查看: 924|回复: 0
[求助] 小米AI智能音箱反复重启动,配网后不保存
发表于 2023-7-9 00:04:23 | 显示全部楼层 |阅读模式
U-Boot 2015.01 (Dec 24 2019 - 07:00:02), Build: jenkins-Mico_s12a_ota_publish-379
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89690
NAND:  nand id: 0xec 0xf1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: ec f1 0 95 42 c6
NAND device: Manufacturer ID: 0xec, Chip ID: 0xec (Samsung M Generation NAND 1Gib FS33ND01GS108TFI0)
oob avail size 6
Creating 1 MTD partitions on "M Generation NAND 1Gib FS33ND01GS108TFI0":
0x000000000000-0x000000200000 : "bootloader"
M Generation NAND 1Gib FS33ND01GS108TFI0 initialized ok
nand id: 0xec 0xf1
PLANE change!
aml_nand_init obmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x400 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=1
aml_nand_scan_rsv_info 1254
nbbt valid addr: 280000
aml_nand_bbt_check 1389 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=24, ec=122, phy_page_addr=0, timestamp=247
nenv free list:
blockN=25, ec=121, dirty_flag=1
blockN=26, ec=1, dirty_flag=1
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=32
nenv valid addr: 310000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=33, ec=0, phy_page_addr=0, timestamp=2
nkey free list:
blockN=32, ec=0, dirty_flag=1
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=16
nkey valid addr: 420000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=41, ec=1, phy_page_addr=0, timestamp=4
ndtb free list:
blockN=40, ec=1, dirty_flag=1
blockN=42, ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=64
ndtb valid addr: 520000
tpl: off 8388608, size 8388608
NAND bbt detect factory Bad block at 4060000
aml_nand_add_partition:1794 factory bad addr=203
NAND bbt detect factory Bad block at 7fe0000
Creating 6 MTD partitions on "M Generation NAND 1Gib FS33ND01GS108TFI0":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001800000 : "boot0"
0x000001800000-0x000002000000 : "boot1"
0x000002000000-0x000004000000 : "system0"
0x000004000000-0x000006020000 : "system1"
0x000006020000-0x000008000000 : "data"
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 310000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 520000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      GZIP format, decompress...
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 5 dtbs.
        aml_dt soc: xiaomi platform: s12c variant: v02
        dtb 0 soc: xiaomi   plat: s12   vari: v1
        dtb 1 soc: xiaomi   plat: s12a   vari: v01
        dtb 2 soc: xiaomi   plat: s12c   vari: v01
        dtb 3 soc: xiaomi   plat: s12c   vari: v02
        dtb 4 soc: xiaomi   plat: s12c   vari: v03
      Find match dtb: 3
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 420000
[EFUSE_MSG]keynum is 4
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
release_free_node 61: bitmap=1fffff
release_free_node 74: bitmap=1ffff7
aml_nand_save_rsv_info:716,save info to 320000
aml_nand_write_rsv:520,write info to 320000
[burnup]Rd:Up sz 0x3ac440 to align 0x1000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f0344f0
copy done
load dtb from 0x1000000 ......
      Single dtb detected
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x017a7808
   Loading Ramdisk to 0eea7000, end 0f004b7b ... OK
   Loading Device Tree to 000000000ee9b000, end 000000000eea62bf ... OK
Starting kernel ...
uboot time: 1534603 us
domain-0 init dvfs: 4
[    0.294545@3] ff803000.serial: clock gate not found
get key is 0x10 , curr_boot is boot1
Booting from boot1
/dev/mtdblock5 is ready now.
[    2.285946@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    2.286064@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
rm: can't remove '/tmp/tmp.iumKTX': No such file or directory
Please press Enter to activate this console.
[    5.323162@2] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.323796@2] cyttsp 0-0008: Failed to update firmware;
[    7.020181@1] name: mac_wifi, size 17
[    7.038622@3] name: mac_bt, size 17
micocfg[981]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[981]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[981]: UNLOCK fd: 3.
micocfg[981]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[981]: cfg get: success: /data/etc/device.info k:sn v:18090/883175425
micocfg[982]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[982]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[982]: UNLOCK fd: 3.
micocfg[982]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[982]: cfg get: success: /data/etc/device.info k:mac_wifi v:E4B:6D:82:0C:87
micocfg[983]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[983]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[983]: UNLOCK fd: 3.
micocfg[983]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[983]: cfg get: success: /data/etc/device.info k:mac_bt v:E4B:6D:A0:91:07
micocfg[984]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[984]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[984]: UNLOCK fd: 3.
micocfg[984]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[984]: cfg get: success: /data/etc/device.info k:miio_did v:152051881
micocfg[985]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[985]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[985]: UNLOCK fd: 3.
micocfg[985]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[985]: cfg get: success: /data/etc/device.info k:miio_key v:e1ER7bQod6KFYjxQ
micocfg[986]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[986]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[986]: UNLOCK fd: 3.
micocfg[986]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[986]: cfg get: success: /data/etc/device.info k:board_id v:6
micocfg[990]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[990]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[990]: UNLOCK fd: 3.
micocfg[990]: cfg get: success: /usr/share/mico/system.cfg k:buildts v:1633919466
micocfg[992]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[992]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[992]: UNLOCK fd: 3.
micocfg[993]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[993]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[993]: UNLOCK fd: 3.
micocfg[993]: bt_enable_set  argv[1] 1
micocfg[993]: LOCK:ret(0) fd(3), path(28): /var/lock/bluetooth.cfg.lock.
micocfg[993]: cfg update success: /data/bt/bluetooth.cfg k:enable v:1
micocfg[994]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[994]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[994]: UNLOCK fd: 3.
micocfg[994]: LOCK:ret(0) fd(3), path(28): /var/lock/messaging.cfg.lock.
micocfg[994]: cfg get: success: /data/etc/messaging.cfg k:super_admin v:882020598
micocfg[995]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[995]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[995]: UNLOCK fd: 3.
micocfg[995]: LOCK:ret(0) fd(3), path(23): /var/lock/miio.cfg.lock.
micocfg[995]: cfg update success: /data/etc/miio.cfg k:registed v:true
micocfg[997]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[997]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[997]: UNLOCK fd: 3.
micocfg[997]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
ledserver[1038]: Build Time: Oct 11 2021 02:58:54
ledserver[1038]: starting
ledserver[1038]: LOCK:ret(0) fd(8), path(28): /var/lock/nightmode.cfg.lock.
ledserver[1038]: cfg get: success: /data/etc/nightmode.cfg k:total v:night
ledserver[1038]: UNLOCK fd: 8.
ledserver[1038]: cfg get: success: /data/etc/nightmode.cfg k:light v:night
ledserver[1038]: cfg get: success: /data/etc/nightmode.cfg k:volume v:night
ledserver[1038]: cfg get: success: /data/etc/nightmode.cfg k:start v:22:20
ledserver[1038]: cfg get: success: /data/etc/nightmode.cfg k:stop v:07:20
ledserver[1038]: handle_show start
ledserver[1038]: start_show effect_id is 4 is_working is 0
ledserver[1038]: start_show end
ledserver[1038]: thread_push_led start
ledserver[1038]: handle_show stop
ledserver[1038]: thread_push_led end
crond[1060]: crond (busybox 1.27.2) started, log level 5
micocfg[1069]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1069]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[1069]: UNLOCK fd: 3.
