查看: 2458|回复: 0
[流程系列] (已解决)疑似Node-Red更新后启动报错的问题
发表于 2023-8-1 08:34:00 | 显示全部楼层 |阅读模式
今天突然发现Node-Red没有启动,启动时报错如下:
启动加载项失败
[color=var(--primary-text-color)]Image ghcr.io/hassio-addons/node-red/amd64:14.4.2 does not exist for addon_a0d7b954_nodered
错误日志如下:
[backcolor=var(--mdc-theme-surface,#fff)]日志详细信息( ERROR )
[color=var(--mdc-dialog-content-ink-color,rgba(0,0,0,.6))]Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:130
Integration: Home Assistant Supervisor ([color=var(--primary-color)]documentation
, [color=var(--primary-color)]issues
First occurred: 08:28:01 (3 occurrences)
Last logged: 08:31:24
Failed to to call /addons/a0d7b954_nodered/start - Image ghcr.io/hassio-addons/node-red/amd64:14.4.2 does not exist for addon_a0d7b954_nodered
addons目录内空空如也,不仅没有Node-Red,其他加载项也没有,不过其他加载项正常运行,不知何故
不知道重装会不会导致Nore-Red的数据丢失,有什么办法能解决此问题,求助
卸载重装已解决,数据不丢
GMT+8, 2025-12-16 00:02 , Processed in 0.689485 second(s), 6 queries , MemCached On.
