查看: 2157|回复: 2
[技术探讨] 请教一个问题,无法进行备份
发表于 2023-7-13 22:16:12 | 显示全部楼层 |阅读模式
群晖的套件版HA,bakcup时候出现如下错误。
Traceback (most recent call last):  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response    await func(hass, connection, msg)  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/homeassistant/components/backup/websocket.py", line 70, in handle_create    backup = await manager.generate_backup()             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/homeassistant/components/backup/manager.py", line 192, in generate_backup    size_in_bytes = await self.hass.async_add_executor_job(                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/var/packages/python311/target/lib/python3.11/concurrent/futures/thread.py", line 58, in run    result = self.fn(*self.args, **self.kwargs)             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/homeassistant/components/backup/manager.py", line 244, in _mkdir_and_generate_backup_contents    atomic_contents_add(  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/securetar/__init__.py", line 188, in atomic_contents_add    atomic_contents_add(tar_file, directory_item, excludes, arcpath)  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/securetar/__init__.py", line 188, in atomic_contents_add    atomic_contents_add(tar_file, directory_item, excludes, arcpath)  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/securetar/__init__.py", line 188, in atomic_contents_add    atomic_contents_add(tar_file, directory_item, excludes, arcpath)  [Previous line repeated 1 more time]  File "/var/packages/HomeAssistant/target/lib/python3.11/site-packages/securetar/__init__.py", line 182, in atomic_contents_add    for directory_item in origin_path.iterdir():  File "/var/packages/python311/target/lib/python3.11/pathlib.py", line 931, in iterdir    for name in os.listdir(self):                ^^^^^^^^^^^^^^^^PermissionError: [Errno 13] Permission denied: '/var/packages/HomeAssistant/home/.homeassistant/custom_components/hacs/repositories/__pycache__'
已经确认/var/packages/HomeAssistant/home/.homeassistant/custom_components/hacs/repositories/__pycache__ 目录的own和上级一致, 也给了755权限但仍然报相同的错误无法执行备份
发表于 2023-7-14 02:37:54 来自手机 | 显示全部楼层
给777权限
 楼主| 发表于 2023-7-14 13:51:10 | 显示全部楼层
试过了,777也不行
GMT+8, 2026-1-16 21:14 , Processed in 1.273703 second(s), 11 queries , MemCached On.