micocfg[1069]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
ledserver[1038]: light_show_control 4
ledserver[1038]: open_light start
ledserver[1038]: light_show_effect 4
[   10.801719@3] pdm_dclk is : 0
[   12.460797@1] invalid toddr src
[   12.466254@0] Unable to handle kernel paging request at virtual address febfdec02976a100
[   12.468712@0] pgd = ffffffc00d81f000
[   12.472289@0] [febfdec02976a100] *pgd=0000000000000000, *pud=0000000000000000
[   12.479309@0] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[   12.484996@0] Modules linked in: dhd iptable_mangle iptable_filter ipt_REJECT ip_tables xt_time xt_tcpudp xt_multiport xt_mark xt_mac xt_limit xt_comment xt_TCPMSS xt_LOG x_tables uinput nf_reject_ipv4 nf_log_ipv4 nf_log_common hci_uart btusb btintel cyttsp_button snd_compress snd_pcm_oss snd_mixer_oss miso is31fl3236a
[   12.513032@0] CPU: 0 PID: 659 Comm: kworker/0:2 Not tainted 4.9.61 #1
[   12.519408@0] Hardware name: Amlogic (DT)
[   12.523391@0] Workqueue: events read_wq_handler
[   12.527862@0] task: ffffffc00dc41000 task.stack: ffffffc00e26c000
[   12.533904@0] PC is at __memcpy+0x78/0x180
[   12.537956@0] LR is at xz_dec_lzma2_run+0x458/0x818
[   12.542783@0] pc : [<ffffff8009262eb8>] lr : [<ffffff80092887a8>] pstate: 80000145
[   12.550286@0] sp : ffffffc00e26fb70
[   12.553736@0] x29: ffffffc00e26fb70 x28: ffffffc00dc6ef10
[   12.559169@0] x27: 0000000000000016 x26: ffffffc00dc6e000
[   12.564603@0] x25: 0000000000000002 x24: 0000000000000003
[   12.570037@0] x23: 0000000000000007 x22: ffffffc00dc68028
[   12.575470@0] x21: 0000000000000016 x20: ffffffc00dc68000
[   12.580904@0] x19: ffffffc00e3e6208 x18: 00000000958424a2
[   12.586338@0] x17: ffffffc00d1fa6ca x16: 0000000000001800
[   12.591772@0] x15: 0000000000001400 x14: 0000000000001c00
[   12.597205@0] x13: 0000000000001000 x12: 0000000000000c00
[   12.602639@0] x11: 0000000000000800 x10: 0000000000000400
[   12.608073@0] x9 : ffffffc00d1f9ffc x8 : 0000000074813d25
[   12.613506@0] x7 : 00000000446f98f5 x6 : ffffffc00dc6ef24
[   12.618940@0] x5 : 00000000acd74cc6 x4 : 0000000000000000
[   12.624374@0] x3 : 0000000000000010 x2 : 0000000000000016
[   12.629808@0] x1 : febfdec02976a100 x0 : ffffffc00dc6ef24
[   12.635244@0]
[   12.635244@0] SP: 0xffffffc00e26faf0:
[   12.640503@0] faf0  0dc68028 ffffffc0 00000007 00000000 00000003 00000000 00000002 00000000
[   12.648782@0] fb10  0dc6e000 ffffffc0 00000016 00000000 0dc6ef10 ffffffc0 0e26fb70 ffffffc0
[   12.657062@0] fb30  092887a8 ffffff80 0e26fb70 ffffffc0 09262eb8 ffffff80 80000145 00000000
[   12.665342@0] fb50  000040ac 00000000 0dc68028 ffffffc0 ffffffff ffffffff 09555508 ffffff80
[   12.673622@0] fb70  0e26fbd0 ffffffc0 09287144 ffffff80 0dd0c800 ffffffc0 0e3e6208 ffffffc0
[   12.681902@0] fb90  09679218 ffffff80 0dadf840 ffffffc0 0dd0c860 ffffffc0 00000026 00000000
[   12.690182@0] fbb0  00000000 00000000 000006cb 00000000 00000006 00000000 0e4b8a00 ffffffc0
[   12.698462@0] fbd0  0e26fc40 ffffffc0 091db608 ffffff80 0e3e6200 ffffffc0 00000000 00000000
[   12.706744@0]
[   12.706744@0] X0: 0xffffffc00dc6eea4:
[   12.712004@0] eea4  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   12.720284@0] eec4  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   12.728564@0] eee4  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   12.736843@0] ef04  04000400 04000400 00000014 2ea7045e f05f295c de658d3b 510d9cb9 1a0ed96f
[   12.745124@0] ef24  e36f4d48 b7a006a2 9dccf75c f40d45f8 cc7e9735 0000f54f 00000000 00000000
[   12.753403@0] ef44  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.761684@0] ef64  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.769963@0] ef84  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.778246@0]
[   12.778246@0] X6: 0xffffffc00dc6eea4:
[   12.783505@0] eea4  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   12.791785@0] eec4  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   12.800065@0] eee4  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   12.808345@0] ef04  04000400 04000400 00000014 2ea7045e f05f295c de658d3b 510d9cb9 1a0ed96f
[   12.816625@0] ef24  e36f4d48 b7a006a2 9dccf75c f40d45f8 cc7e9735 0000f54f 00000000 00000000
[   12.824905@0] ef44  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.833185@0] ef64  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.841465@0] ef84  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.849747@0]
[   12.849747@0] X9: 0xffffffc00d1f9f7c:
[   12.855006@0] 9f7c  340a8ebc e7747d3d a63f70bb df1820bc 925a61bc 618b66bd 34e788bc 38d9923d
[   12.863286@0] 9f9c  aebcb7bd a85df53c e1a30b3c c1ce3b3d 496d25bc 8420433e 0dce90bd c6e3debc
[   12.871566@0] 9fbc  10484cbd 380b5fbd a85a443c 4867ea3c 85c7503e 062083bd 81995b3e 8c16babd
[   12.879846@0] 9fdc  0885c63d a74ee53e b7a833be 2a59943b b54da23e c022463c 6f8636bd 934a4abd
[   12.888126@0] 9ffc  d27b663b 4c494146 525f4445 4f534145 4644004e 41525f53 5f524144 45544544
[   12.896406@0] a01c  44455443 53464400 4341435f 4e49465f 45485349 46440044 41435f53 42415f43
[   12.904686@0] a03c  4554524f 46440044 4f4e5f53 49465f50 4853494e 41004445 44494f56 4552465f
[   12.912966@0] a05c  4e455551 53454943 53434100 4148435f 4c454e4e 4c45535f 45544345 46440044
[   12.921250@0]
[   12.921250@0] X17: 0xffffffc00d1fa64a:
[   12.926594@0] a648  4e49202c 45524944 202c5443 49434e49 544e4544 0a2c4c41 43455053 2c4c4149
[   12.934873@0] a668  45584520 414c504d 202c5952 4320524f 45534e4f 4e455551 4c414954 4d414420
[   12.943153@0] a688  53454741 4e492820 44554c43 2c474e49 54554220 544f4e20 4d494c0a 44455449
[   12.951433@0] a6a8  2c4f5420 4f525020 45525543 544e454d 20464f20 53425553 55544954 47204554
[   12.959713@0] a6c8  00444f4f 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.967993@0] a6e8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.976273@0] a708  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.984553@0] a728  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   12.992833@0] a748  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   13.001115@0]
[   13.001115@0] X19: 0xffffffc00e3e6188:
[   13.006461@0] 6188  ffffffff 00f000f0 0d9579d8 ffffffc0 0d9579d8 ffffffc0 0dc41000 ffffffc0
[   13.014741@0] 61a8  00000000 00000000 00000000 00000000 00000000 00000000 0f585a00 ffffffc0
[   13.023021@0] 61c8  0dc0d000 ffffffc0 00000020 00020000 0000000f 00000000 00000000 00000000
[   13.031301@0] 61e8  00000000 00000000 00000000 00000000 00000000 00000000 0dd0c800 ffffffc0
[   13.039581@0] 6208  2976a100 febfdec0 00000000 00000000 00000400 00000000 0d1fa000 ffffffc0
[   13.047861@0] 6228  000006cb 00000000 00001000 00000000 00000000 00000000 00000000 00000000
[   13.056141@0] 6248  08582000 ffffff80 00021000 00000000 00000002 00000000 0f585900 ffffffc0
