查看: 3565|回复: 6
[求助] debian 11安装求助最后一步
发表于 2023-7-14 22:58:57 | 显示全部楼层 |阅读模式
利用nas虚拟机安装debian11后,终端安装docker,目前安装 Home Assistant supervised Debian 软件包时,执行sudo dpkg -i homeassistant-supervised.deb错误,提示“dpkg:依赖关系问题使得 homessistant-supervised 的配置工作不能继续homeassistant-supervised 依赖于 systemd-resolved;然而:未安装软件包 systemd-resolved。”
发表于 2023-7-15 12:45:30 | 显示全部楼层
不要下载的homeassistant-supervisor.deb的最新安装包,下载之前一个版本的!!!!新版本貌似只支持最新版的debian12
发表于 2023-7-15 23:59:14 | 显示全部楼层
缺少这个文件 /lib/systemd/system/systemd-journal-gatewayd.service
发表于 2023-7-16 00:15:09 | 显示全部楼层
#  SPDX-License-Identifier: LGPL-2.1-or-later
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
[Unit]
Description=Journal Gateway Service Socket
Documentation=man:systemd-journal-gatewayd(8)
[Socket]
ListenStream=19531
[Install]
WantedBy=sockets.target
 楼主| 发表于 2023-7-17 00:54:46 | 显示全部楼层
安装代码咋写呢
发表于 2023-7-25 11:58:10 | 显示全部楼层
修改最新的 homeassistant-supervisor.deb 用代理ghproxy.com 替换 ghcr.io
https://ghproxy.com/https://gith ... tant-supervised.deb
发表于 2023-10-5 00:47:38 | 显示全部楼层
Debian 11 already has systemd-resolved.
install using:
sudo dpkg -i --ignore-depends=systemd-resolved ./homeassistant-supervised.deb
once it installs, edit /var/lib/dpkg/status and remove system-resolved from homeassistant-supervised Depends
GMT+8, 2025-12-17 07:23 , Processed in 0.618669 second(s), 8 queries , MemCached On.
