查看: 4682|回复: 5
[硬件DIY] ESPhome接入pzem 004t出现问题
发表于 2023-8-11 14:06:20 | 显示全部楼层 |阅读模式
使用培正 PZEM 004T 和 HomeAssistant 监测家庭用电情况 (hellowood.dev)
现在按照上述链接准备先烧录esp-01s,
但是出现编译bin文件的错误,一直停住反复
INFO ESPHome 2023.7.1INFO Reading configuration /config/esphome/power-monitor.yaml...INFO Generating C++ source...INFO Compiling app...Processing power-monitor (board: esp01_1m; framework: arduino; platform: platformio/[email protected])--------------------------------------------------------------------------------Tool Manager: Installing platformio/framework-arduinoespressif8266 @ ~3.30002.0INFO Installing platformio/framework-arduinoespressif8266 @ ~3.30002.0Downloading  [####################################]  100%          Tool Manager: Warning! Package Mirror: The size (28870912 bytes) of downloaded file '7bb51cd-framework-arduinoespressif8266-3.30002.0.tar.gz' is not equal to remote size (35598641 bytes)WARNING Warning! Package Mirror: The size (28870912 bytes) of downloaded file '7bb51cd-framework-arduinoespressif8266-3.30002.0.tar.gz' is not equal to remote size (35598641 bytes)Tool Manager: Looking for another mirror...WARNING Looking for another mirror...Tool Manager: Error: Please read https://bit.ly/package-manager-ioerrorERROR Error: Please read https://bit.ly/package-manager-ioerrorTool Manager: Warning! Package Mirror: HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /ivankravets/pioreg-ci-mirror/releases/download/framework-arduinoespressif8266/7bb51cd-framework-arduinoespressif8266-3.30002.0.tar.gz (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fa323f8b0>, 'Connection to github.com timed out. (connect timeout=10)'))WARNING Warning! Package Mirror: HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /ivankravets/pioreg-ci-mirror/releases/download/framework-arduinoespressif8266/7bb51cd-framework-arduinoespressif8266-3.30002.0.tar.gz (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fa323f8b0>, 'Connection to github.com timed out. (connect timeout=10)'))Tool Manager: Looking for another mirror...WARNING Looking for another mirror...
但是论坛里也没找出个完整的[color=var(--mdc-dialog-heading-ink-color, rgba(0, 0, 0, 0.87))]power-monitor.yaml文件,目前像按照图中那样去接,谈有大神有知道这个bin编译错误的原因么?或者有其他配置文件指导一下?
发表于 2023-8-11 14:32:56 | 显示全部楼层
多试几次,有些文件没下载下来,有条件架个梯子。有梯子下载就快了
 楼主| 发表于 2023-8-11 16:38:22 | 显示全部楼层
可以编译了,已经生成了bin文件,是网络的问题
发表于 2023-8-11 16:54:37 | 显示全部楼层
用tosmota不是更方便?而且信息还多一些
Awe7 手机认证
发表于 2023-8-18 19:47:43 | 显示全部楼层
我想问问esphome pwm默认是占空比可变固定频率的,如何让它固定占空比50,频率可调呢?50hz--700hz
 楼主| 发表于 2023-8-28 17:35:56 | 显示全部楼层
是的,在用tasmota了,esphome还是麻烦了点
GMT+8, 2026-1-16 14:17 , Processed in 0.961369 second(s), 13 queries , MemCached On.