[   13.064421@0] 6268  00000020 00000000 00000000 00000000 09288bb4 ffffff80 0f585b00 ffffffc0
[   13.072702@0]
[   13.072702@0] X20: 0xffffffc00dc67f80:
[   13.078049@0] 7f80  6c202020 6c61636f 646f6d20 243d6c65 63696d28 6766636f 646f6d5f 0a296c65
[   13.086328@0] 7fa0  20202020 67676f6c 2d207265 696d2074 2d736e70 74696e69 2d20642e 20332070
[   13.094608@0] 7fc0  74735f22 5f747261 6e70696d 69785f73 696d6f61 646f6d2e 243d6c65 65646f6d
[   13.102888@0] 7fe0  200a226c 69202020 205b2066 39304c27 3d202741 6f6d2420 206c6564 7c7c205d
[   13.111168@0] 8000  02c5762b 0118c76d 00000000 00000080 0d760c00 ffffffc0 000003ec 00000000
[   13.119449@0] 8020  000003eb 00000000 08582000 ffffff80 000106cb 00000000 000106cb 00000000
[   13.127728@0] 8040  000106cb 00000000 00011000 00000000 00020000 00000000 00020000 00020000
[   13.136009@0] 8060  00000000 00000001 00000007 00000005 0000f75d 00003dbc 0dc60000 00003e31
[   13.144291@0]
[   13.144291@0] X22: 0xffffffc00dc67fa8:
[   13.149636@0] 7fa8  2d207265 696d2074 2d736e70 74696e69 2d20642e 20332070 74735f22 5f747261
[   13.157916@0] 7fc8  6e70696d 69785f73 696d6f61 646f6d2e 243d6c65 65646f6d 200a226c 69202020
[   13.166196@0] 7fe8  205b2066 39304c27 3d202741 6f6d2420 206c6564 7c7c205d 02c5762b 0118c76d
[   13.174476@0] 8008  00000000 00000080 0d760c00 ffffffc0 000003ec 00000000 000003eb 00000000
[   13.182756@0] 8028  08582000 ffffff80 000106cb 00000000 000106cb 00000000 000106cb 00000000
[   13.191036@0] 8048  00011000 00000000 00020000 00000000 00020000 00020000 00000000 00000001
[   13.199316@0] 8068  00000007 00000005 0000f75d 00003dbc 0dc60000 00003e31 0000001c 00000036
[   13.207596@0] 8088  00000a45 00000007 00000000 00000000 00000003 00000003 04700697 0690063f
[   13.215878@0]
[   13.215878@0] X26: 0xffffffc00dc6df80:
[   13.221224@0] df80  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.229503@0] dfa0  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.237783@0] dfc0  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.246063@0] dfe0  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.254344@0] e000  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.262624@0] e020  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.270904@0] e040  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.279184@0] e060  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.287467@0]
[   13.287467@0] X28: 0xffffffc00dc6ee90:
[   13.292811@0] ee90  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.301091@0] eeb0  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.309371@0] eed0  04000400 04000400 04000400 04000400 04000400 04000400 04000400 04000400
[   13.317651@0] eef0  04000400 04000400 04000400 04000400 04000400 04000400 04000400 00000014
[   13.325931@0] ef10  2ea7045e f05f295c de658d3b 510d9cb9 1a0ed96f e36f4d48 b7a006a2 9dccf75c
[   13.334211@0] ef30  f40d45f8 cc7e9735 0000f54f 00000000 00000000 00000000 00000000 00000000
[   13.342491@0] ef50  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   13.350771@0] ef70  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   13.359058@0]
[   13.359058@0] X29: 0xffffffc00e26faf0:
[   13.364401@0] faf0  0dc68028 ffffffc0 00000007 00000000 00000003 00000000 00000002 00000000
[   13.372680@0] fb10  0dc6e000 ffffffc0 00000016 00000000 0dc6ef10 ffffffc0 0e26fb70 ffffffc0
[   13.380959@0] fb30  092887a8 ffffff80 0e26fb70 ffffffc0 09262eb8 ffffff80 80000145 00000000
[   13.389239@0] fb50  000040ac 00000000 0dc68028 ffffffc0 ffffffff ffffffff 09555508 ffffff80
[   13.397520@0] fb70  0e26fbd0 ffffffc0 09287144 ffffff80 0dd0c800 ffffffc0 0e3e6208 ffffffc0
[   13.405800@0] fb90  09679218 ffffff80 0dadf840 ffffffc0 0dd0c860 ffffffc0 00000026 00000000
[   13.414081@0] fbb0  00000000 00000000 000006cb 00000000 00000006 00000000 0e4b8a00 ffffffc0
[   13.422360@0] fbd0  0e26fc40 ffffffc0 091db608 ffffff80 0e3e6200 ffffffc0 00000000 00000000
[   13.430641@0]
[   13.432284@0] Process kworker/0:2 (pid: 659, stack limit = 0xffffffc00e26c020)
[   13.439460@0] Stack: (0xffffffc00e26fb70 to 0xffffffc00e270000)
[   13.445329@0] fb60:                                   ffffffc00e26fbd0 ffffff8009287144
[   13.453240@0] fb80: ffffffc00dd0c800 ffffffc00e3e6208 ffffff8009679218 ffffffc00dadf840
[   13.461175@0] fba0: ffffffc00dd0c860 0000000000000026 0000000000000000 00000000000006cb
[   13.469110@0] fbc0: 0000000000000006 ffffffc00e4b8a00 ffffffc00e26fc40 ffffff80091db608
[   13.477044@0] fbe0: ffffffc00e3e6200 0000000000000000 0000000000000001 ffffffc00dadf840
[   13.484979@0] fc00: 0000000000000016 0000000000000026 0000000000010000 0000000000000000
[   13.492914@0] fc20: 00000000000039c6 ffffffc00e4b8a00 000000010e3e6200 000000000001fe28
[   13.500853@0] fc40: ffffffc00e26fcc0 ffffff80091db388 ffffffc00e2fe540 ffffffc00e3e6180
[   13.508787@0] fc60: ffffffc00e3e6188 ffffffc00e4b8a00 0000000000000026 000000000000037a
[   13.516720@0] fc80: 000000000000924c ffffffc00dadf840 ffffffc00dadf840 ffffffc00e2fe540
[   13.524654@0] fca0: ffffffc00e26fcc0 ffffff80098376a0 ffffffc00e2fe540 0000000000000002
[   13.532589@0] fcc0: ffffffc00e26fd10 ffffff80091d70dc 000000000000924c ffffffc00e983c30
[   13.540524@0] fce0: ffffffc00e4b8a00 0000000000000026 0000000000000000 ffffff800966b1b0
[   13.548477@0] fd00: ffffffc00e25c180 00000000fffffffb ffffffc00e26fd70 ffffff80091d7260
[   13.556397@0] fd20: ffffffc00e25c1e0 ffffffc00e30ec00 ffffffc00fb836c0 ffffffc00fb87700
[   13.564330@0] fd40: 0000000000000000 0000000000000000 ffffff80097625e0 0000000000000000
[   13.572264@0] fd60: ffffff8009756000 0000000000000000 ffffffc00e26fd80 ffffff80090ace60
[   13.580201@0] fd80: ffffffc00e26fdc0 ffffff80090ad264 ffffffc00e30ec00 ffffff8009756000
[   13.588136@0] fda0: ffffffc00fb836c0 ffffffc00e30ec30 ffffffc00fb836e0 ffffffc00e26c000
[   13.596070@0] fdc0: ffffffc00e26fe20 ffffff80090b2b58 ffffffc00e3c9340 ffffff80097ac4d0
[   13.604004@0] fde0: ffffff800965e970 ffffffc00e30ec00 ffffff80090acfc8 0000000000000000
[   13.611939@0] fe00: 0000000000000000 0000000000000000 0000000000000000 ffffffc00e30ec00
[   13.619874@0] fe20: 0000000000000000 ffffff8009082680 ffffff80090b2a68 ffffffc00e3c9340
[   13.627809@0] fe40: 0000000000000000 0000000000000000 0000000000000000 ffffff8009555508
[   13.635744@0] fe60: ffffffc00e26fe70 0000000000000000 ffffffc00e26fea0 ffffffc00e30ec00
[   13.643679@0] fe80: ffffff8000000000 ffffffc000000000 ffffffc00e26fe90 ffffffc00e26fe90
[   13.651615@0] fea0: 0000000000000000 ffffff8000000000 ffffffc00e26feb0 ffffffc00e26feb0
