hvac:
            'off': false
            heat: false
            cool: false
            heat_cool: false
          fan:
            Auto low:
              icon: mdi:fan-auto
            Low:
              icon: mdi:fan
    entities:
        name: Inside Temperature
        color: '#4caf50'
      - entity: sensor.colorfulclouds_shi_du
        name: Outside Temperature
        color: '#2196f3'
        y_axis: secondary
    hours_to_show: 24
    line_width: 3
    font_size: 50
    animate: true
    show:
      icon: false
      state: false
      legend: false
      fill: fade
参与人数 2金钱 +15 收起 理由
firewater + 10 厉害了word楼主!
DDDear + 5 感谢楼主分享!
发表于 2023-8-14 20:28:38 | 显示全部楼层
空调那部分有吗
 楼主| 发表于 2023-8-14 21:30:31 | 显示全部楼层
diy97 发表于 2023-8-14 20:28
空调那部分有吗
已经更新了。
发表于 2024-3-3 21:16:05 | 显示全部楼层
学习了,感谢!
ivy
发表于 2024-5-14 13:43:21 | 显示全部楼层
代码可以分享一下嘛
GMT+8, 2025-9-14 02:56 , Processed in 0.074553 second(s), 16 queries , MemCached On.
