查看: 3037|回复: 1
[技术探讨] 求助华凌空调用户,我的空调能耗传感器一直为0
发表于 2023-7-15 17:11:40 | 显示全部楼层 |阅读模式
有N8HE1 PRO的用户帮我看看吗?在homeassistant中,同型号空调的能耗传感器回报是否正常?
我使用插件Midea AC LAN,传感器Air Conditioner Current Energy Consumption回报一直为0,应该是当日耗电量调试日志里面收到的如下,居然也是0
2023-07-15 17:04:54.970 DEBUG (Air Conditioner) [custom_components.midea_ac_lan.midea.core.device] [208907211624039] Status update: {'total_energy_consumption': 71.61, 'current_energy_consumption': 0.0, 'realtime_power': 1073.0}
2023-07-15 17:05:55.042 DEBUG (Air Conditioner) [custom_components.midea_ac_lan.midea.core.device] [208907211624039] Status update: {'total_energy_consumption': 71.62, 'current_energy_consumption': 0.0, 'realtime_power': 1035.0}
2023-07-15 17:06:55.129 DEBUG (Air Conditioner) [custom_components.midea_ac_lan.midea.core.device] [208907211624039] Status update: {'total_energy_consumption': 71.64, 'current_energy_consumption': 0.0, 'realtime_power': 952.0}
2023-07-15 17:07:56.807 DEBUG (Air Conditioner) [custom_components.midea_ac_lan.midea.core.device] [208907211624039] Status update: {'total_energy_consumption': 71.66, 'current_energy_consumption': 0.0, 'realtime_power': 767.0}
2023-07-15 17:09:06.297 DEBUG (Air Conditioner) [custom_components.midea_ac_lan.midea.core.device] [208907211624039] Status update: {'total_energy_consumption': 71.67, 'current_energy_consumption': 0.0, 'realtime_power': 420.0}
可是之前一段时间每天都有变化,我天天看空调当日耗电,累计耗电和实时功率传感器都有变化
美的美居APP里能联网查看当日耗电量,华凌智联小程序也需要联网才能查看
是官方云控了还是我传感器坏了?或者插件有问题?
 楼主| 发表于 2023-7-18 11:17:46 | 显示全部楼层
解决了,可能之前是用的空调插座的当日能耗传感器。可以用总耗电新建一个辅助设备,每日清零,得到一个当日能耗
GMT+8, 2025-12-1 01:02 , Processed in 0.975871 second(s), 12 queries , MemCached On.