[   13.659549@0] fec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.667484@0] fee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.675419@0] ff00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.683354@0] ff20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.691289@0] ff40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.699224@0] ff60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.707159@0] ff80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.715094@0] ffa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.723029@0] ffc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
[   13.730964@0] ffe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.738897@0] Call trace:
[   13.741487@0] Exception stack(0xffffffc00e26f9a0 to 0xffffffc00e26fad0)
[   13.748042@0] f9a0: ffffffc00e3e6208 0000008000000000 ffffffc00e26fb70 ffffff8009262eb8
[   13.755977@0] f9c0: ffffffc00e26fae0 ffffff80090ca7c8 ffffffc00f4f6000 ffffffc00fb83dc0
[   13.763912@0] f9e0: 00000000fffee82b 0000000000000001 0000000000000000 00000002e63ce033
[   13.771847@0] fa00: ffffffc00dc68028 ffffffc00dc68090 0000000000000006 0000000000000006
[   13.779782@0] fa20: 000000000000083b 0000000000000006 000000000000e0c8 000000000f2e789e
[   13.787717@0] fa40: ffffffc00dc6ef24 febfdec02976a100 0000000000000016 0000000000000010
[   13.795652@0] fa60: 0000000000000000 00000000acd74cc6 ffffffc00dc6ef24 00000000446f98f5
[   13.803587@0] fa80: 0000000074813d25 ffffffc00d1f9ffc 0000000000000400 0000000000000800
[   13.811524@0] faa0: 0000000000000c00 0000000000001000 0000000000001c00 0000000000001400
[   13.819457@0] fac0: 0000000000001800 ffffffc00d1fa6ca
[   13.824467@0] [<ffffff8009262eb8>] __memcpy+0x78/0x180
[   13.829550@0] [<ffffff8009287144>] xz_dec_run+0x39c/0x8e8
[   13.834897@0] [<ffffff80091db608>] squashfs_xz_uncompress+0x238/0x3c0
[   13.841277@0] [<ffffff80091db388>] squashfs_decompress+0x68/0xa8
[   13.847234@0] [<ffffff80091d70dc>] squashfs_process_blocks+0x224/0x398
[   13.853698@0] [<ffffff80091d7260>] read_wq_handler+0x10/0x18
[   13.859307@0] [<ffffff80090ace60>] process_one_work+0x1e0/0x348
[   13.865168@0] [<ffffff80090ad264>] worker_thread+0x29c/0x4b8
[   13.870778@0] [<ffffff80090b2b58>] kthread+0xf0/0xf8
[   13.875694@0] [<ffffff8009082680>] ret_from_fork+0x10/0x50
[   13.881128@0] Code: a8c12027 a88120c7 a8c12027 a88120c7 (a8c12027)
[   13.887528@0] ---[ end trace 6e29e40f9a426c59 ]---
[   13.903546@0] note: kworker/0:2[659] exited with preempt_count 1
[   13.904124@0] Unable to handle kernel paging request at virtual address ffffffffffffffd8
[   13.911955@0] pgd = ffffffc00d81f000
[   13.915470@0] [ffffffffffffffd8] *pgd=0000000000000000, *pud=0000000000000000
[   13.922545@0] Internal error: Oops: 96000005 [#2] PREEMPT SMP
[   13.928235@0] Modules linked in: dhd iptable_mangle iptable_filter ipt_REJECT ip_tables xt_time xt_tcpudp xt_multiport xt_mark xt_mac xt_limit xt_comment xt_TCPMSS xt_LOG x_tables uinput nf_reject_ipv4 nf_log_ipv4 nf_log_common hci_uart btusb btintel cyttsp_button snd_compress snd_pcm_oss snd_mixer_oss miso is31fl3236a
[   13.956271@0] CPU: 0 PID: 659 Comm: kworker/0:2 Tainted: G      D         4.9.61 #1
[   13.963854@0] Hardware name: Amlogic (DT)
[   13.967834@0] task: ffffffc00dc41000 task.stack: ffffffc00e26c000
[   13.973868@0] PC is at kthread_data+0x4/0x10
[   13.978088@0] LR is at wq_worker_sleeping+0xc/0xb8
[   13.982830@0] pc : [<ffffff80090b34fc>] lr : [<ffffff80090add8c>] pstate: 800001c5
[   13.990333@0] sp : ffffffc00e26f800
[   13.993783@0] x29: ffffffc00e26f800 x28: ffffffc00e26c000
[   13.999216@0] x27: 0000000000000016 x26: 0000000000000000
[   14.004650@0] x25: ffffff8009755000 x24: 0000000000000000
[   14.010084@0] x23: ffffffc00dc41488 x22: ffffffc00dc41000
[   14.015518@0] x21: ffffff8009756000 x20: ffffff8009745000
[   14.020951@0] x19: ffffffc00fb83dc0 x18: 0000000000000068
[   14.026385@0] x17: 000000000000004c x16: 0000000000000033
[   14.031819@0] x15: 0000000000000019 x14: 0000000000000001
[   14.037252@0] x13: 0000000000000007 x12: 000000000000000e
[   14.042686@0] x11: ffffff8009593308 x10: 000000008aa5f150
[   14.048120@0] x9 : 000000009376d552 x8 : 0000000000000001
[   14.053554@0] x7 : 00000000400c2000 x6 : 0000000001953323
[   14.058988@0] x5 : 00ffffffffffffff x4 : 0000000000000001
[   14.064421@0] x3 : 0000000000100000 x2 : ffffffc00fb83dc0
[   14.069855@0] x1 : 0000000000000000 x0 : 0000000000000000
[   14.075290@0]
[   14.075290@0] SP: 0xffffffc00e26f780:
[   14.080550@0] f780  0dc41000 ffffffc0 0dc41488 ffffffc0 00000000 00000000 09755000 ffffff80
[   14.088829@0] f7a0  00000000 00000000 00000016 00000000 0e26c000 ffffffc0 0e26f800 ffffffc0
[   14.097110@0] f7c0  090add8c ffffff80 0e26f800 ffffffc0 090b34fc ffffff80 800001c5 00000000
[   14.105390@0] f7e0  0e26f810 ffffffc0 09551480 ffffff80 00000000 00000080 09745000 ffffff80
[   14.113669@0] f800  0e26f810 ffffffc0 09551100 ffffff80 0e26f860 ffffffc0 090bc2b0 ffffff80
[   14.121950@0] f820  0dc41000 ffffffc0 0e26f520 ffffffc0 0f429000 ffffffc0 0e26f8d0 ffffffc0
[   14.130229@0] f840  00000000 00000000 0dc41378 ffffffc0 0e26f870 ffffffc0 09099420 ffffff80
[   14.138509@0] f860  0e26f870 ffffffc0 09099458 ffffff80 0e26f8e0 ffffffc0 090873e4 ffffff80
[   14.146792@0]
[   14.146792@0] X2: 0xffffffc00fb83d40:
[   14.152051@0] 3d40  00000001 00000000 00140014 0000000b 0e309cc0 ffffffc0 0dcf7d00 ffffffc0
[   14.160331@0] 3d60  0f42e1c0 ffffffc0 00000000 00000000 00000000 00000000 00000001 00000000
[   14.168611@0] 3d80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.176891@0] 3da0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.185171@0] 3dc0  55755574 00000000 00000403 00000000 000003be 00000000 00000306 00000000
[   14.193451@0] 3de0  00000265 00000000 0000020a 00000000 00000000 00000000 fffee89c 00000000
[   14.201731@0] 3e00  00000000 00000000 00000000 00000000 00000000 00000000 000007d0 00000000
[   14.210011@0] 3e20  000020c1 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.218298@0]
[   14.218298@0] X19: 0xffffffc00fb83d40:
[   14.223638@0] 3d40  00000001 00000000 00140014 0000000b 0e309cc0 ffffffc0 0dcf7d00 ffffffc0
[   14.231918@0] 3d60  0f42e1c0 ffffffc0 00000000 00000000 00000000 00000000 00000001 00000000
[   14.240198@0] 3d80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.248478@0] 3da0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.256759@0] 3dc0  55765574 00000000 00000403 00000000 000003be 00000000 00000306 00000000
[   14.265038@0] 3de0  00000265 00000000 0000020a 00000000 00000000 00000000 fffee89c 00000000
[   14.273318@0] 3e00  00000000 00000000 00000000 00000000 00000000 00000000 000007d0 00000000
[   14.281598@0] 3e20  000020c1 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.289881@0]
[   14.289881@0] X22: 0xffffffc00dc40f80:
