查看: 3044|回复: 3
[求助] node-red下载不了节点
发表于 2023-8-11 08:37:59 | 显示全部楼层 |阅读模式
版本:Operating System 10.4
环境:WIN10上的VM虚拟机
家里群晖虚拟机部署的没问题,win10的这个,根本安装不了节点
 楼主| 发表于 2023-8-11 11:46:22 | 显示全部楼层
2023-08-11T02:53:17.201Z 安装 : node-red-contrib-bizwechat-apiproxy 1.2.1
2023-08-11T10:53:15.707Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict [email protected]
2023-08-11T10:53:16.039Z [err] npm WARN config production Use `--omit=dev` instead.
2023-08-11T11:00:53.872Z [err] npm ERR! code
2023-08-11T11:00:53.872Z [err]  ETIMEDOUT
2023-08-11T11:00:53.872Z [err] npm ERR! syscall connect
2023-08-11T11:00:53.872Z [err] npm ERR! errno ETIMEDOUT
2023-08-11T11:00:53.875Z [err] npm ERR! network request to https://registry.npmjs.org/node-red-contrib-bizwechat-apiproxy failed, reason: connect ETIMEDOUT 2606:4700::6810:23:443
2023-08-11T11:00:53.875Z [err] npm ERR! network This is a problem related to network connectivity.
2023-08-11T11:00:53.875Z [err] npm ERR! network In most cases you are behind a proxy or have bad network settings.
2023-08-11T11:00:53.875Z [err] npm ERR! network If you are behind a proxy, please make sure that the
2023-08-11T11:00:53.875Z [err]  ERR! network
2023-08-11T11:00:53.875Z [err]  'proxy' config is set properly.  See: 'npm help config'
2023-08-11T11:00:53.877Z [err]
2023-08-11T11:00:53.877Z [err] npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-08-11T10_53_16_009Z-debug-0.log
2023-08-11T11:00:53.885Z rc=1
发表于 2023-10-21 21:01:08 | 显示全部楼层
楼主解决了吗,我也一样问题
 楼主| 发表于 2023-10-24 12:19:30 | 显示全部楼层
fjcy233 发表于 2023-10-21 21:01
楼主解决了吗,我也一样问题
win11的虚拟机不行,但是群晖里的虚拟机没啥问题
GMT+8, 2025-12-18 14:12 , Processed in 0.273651 second(s), 15 queries , MemCached On.
