查看: 2854|回复: 2
[求助] 请问大佬,怎么外部调用home assistant 的灯光api啊?
mzh
发表于 2023-7-24 17:09:20 | 显示全部楼层 |阅读模式
mzh
 楼主| 发表于 2023-7-24 17:10:33 | 显示全部楼层
http:[*****]:8123/api/services/light/turn_${ state ? 'on' : 'off' }好像不行
发表于 2023-7-25 09:16:39 | 显示全部楼层
https://developers.home-assistant.io/docs/api/rest
看文档呗,文档案例如下:
curl \
  -H "Authorization: Bearer TOKEN" \
  -H "Content-Type: application/json" \
  -d '{"entity_id": "switch.christmas_lights"}' \
  http://localhost:8123/api/services/switch/turn_on
你直接把/api/services/switch换成/api/services/light,然后再把entity_id改成你的。
GMT+8, 2025-12-18 13:59 , Processed in 0.137889 second(s), 12 queries , MemCached On.