[   14.295226@0] 0f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.303506@0] 0fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.311786@0] 0fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.320066@0] 0fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.328346@0] 1000  00000040 00000000 0e26c000 ffffffc0 00000002 0420806c 00000000 00000000
[   14.336626@0] 1020  00000000 00000000 00000001 0000000c fffee898 00000000 0dfdd000 ffffffc0
[   14.344906@0] 1040  00000000 00000000 00000078 00000078 00000078 00000000 09568178 ffffff80
[   14.353186@0] 1060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.361467@0]
[   14.361467@0] X23: 0xffffffc00dc41408:
[   14.366813@0] 1408  0dc41408 ffffffc0 00000200 dead0000 0f721450 ffffffc0 00000200 dead0000
[   14.375094@0] 1428  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.383373@0] 1448  00000076 00000000 00000000 00000000 00000076 00000000 00000000 00000000
[   14.391654@0] 1468  00000000 00000000 00000000 00000000 00000000 00000000 0000002c 00000000
[   14.399934@0] 1488  0000006f 00000000 4e8021b3 00000000 4e8023fb 00000000 00000000 00000000
[   14.408213@0] 14a8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.416493@0] 14c8  0dc414c8 ffffffc0 0dc414c8 ffffffc0 0dc414d8 ffffffc0 0dc414d8 ffffffc0
[   14.424773@0] 14e8  0dc414e8 ffffffc0 0dc414e8 ffffffc0 00000000 00000000 0e4a9e00 ffffffc0
[   14.433057@0]
[   14.433057@0] X28: 0xffffffc00e26bf80:
[   14.438402@0] bf80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.446681@0] bfa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.454961@0] bfc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.463241@0] bfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.471521@0] c000  00000000 00000000 ffffffff ffffffff 0dc41000 ffffffc0 00000003 00000000
[   14.479801@0] c020  57ac6e9d 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.488081@0] c040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.496361@0] c060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.504642@0]
[   14.504642@0] X29: 0xffffffc00e26f780:
[   14.509989@0] f780  0dc41000 ffffffc0 0dc41488 ffffffc0 00000000 00000000 09755000 ffffff80
[   14.518268@0] f7a0  00000000 00000000 00000016 00000000 0e26c000 ffffffc0 0e26f800 ffffffc0
[   14.526548@0] f7c0  090add8c ffffff80 0e26f800 ffffffc0 090b34fc ffffff80 800001c5 00000000
[   14.534828@0] f7e0  0e26f810 ffffffc0 09551480 ffffff80 00000000 00000080 09745000 ffffff80
[   14.543108@0] f800  0e26f810 ffffffc0 09551100 ffffff80 0e26f860 ffffffc0 090bc2b0 ffffff80
[   14.551388@0] f820  0dc41000 ffffffc0 0e26f520 ffffffc0 0f429000 ffffffc0 0e26f8d0 ffffffc0
[   14.559668@0] f840  00000000 00000000 0dc41378 ffffffc0 0e26f870 ffffffc0 09099420 ffffff80
[   14.567948@0] f860  0e26f870 ffffffc0 09099458 ffffff80 0e26f8e0 ffffffc0 090873e4 ffffff80
[   14.576228@0]
[   14.577871@0] Process kworker/0:2 (pid: 659, stack limit = 0xffffffc00e26c020)
[   14.585029@0] Stack: (0xffffffc00e26f800 to 0xffffffc00e270000)
[   14.590895@0] f800: ffffffc00e26f810 ffffff8009551100 ffffffc00e26f860 ffffff80090bc2b0
[   14.598829@0] f820: ffffffc00dc41000 ffffffc00e26f520 ffffffc00f429000 ffffffc00e26f8d0
[   14.606764@0] f840: 0000000000000000 ffffffc00dc41378 ffffffc00e26f870 ffffff8009099420
[   14.614700@0] f860: ffffffc00e26f870 ffffff8009099458 ffffffc00e26f8e0 ffffff80090873e4
[   14.622634@0] f880: ffffff80097ab000 ffffffc00e26fa40 0000000000000000 ffffff800965b340
[   14.630569@0] f8a0: ffffffc00e26c000 ffffffc00dc41000 0000000000000002 ffffffc00dc6e000
[   14.638504@0] f8c0: 0000000000000016 ffffffc00e26c000 ffffffc00e26f8d0 ffffffc00e26f8d0
[   14.646439@0] f8e0: ffffffc00e26f920 ffffff80090934d4 febfdec02976a100 ffffffc00e26fa40
[   14.654374@0] f900: 0000000096000004 ffffffc00dc90680 0000000080000145 0000000000000025
[   14.662309@0] f920: ffffffc00e26f950 ffffff8009091a1c ffffffc00e26fa40 0000000096000004
[   14.670244@0] f940: febfdec02976a100 ffffffc00dc90680 ffffffc00e26f980 ffffff8009091a8c
[   14.678179@0] f960: 0000000096000004 ffffff8009567070 febfdec02976a100 ffffffc00e26fa40
[   14.686114@0] f980: ffffffc00e26f990 ffffff8009080a48 ffffffc00e26fb70 ffffff8009081dd0
[   14.694049@0] f9a0: ffffffc00e3e6208 0000008000000000 ffffffc00e26fb70 ffffff8009262eb8
[   14.701984@0] f9c0: ffffffc00e26fae0 ffffff80090ca7c8 ffffffc00f4f6000 ffffffc00fb83dc0
[   14.709919@0] f9e0: 00000000fffee82b 0000000000000001 0000000000000000 00000002e63ce033
[   14.717854@0] fa00: ffffffc00dc68028 ffffffc00dc68090 0000000000000006 0000000000000006
[   14.725789@0] fa20: 000000000000083b 0000000000000006 000000000000e0c8 000000000f2e789e
[   14.733724@0] fa40: ffffffc00dc6ef24 febfdec02976a100 0000000000000016 0000000000000010
[   14.741659@0] fa60: 0000000000000000 00000000acd74cc6 ffffffc00dc6ef24 00000000446f98f5
[   14.749594@0] fa80: 0000000074813d25 ffffffc00d1f9ffc 0000000000000400 0000000000000800
[   14.757529@0] faa0: 0000000000000c00 0000000000001000 0000000000001c00 0000000000001400
[   14.765464@0] fac0: 0000000000001800 ffffffc00d1fa6ca 00000000958424a2 ffffffc00e3e6208
[   14.773399@0] fae0: ffffffc00dc68000 0000000000000016 ffffffc00dc68028 0000000000000007
[   14.781334@0] fb00: 0000000000000003 0000000000000002 ffffffc00dc6e000 0000000000000016
[   14.789269@0] fb20: ffffffc00dc6ef10 ffffffc00e26fb70 ffffff80092887a8 ffffffc00e26fb70
[   14.797204@0] fb40: ffffff8009262eb8 0000000080000145 00000000000040ac ffffffc00dc68028
[   14.805139@0] fb60: ffffffffffffffff ffffff8009555508 ffffffc00e26fbd0 ffffff8009287144
[   14.813074@0] fb80: ffffffc00dd0c800 ffffffc00e3e6208 ffffff8009679218 ffffffc00dadf840
[   14.821009@0] fba0: ffffffc00dd0c860 0000000000000026 0000000000000000 00000000000006cb
[   14.828944@0] fbc0: 0000000000000006 ffffffc00e4b8a00 ffffffc00e26fc40 ffffff80091db608
[   14.836879@0] fbe0: ffffffc00e3e6200 0000000000000000 0000000000000001 ffffffc00dadf840
[   14.844814@0] fc00: 0000000000000016 0000000000000026 0000000000010000 0000000000000000
[   14.852749@0] fc20: 00000000000039c6 ffffffc00e4b8a00 000000010e3e6200 000000000001fe28
[   14.860684@0] fc40: ffffffc00e26fcc0 ffffff80091db388 ffffffc00e2fe540 ffffffc00e3e6180
[   14.868619@0] fc60: ffffffc00e3e6188 ffffffc00e4b8a00 0000000000000026 000000000000037a
[   14.876554@0] fc80: 000000000000924c ffffffc00dadf840 ffffffc00dadf840 ffffffc00e2fe540
[   14.884489@0] fca0: ffffffc00e26fcc0 ffffff80098376a0 ffffffc00e2fe540 0000000000000002
[   14.892424@0] fcc0: ffffffc00e26fd10 ffffff80091d70dc 000000000000924c ffffffc00e983c30
[   14.900359@0] fce0: ffffffc00e4b8a00 0000000000000026 0000000000000000 ffffff800966b1b0
[   14.908294@0] fd00: ffffffc00e25c180 00000000fffffffb ffffffc00e26fd70 ffffff80091d7260
[   14.916229@0] fd20: ffffffc00e25c1e0 ffffffc00e30ec00 ffffffc00fb836c0 ffffffc00fb87700
