查看: 5581|回复: 2
求助:homebridge启动不了
发表于 2017-12-22 21:42:44 | 显示全部楼层 |阅读模式
求助:
按照老高“使用树莓派官方系统来安装hass,并使用一键脚本安装homekit”的方法安装的。链接在这里:https://bbs.hassbian.com/thread-1302-1-1.html
homebridge能手动启动。但是homebridge.service服务启动不了,错误如下,请问是什么原因?
pi@raspberrypi:~ $ sudo systemctl start homebridge
pi@raspberrypi:~ $ sudo systemctl status homebridge
● homebridge.service - Node.js HomeKit Server
   Loaded: loaded (/etc/systemd/system/homebridge.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Sat 2017-12-23 00:31:22 CST; 2s ago
  Process: 3408 ExecStart=/usr/bin/homebridge $HOMEBRIDGE_OPTS (code=exited, status=1/FAILURE)
Main PID: 3408 (code=exited, status=1/FAILURE)
Dec 23 00:31:22 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Dec 23 00:31:22 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
/etc/systemd/system/homebridge.service内容:
[Unit]# Defaults / Configuration options for homebridge
Description=Node.js HomeKit Server
After=syslog.target network-online.target
[Service]
Type=simple
User=homebridge
EnvironmentFile=/etc/default/homebridge
# Adapt this to your specific setup (could be /usr/bin/homebridge)
# See comments below for more information
Restart=on-failure
RestartSec=10
KillMode=process
[Install]
WantedBy=multi-user.target
谢谢!
发表于 2017-12-23 18:44:39 | 显示全部楼层
一样的问题
 楼主| 发表于 2017-12-26 19:43:41 | 显示全部楼层
只能重装。没有办法啊
GMT+8, 2025-6-25 12:45 , Processed in 0.461624 second(s), 22 queries .
