查看: 1748|回复: 1
[求助] HASS无法更新
发表于 2023-7-9 19:05:31 | 显示全部楼层 |阅读模式
最近HASS内核一直无法更新,另外还有一个插件也是,现在把日志贴出来大家帮忙看看是不是墙的问题?
Home Assistant Core:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:305
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 17:19:14 (7 occurrences)
Last logged: 18:52:53
[139694361423360] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, no host internet connection
[139694319748528] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, was unable to update plugin(s) dns, multicast and all plugins must be up to date first
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 303, in async_install
    await async_update_core(self.hass, version=version, backup=backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 52, in _wrapper
    raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'HomeAssistantCore.update' blocked from execution, no host internet connection
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 199, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1849, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1889, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 226, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 798, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 981, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 838, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 156, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 417, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 305, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, no host internet connection
Node-RED:
Node-RED
9 Jul 17:01:00 - [warn] [ha-sensoransonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:00 - [error] [ha-sensoransonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:00 - [warn] [ha-sensoransonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:00 - [error] [ha-sensoransonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:00 - [warn] [ha-sensoransonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:00 - [error] [ha-sensoransonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:00 - [info] [server:Home Assistant] Connecting to http://supervisor/core9 Jul 17:01:05 - [warn] [ha-sensoransonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:05 - [error] [ha-sensoransonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:05 - [warn] [ha-sensoransonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:05 - [error] [ha-sensoransonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:05 - [warn] [ha-sensor:Pansonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:05 - [error] [ha-sensor:Pansonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:05 - [warn] [ha-sensor:Pansonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:05 - [error] [ha-sensor:Pansonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:05 - [warn] [ha-sensor:Pansonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:05 - [error] [ha-sensor:Pansonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:05 - [warn] [ha-sensor:Pansonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:05 - [error] [ha-sensor:Pansonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:05 - [warn] [ha-sensor:Pansonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:05 - [error] [ha-sensor:Pansonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant9 Jul 17:01:05 - [warn] [ha-sensor:Pansonic_Fan_Alarm] Message exceeded maximum number of catches9 Jul 17:01:05 - [error] [ha-sensor:Pansonic_Fan_Alarm] NoConnectionError: No connection to Home Assistant
国内网,无墙。请问除了用优盘外有什么办法吗?我是虚拟机直接安装官网下载的虚拟盘文件。
[color=var(--primary-text-color)]Home Assistant 2023.5.2Supervisor 2023.07.1Operating System 10.3前端版本: 20230503.3 - latest
发表于 2023-7-10 10:20:39 | 显示全部楼层
同样的问题,没有留学,ha core 从2023.6.3更新到2023.7,一直更新中,好像收不到更新文件,请大神指教!
GMT+8, 2025-12-18 13:57 , Processed in 1.125135 second(s), 6 queries , MemCached On.