[   14.924164@0] fd40: 0000000000000000 0000000000000000 ffffff80097625e0 0000000000000000
[   14.932099@0] fd60: ffffff8009756000 0000000000000000 ffffffc00e26fd80 ffffff80090ace60
[   14.940034@0] fd80: ffffffc00e26fdc0 ffffff80090ad264 ffffffc00e30ec00 ffffff8009756000
[   14.947969@0] fda0: ffffffc00fb836c0 ffffffc00e30ec30 ffffffc00fb836e0 ffffffc00e26c000
[   14.955904@0] fdc0: ffffffc00e26fe20 ffffff80090b2b58 ffffffc00e3c9340 ffffff80097ac4d0
[   14.963839@0] fde0: ffffff800965e970 ffffffc00e30ec00 ffffff80090acfc8 0000000000000000
[   14.971774@0] fe00: 0000000000000000 0000000000000000 0000000000000000 ffffffc00e30ec00
[   14.979709@0] fe20: 0000000000000000 ffffff8009082680 ffffff80090b2a68 ffffffc00e3c9340
[   14.987644@0] fe40: 0000000000000000 0000000000000000 0000000000000000 ffffff8009555508
[   14.995579@0] fe60: ffffffc00e26fe70 0000000000000000 ffffffc00e26fea0 ffffffc00e30ec00
[   15.003514@0] fe80: ffffff8000000000 ffffffc000000000 ffffffc00e26fe90 ffffffc00e26fe90
[   15.011449@0] fea0: 0000000000000001 ffffff8000010001 ffffffc00e26feb0 ffffffc00e26feb0
[   15.019384@0] fec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.027319@0] fee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.035254@0] ff00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.043189@0] ff20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.051124@0] ff40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.059059@0] ff60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.066994@0] ff80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.074929@0] ffa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.082864@0] ffc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
[   15.090799@0] ffe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   15.098732@0] Call trace:
[   15.101322@0] Exception stack(0xffffffc00e26f630 to 0xffffffc00e26f760)
[   15.107876@0] f620:                                   ffffffc00fb83dc0 0000008000000000
[   15.115812@0] f640: ffffffc00e26f800 ffffff80090b34fc 0000000000000000 0000000180010000
[   15.123746@0] f660: ffffffc00f403800 0000000000000000 0000000000000001 0000000000000001
[   15.131681@0] f680: ffffffc00e26f780 ffffff8009161fa4 ffffffc00ff57240 ffffff80097493f0
[   15.139617@0] f6a0: ffffffc00f403800 ffffffc00e26c000 ffffffc00e350000 ffffffc00e26c000
[   15.147551@0] f6c0: ffffff8009094058 0000000000000878 0000000000000000 0000000000000000
[   15.155486@0] f6e0: ffffffc00fb83dc0 0000000000100000 0000000000000001 00ffffffffffffff
[   15.163421@0] f700: 0000000001953323 00000000400c2000 0000000000000001 000000009376d552
[   15.171357@0] f720: 000000008aa5f150 ffffff8009593308 000000000000000e 0000000000000007
[   15.179291@0] f740: 0000000000000001 0000000000000019 0000000000000033 000000000000004c
[   15.187231@0] [<ffffff80090b34fc>] kthread_data+0x4/0x10
[   15.192493@0] [<ffffff8009551100>] __schedule+0x100/0x4d0
[   15.197839@0] [<ffffff80090bc2b0>] do_task_dead+0x88/0x90
[   15.203185@0] [<ffffff8009099458>] do_exit+0x8b0/0x910
[   15.208274@0] [<ffffff80090873e4>] die+0x194/0x1b0
[   15.213019@0] [<ffffff80090934d4>] __do_kernel_fault.part.1+0x70/0x84
[   15.219398@0] [<ffffff8009091a1c>] do_bad_area+0x8c/0xb0
[   15.224659@0] [<ffffff8009091a8c>] do_translation_fault+0x34/0x40
[   15.230697@0] [<ffffff8009080a48>] do_mem_abort+0x40/0x98
[   15.236042@0] Exception stack(0xffffffc00e26f9a0 to 0xffffffc00e26fad0)
[   15.242599@0] f9a0: ffffffc00e3e6208 0000008000000000 ffffffc00e26fb70 ffffff8009262eb8
[   15.250534@0] f9c0: ffffffc00e26fae0 ffffff80090ca7c8 ffffffc00f4f6000 ffffffc00fb83dc0
[   15.258469@0] f9e0: 00000000fffee82b 0000000000000001 0000000000000000 00000002e63ce033
[   15.266404@0] fa00: ffffffc00dc68028 ffffffc00dc68090 0000000000000006 0000000000000006
[   15.274339@0] fa20: 000000000000083b 0000000000000006 000000000000e0c8 000000000f2e789e
[   15.282274@0] fa40: ffffffc00dc6ef24 febfdec02976a100 0000000000000016 0000000000000010
[   15.290209@0] fa60: 0000000000000000 00000000acd74cc6 ffffffc00dc6ef24 00000000446f98f5
[   15.298144@0] fa80: 0000000074813d25 ffffffc00d1f9ffc 0000000000000400 0000000000000800
[   15.306079@0] faa0: 0000000000000c00 0000000000001000 0000000000001c00 0000000000001400
[   15.314013@0] fac0: 0000000000001800 ffffffc00d1fa6ca
[   15.319016@0] [<ffffff8009081dd0>] el1_da+0x24/0x84
[   15.323849@0] [<ffffff8009287144>] xz_dec_run+0x39c/0x8e8
[   15.329196@0] [<ffffff80091db608>] squashfs_xz_uncompress+0x238/0x3c0
[   15.335576@0] [<ffffff80091db388>] squashfs_decompress+0x68/0xa8
[   15.341531@0] [<ffffff80091d70dc>] squashfs_process_blocks+0x224/0x398
[   15.347997@0] [<ffffff80091d7260>] read_wq_handler+0x10/0x18
[   15.353604@0] [<ffffff80090ace60>] process_one_work+0x1e0/0x348
[   15.359467@0] [<ffffff80090ad264>] worker_thread+0x29c/0x4b8
[   15.365074@0] [<ffffff80090b2b58>] kthread+0xf0/0xf8
[   15.369990@0] [<ffffff8009082680>] ret_from_fork+0x10/0x50
[   15.375426@0] Code: a94153f3 a8c27bfd d65f03c0 f9421400 (f85d8000)
AXG:BL1:d1dbf2:a4926f;FEAT:E0DC318C:2000OC:F;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
sdio debug board detected
TE: 23499
BL2 Built : 18:30:39, Aug 28 2018. axg g56303a2-dirty - liang.yang@droid11-sz
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 6
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 2d 0a 51 36 13 59 2c 08 50 34 12 56 00 00 00 00 00 00 00 00 00 00 00 00 650   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
page0 page0->bbt:
0000000000000000000000000000000000000000000000000000000000000000
page0 bbt:
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x43
17 8d b0 63 59 1 ca 82 5d 50 52 f0 bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014520 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
DRAM:  256 MiB
oob avail size 6
nand id: 0xec 0xf1
PLANE change!
oob avail size 8
nbbt free list:
nenv : phy_blk_addr=25, ec=122, phy_page_addr=0, timestamp=248
nenv free list:
blockN=24, ec=122, dirty_flag=1
nenv valid addr: 320000
nkey free list:
ndtb free list:
aml_key_init 170
MMC:
aml_nand_read_rsv_info:397,read nenv info to 320000
In:    serial
Out:   serial
Err:   serial
sub cmd dtb
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
      Multi dtb detected
      Support 5 dtbs.
      Find match dtb: 3
aml_nand_save_rsv_info:716,save info to 330000
aml_nand_write_rsv:520,write info to 330000
save_power_post ...
reloc_addr =f0344f0
copy done
      Single dtb detected
   Loading Ramdisk to 0eea7000, end 0f004b95 ... OK
Starting kernel ...
uboot time: 1518440 us
[    0.278949@2] ff803000.serial: clock gate not found
get key is 0x00 , curr_boot is boot0
Booting from boot0
/dev/mtdblock4 is ready now.
