查看: 10494|回复: 1
[求助] homebridge桥接后 broadlink设备正常 小米设备都无反馈
发表于 2017-12-25 22:20:23 | 显示全部楼层 |阅读模式
小米网关接入homeassistant 可以在web端正常显示数值 但是网关灯不能控制,但是能反馈属性。。。homebridge安装homebridge-homeassistant之后
非小米设备正常
小米设备都有问题
[2017-12-25 14:33:44] [HomeAssistant] Fetching HomeAssistant devices.
Failed to find plugin to handle accessory Gateway_Lightbulb
Failed to find plugin to handle accessory Gateway_LightSensor
Failed to find plugin to handle accessory Gateway_Switch_JoinPermission
Failed to find plugin to handle accessory TemperatureAndHumiditySensor_TemperatureSensor_
Failed to find plugin to handle accessory TemperatureAndHumiditySensor_HumiditySensor_
Failed to find plugin to handle accessory ContactSensor_ContactSensor_
Failed to find plugin to handle accessory MotionSensor_MotionSensor_
(四位编码隐去)
大家帮帮忙……
 楼主| 发表于 2017-12-25 23:27:43 | 显示全部楼层
自己解决了……把homebridge和homeassistant全部升级了一次 然后把缓存都删了
重启homebridge 全部OK了 这次自动化和编组也都有了 可见之前要不依赖有问题
升级homebridge-homeassistant的同时也将config.json 按照最新的simple修改了一下
删除了HomeKit中的homebridge桥 然后重新添加 妥妥的了
GMT+8, 2025-12-25 11:56 , Processed in 0.046741 second(s), 6 queries , MemCached On.
