楼主: Courae_feng
[求助] 关于悟空M1接入HA的问题。
 楼主| 发表于 2023-7-29 21:22:18 | 显示全部楼层
大神,是按照这样配置不
发表于 2023-7-30 00:46:11 | 显示全部楼层
Courae_feng 发表于 2023-7-29 21:22
大神,是按照这样配置不
注意缩进!!映射customize.ymal    customize下的放一起
 楼主| 发表于 2023-7-30 08:59:31 | 显示全部楼层
Integration error: customize - Integration 'customize' not found. 报这个错误一直没搞好,试了好几次了。
发表于 2023-7-30 13:31:10 | 显示全部楼层
Courae_feng 发表于 2023-7-30 08:59
Integration error: customize - Integration 'customize' not found. 报这个错误一直没搞好,试了好几次 ...
 楼主| 发表于 2023-7-30 14:42:39 | 显示全部楼层
感谢各位大佬帮助
发表于 2025-5-24 16:55:26 | 显示全部楼层
Invalid config for 'sensor' at configuration.yaml, line 160: required key 'platform' not provided
Invalid config for 'sensor' at configuration.yaml, line 167: required key 'platform' not provided
Invalid config for 'sensor' at configuration.yaml, line 174: required key 'platform' not provided
Invalid config for 'sensor' at configuration.yaml, line 181: required key 'platform' not provided
Invalid config for 'light' at configuration.yaml, line 190: required key 'platform' not provided
GMT+8, 2025-12-7 14:23 , Processed in 0.437965 second(s), 12 queries , MemCached On.