[    2.149849@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    2.149972@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
[    5.288692@3] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.289318@3] cyttsp 0-0008: Failed to update firmware;
[    6.996813@1] name: mac_wifi, size 17
[    7.015170@1] name: mac_bt, size 17
micocfg[983]: cfg get: success: /data/etc/device.info k:mac_wifi v:E4B:6D:82:0C:87
micocfg[984]: cfg get: success: /data/etc/device.info k:mac_bt v:E4B:6D:A0:91:07
micocfg[985]: cfg get: success: /data/etc/device.info k:miio_did v:152051881
micocfg[986]: cfg get: success: /data/etc/device.info k:miio_key v:e1ER7bQod6KFYjxQ
micocfg[987]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[987]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[987]: UNLOCK fd: 3.
micocfg[987]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[987]: cfg get: success: /data/etc/device.info k:board_id v:6
micocfg[991]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[991]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[991]: UNLOCK fd: 3.
micocfg[991]: cfg get: success: /usr/share/mico/system.cfg k:buildts v:1637912798
micocfg[994]: bt_enable_set  argv[1] 1
micocfg[994]: LOCK:ret(0) fd(3), path(28): /var/lock/bluetooth.cfg.lock.
micocfg[994]: cfg update success: /data/bt/bluetooth.cfg k:enable v:1
micocfg[995]: LOCK:ret(0) fd(3), path(28): /var/lock/messaging.cfg.lock.
micocfg[995]: cfg get: success: /data/etc/messaging.cfg k:super_admin v:882020598
micocfg[996]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[996]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[996]: UNLOCK fd: 3.
micocfg[996]: LOCK:ret(0) fd(3), path(23): /var/lock/miio.cfg.lock.
micocfg[996]: cfg update success: /data/etc/miio.cfg k:registed v:true
micocfg[998]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[998]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[998]: UNLOCK fd: 3.
micocfg[998]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
ledserver[1038]: Build Time: Nov 26 2021 08:16:09
[   10.930493@0] pdm_dclk is : 0
        70e0fab79649fa8746d9c813f5ca70ba[   12.018871@3] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.036404@1] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.037896@2] pgd = ffffffc00e502000
[   12.041355@2] [f6d0f000] *pgd=000000000de58003, *pud=000000000de58003[   12.046319@0] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.046478@1] VFS: brelse: Trying to free free buffer
[   12.048587@1] VFS: brelse: Trying to free free buffer
[   12.050610@1] VFS: brelse: Trying to free free buffer
[   12.052630@1] VFS: brelse: Trying to free free buffer
[   12.054671@1] VFS: brelse: Trying to free free buffer
[   12.056678@1] VFS: brelse: Trying to free free buffer
[   12.058662@1] VFS: brelse: Trying to free free buffer
[   12.060658@1] VFS: brelse: Trying to free free buffer
[   12.062655@1] VFS: brelse: Trying to free free buffer
[   12.064638@1] VFS: brelse: Trying to free free buffer
[   12.066665@1] VFS: brelse: Trying to free free buffer
[   12.068654@1] VFS: brelse: Trying to free free buffer
[   12.070680@1] VFS: brelse: Trying to free free buffer
[   12.072687@1] VFS: brelse: Trying to free free buffer
[   12.074681@1] VFS: brelse: Trying to free free buffer
[   12.076634@1] VFS: brelse: Trying to free free buffer
[   12.088767@1] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.103713@3] pgd = ffffffc00da3d000
[   12.103717@3] [f7eeddbc] *pgd=000000000da46003
[   12.104128@1] pgd = ffffffc00e232000
[   12.104131@1] [a000201c] *pgd=0000000000000000
[   12.109583@3] pgd = ffffffc00da42000
[   12.109586@3] [a4108c38] *pgd=0000000000000000
[   12.113688@2] pgd = ffffffc00daab000
[   12.113692@2] [d72fa6c4] *pgd=000000000dac3003
[   12.118242@2] pgd = ffffffc00daab000
[   12.118245@2] [0001892c] *pgd=000000000d95c003
[   12.122421@2] pgd = ffffffc00daab000
[   12.122424@2] [fb10358c] *pgd=000000000d98e003
[   12.123699@0] pgd = ffffffc00daaf000
[   12.123702@0] [f73d6dcb] *pgd=000000000d866003
[   12.127958@2] pgd = ffffffc00daab000
[   12.127961@2] [d30159cc] *pgd=000000000d8db003
[   12.128819@0] pgd = ffffffc00daaf000
[   12.128822@0] [5e9aee7c] *pgd=0000000000000000
[   12.148976@1] VFS: brelse: Trying to free free buffer
[   12.151103@1] VFS: brelse: Trying to free free buffer
[   12.153077@1] VFS: brelse: Trying to free free buffer
[   12.268334@0] VFS: brelse: Trying to free free buffer
[   12.272143@0] VFS: brelse: Trying to free free buffer
[   12.276572@0] VFS: brelse: Trying to free free buffer
[   12.281523@0] VFS: brelse: Trying to free free buffer
[   12.286269@0] VFS: brelse: Trying to free free buffer
[   12.292624@0] VFS: brelse: Trying to free free buffer
[   12.296447@0] VFS: brelse: Trying to free free buffer
[   12.301488@0] VFS: brelse: Trying to free free buffer
[   12.306474@0] VFS: brelse: Trying to free free buffer
[   12.311486@0] VFS: brelse: Trying to free free buffer
[   12.318310@0] VFS: brelse: Trying to free free buffer
[   12.321720@0] VFS: brelse: Trying to free free buffer
[   12.326839@0] VFS: brelse: Trying to free free buffer
[   12.343691@3] VFS: brelse: Trying to free free buffer
[   12.388680@0] VFS: brelse: Trying to free free buffer
[   12.392221@0] VFS: brelse: Trying to free free buffer
[   12.396819@0] VFS: brelse: Trying to free free buffer
[   12.461700@3] VFS: brelse: Trying to free free buffer
[   12.465567@3] VFS: brelse: Trying to free free buffer
[   12.469316@3] VFS: brelse: Trying to free free buffer
[   12.474673@3] VFS: brelse: Trying to free free buffer
[   12.479361@3] VFS: brelse: Trying to free free buffer
[   12.484606@3] VFS: brelse: Trying to free free buffer
[   12.490157@3] VFS: brelse: Trying to free free buffer
[   12.494910@3] VFS: brelse: Trying to free free buffer
[   12.499349@3] VFS: brelse: Trying to free free buffer
[   12.504344@3] VFS: brelse: Trying to free free buffer
[   12.509355@3] VFS: brelse: Trying to free free buffer
[   12.514677@3] VFS: brelse: Trying to free free buffer
[   12.519893@3] VFS: brelse: Trying to free free buffer
[   12.524364@3] VFS: brelse: Trying to free free buffer
[   12.529459@3] VFS: brelse: Trying to free free buffer
[   12.556607@3] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.558172@3] VFS: brelse: Trying to free free buffer
[   12.566609@3] VFS: brelse: Trying to free free buffer
[   12.571463@3] VFS: brelse: Trying to free free buffer
[   12.576229@3] VFS: brelse: Trying to free free buffer
[   12.581301@3] VFS: brelse: Trying to free free buffer
[   12.586545@3] VFS: brelse: Trying to free free buffer
[   12.589579@1] VFS: brelse: Trying to free free buffer
[   12.591496@1] VFS: brelse: Trying to free free buffer
[   12.593352@1] VFS: brelse: Trying to free free buffer
[   12.595640@1] VFS: brelse: Trying to free free buffer
[   12.604239@1] VFS: brelse: Trying to free free buffer
[   12.606334@1] VFS: brelse: Trying to free free buffer
[   12.608289@1] VFS: brelse: Trying to free free buffer
[   12.610283@1] VFS: brelse: Trying to free free buffer
[   12.612217@1] VFS: brelse: Trying to free free buffer
[   12.614255@1] VFS: brelse: Trying to free free buffer
[   12.616209@1] VFS: brelse: Trying to free free buffer
[   12.627077@1] VFS: brelse: Trying to free free buffer
[   12.629122@1] VFS: brelse: Trying to free free buffer
[   12.655181@3] VFS: brelse: Trying to free free buffer
[   12.661509@3] VFS: brelse: Trying to free free buffer
[   12.666480@3] VFS: brelse: Trying to free free buffer
[   12.671327@3] VFS: brelse: Trying to free free buffer
[   12.676477@3] VFS: brelse: Trying to free free buffer
[   12.681521@3] VFS: brelse: Trying to free free buffer
[   12.686459@3] VFS: brelse: Trying to free free buffer
[   12.691487@3] VFS: brelse: Trying to free free buffer
[   12.696552@3] VFS: brelse: Trying to free free buffer
[   12.701482@3] VFS: brelse: Trying to free free buffer
[   12.720875@3] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.733254@3] VFS: brelse: Trying to free free buffer
[   12.737089@3] VFS: brelse: Trying to free free buffer
[   12.741379@3] VFS: brelse: Trying to free free buffer
[   12.746427@3] VFS: brelse: Trying to free free buffer
[   12.751457@3] VFS: brelse: Trying to free free buffer
[   12.756979@3] VFS: brelse: Trying to free free buffer
[   12.761449@3] VFS: brelse: Trying to free free buffer
[   12.766424@3] VFS: brelse: Trying to free free buffer
[   12.771415@3] VFS: brelse: Trying to free free buffer
[   12.776364@3] VFS: brelse: Trying to free free buffer
[   12.781353@3] VFS: brelse: Trying to free free buffer
[   12.786906@3] VFS: brelse: Trying to free free buffer
[   12.791326@3] VFS: brelse: Trying to free free buffer
[   12.796426@3] VFS: brelse: Trying to free free buffer
[   12.801438@3] VFS: brelse: Trying to free free buffer
[   12.806360@3] VFS: brelse: Trying to free free buffer
        70e0fab79649fa8746d9c813f5ca70ba        70e0fab79649fa8746d9c813f5ca70ba        70e0fab79649fa8746d9c813f5ca70ba70e0fab79649fa8746d9c813f5ca70ba  70e0fab79649fa8746d9c813f5ca70ba  bl31 reboot reason: 0xd
bl31 reboot reason: 0xc
system cmd  1.
