查看: 5951|回复: 19
[求助] 升级8.1以后出现的异常情况
发表于 2023-8-6 20:50:37 | 显示全部楼层 |阅读模式
(PVE装的haos)升级8.1后发现在后台会出现图片里这些记录,前端页面除了用“Node-RED Companion”集成和nodered加载项添加的自定义实体回事状态不可用之外别的都还正常,而这些不可用的实体等一会儿也会恢复正常,不知道什么原因
加载项的问题
加载项的问题
jjcs 手机认证
发表于 2023-8-7 17:30:39 | 显示全部楼层
请升级nodered,和nodered集成,还有homeassistant节点到最新版本,一般就能解决
 楼主| 发表于 2023-8-7 18:54:16 | 显示全部楼层
已经更新过了啊,加载项nodered是14.4.3,Node-RED Companion插件是2.1.1
jjcs 手机认证
发表于 2023-8-7 21:25:22 | 显示全部楼层
还有nodered里面的ha节点
jjcs 手机认证
发表于 2023-8-7 21:28:28 | 显示全部楼层
还有nodered里面的ha节点
 楼主| 发表于 2023-8-7 21:41:10 | 显示全部楼层
jjcs 发表于 2023-8-7 21:28
还有nodered里面的ha节点
可是我现在好像是加载项总是有问题,和里面的节点没啥关系把,重启ha以后有一定概率addons无法重启。
比如Samba share手动启动以后很快又自己关了两个日志,一个是加载项的
cont-init: info: running /etc/cont-init.d/samba.sh
[21:35:35] INFO: Hostname: homeassistant
[21:35:35] FATAL: No supported interfaces found to bind on.
cont-init: info: /etc/cont-init.d/samba.sh exited 1
cont-init: warning: some scripts exited nonzero
s6-rc: warning: unable to start service legacy-cont-init: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
一个是supervisior的
[color=var(--success-color)]23-08-07 21:40:34 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_core_samba application[color=var(--success-color)]23-08-07 21:40:35 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-samba with version 10.0.2[color=var(--success-color)]23-08-07 21:40:35 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_samba[color=var(--error-color)]23-08-07 21:40:40 ERROR (MainThread) [asyncio] Task exception was never retrievedfuture: <Task finished name='Task-3938' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1042> exception=AddonsJobError('Rate limit exceeded, more then 10 calls in 0:30:00')>Traceback (most recent call last):  File "/usr/src/supervisor/supervisor/addons/addon.py", line 1056, in watchdog_container    await self._restart_after_problem(self, event.state)  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 144, in wrapper    raise on_condition(supervisor.exceptions.AddonsJobError: Rate limit exceeded, more then 10 calls in 0:30:00[color=var(--error-color)]23-08-07 21:40:47 ERROR (SyncWorker_2) [supervisor.docker.interface] Container addon_core_samba is not running
 楼主| 发表于 2023-8-7 21:44:58 | 显示全部楼层
这是supervisor里nodered的日志
23-08-07 21:32:37 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Node-RED is failed, restarting...
23-08-07 21:32:37 INFO (SyncWorker_6) [supervisor.docker.interface] Cleaning addon_a0d7b954_nodered application
23-08-07 21:32:38 INFO (SyncWorker_5) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-rpc_shutdown with version 2.4
23-08-07 21:32:38 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/node-red/amd64 with version 14.4.3
23-08-07 21:32:39 INFO (SyncWorker_5) [supervisor.docker.interface] Cleaning addon_core_samba application
23-08-07 21:32:40 INFO (SyncWorker_5) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-samba with version 10.0.2
23-08-07 21:32:40 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_samba
23-08-07 21:32:45 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-2469' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1042> exception=AddonsJobError('Rate limit exceeded, more then 10 calls in 0:30:00')>
    raise on_condition(
发表于 2023-8-8 00:36:01 | 显示全部楼层
mtqq两个什么东当前版本无法升级
RED14.4.4来了
 楼主| 发表于 2023-8-8 08:12:44 | 显示全部楼层
315956999 发表于 2023-8-8 00:36
mtqq两个什么东当前版本无法升级
RED14.4.4来了
我没装mqtt啊,另外我这个升级新版nodered也不行
 楼主| 发表于 2023-8-8 08:14:08 | 显示全部楼层
昨晚上开始变成这了,无法启动
GMT+8, 2025-12-17 07:22 , Processed in 0.530111 second(s), 8 queries , MemCached On.