TE: 23744
set vcck to 1140 mv
Board ID = 6
CPU clk: 1200MHz
bist_test rank: 0 2e 0b 51 36 13 59 2a 06 4f 34 12 57 00 00 00 00 00 00 00 00 00 00 00 00 650   - PASS
AddrBus test pass!
NAND init
page0 page0->bbt:
page0 bbt:
OPS=0x43
bl30:axg thermal0
[0.014522 Inits done]
secure task start!
high task start!
low task start!
DRAM:  256 MiB
oob avail size 6
nand id: 0xec 0xf1
PLANE change!
oob avail size 8
nbbt free list:
nenv : phy_blk_addr=24, ec=123, phy_page_addr=0, timestamp=249
nenv free list:
blockN=25, ec=122, dirty_flag=1
nenv valid addr: 300000
nkey free list:
ndtb free list:
aml_key_init 170
MMC:
aml_nand_read_rsv_info:397,read nenv info to 300000
In:    serial
Out:   serial
Err:   serial
sub cmd dtb
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
      Multi dtb detected
      Support 5 dtbs.
      Find match dtb: 3
aml_nand_save_rsv_info:716,save info to 310000
aml_nand_write_rsv:520,write info to 310000
save_power_post ...
reloc_addr =f0344f0
copy done
      Single dtb detected
Starting kernel ...
uboot time: 1518394 us
[    0.290662@1] ff803000.serial: clock gate not found
Booting from boot0
[    2.282055@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    2.282177@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
rm: can't remove '/tmp/tmp.fGX1IZ': No such file or directory
[    5.306872@1] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.307505@1] cyttsp 0-0008: Failed to update firmware;
[    7.027790@2] name: mac_wifi, size 17
[    7.045379@3] name: mac_bt, size 17
micocfg[980]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[980]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[980]: UNLOCK fd: 3.
micocfg[980]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[980]: cfg get: success: /data/etc/device.info k:sn v:18090/883175425
micocfg[981]: cfg get: success: /data/etc/device.info k:mac_wifi v:E4B:6D:82:0C:87
micocfg[982]: cfg get: success: /data/etc/device.info k:mac_bt v:E4B:6D:A0:91:07
micocfg[983]: cfg get: success: /data/etc/device.info k:miio_did v:152051881
micocfg[984]: cfg get: success: /data/etc/device.info k:miio_key v:e1ER7bQod6KFYjxQ
micocfg[985]: cfg get: success: /data/etc/device.info k:board_id v:6
micocfg[989]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[989]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[989]: UNLOCK fd: 3.
micocfg[989]: cfg get: success: /usr/share/mico/system.cfg k:buildts v:1637912798
micocfg[992]: bt_enable_set  argv[1] 1
micocfg[992]: LOCK:ret(0) fd(3), path(28): /var/lock/bluetooth.cfg.lock.
micocfg[992]: cfg update success: /data/bt/bluetooth.cfg k:enable v:1
micocfg[993]: LOCK:ret(0) fd(3), path(28): /var/lock/messaging.cfg.lock.
micocfg[993]: cfg get: success: /data/etc/messaging.cfg k:super_admin v:882020598
micocfg[994]: LOCK:ret(0) fd(3), path(23): /var/lock/miio.cfg.lock.
micocfg[994]: cfg update success: /data/etc/miio.cfg k:registed v:true
micocfg[996]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
[   10.964723@3] pdm_dclk is : 0
[   12.298930@2] Unable to handle kernel paging request at virtual address fafe5fc0afeb7940
[   12.301421@2] pgd = ffffffc00e333000
[   12.304948@2] [fafe5fc0afeb7940] *pgd=0000000000000000, *pud=0000000000000000
[   12.311996@2] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[   12.317683@2] Modules linked in: dhd iptable_mangle iptable_filter ipt_REJECT ip_tables xt_time xt_tcpudp xt_multiport xt_mark xt_mac xt_limit xt_comment xt_TCPMSS xt_LOG x_tables uinput nf_reject_ipv4[   12.334410@3] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   12.334704@3] bcmsdh_oob_intr_register: Enter
[   12.334706@3] bcmsdh_oob_intr_register: HW_OOB enabled
[   12.334710@3] bcmsdh_oob_intr_register OOB irq=91 flags=414
[   12.334744@3] meson_pinctrl: gpio virq[91] connect to GIC hwirq[96]
[   12.334809@3] bcmsdh_oob_intr_register: enable_irq_wake
[   12.334813@3] bcmsdh_oob_intr_register: enable_irq_wake failed with -6
[   12.336028@3] dhd_conf_set_fw_int_cmd: set WLC_SET_BAND 142 0
[   12.336218@3] dhd_preinit_ioctls: Set tcpack_sup_mode 0
[   12.337753@3] Firmware up: op_mode=0x0005, MAC=e4:db:6d:82:0c:87
[   12.337758@3] dhd_conf_set_country: set country CN, revision 38
[   12.337762@3] dhd_conf_set_fw_string_struct_cmd: set country
[   12.359974@3] Country code: CN (CN/38)
[   12.360334@3] dhd_conf_set_fw_string_cmd: set roam_off 1
[   12.368429@3] Firmware version = wl0: Dec 22 2017 09:40:17 version 7.45.96 (r) FWID 01-fa516500
[   12.368435@3]   Driver: 1.201.59.6 (r506368)
[   12.368435@3]   Firmware: wl0: Dec 22 2017 09:40:17 version 7.45.96 (r) FWID 01-fa516500
[   12.368658@3] dhd_txglom_enable: enable 1
[   12.368663@3] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[   12.368666@3] dhd_conf_set_txglom_params: txglom_bucket_size=0
[   12.368669@3] dhd_conf_set_txglom_params: txglomsize=40, deferred_tx_len=40, bus_txglom=0
[   12.368672@3] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
[   12.368675@3] dhd_conf_set_disable_proptx: set disable_proptx 0
[   12.371417@3] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[   12.475527@2]  nf_log_ipv4 nf_log_common hci_uart btusb btintel cyttsp_button snd_compress snd_pcm_oss snd_mixer_oss miso is31fl3236a
[   12.487426@2] CPU: 2 PID: 541 Comm: kworker/2:1 Not tainted 4.9.61 #1
[   12.493803@2] Hardware name: Amlogic (DT)
[   12.497781@2] Workqueue: mtdblock4 mtd_blktrans_work
[   12.502687@2] task: ffffffc00e69a000 task.stack: ffffffc00de5c000
[   12.508731@2] PC is at flush_dcache_page+0x0/0x30
[   12.513387@2] LR is at rq_flush_dcache_pages+0x68/0x120
[   12.518557@2] pc : [<ffffff8009091e40>] lr : [<ffffff80092435b0>] pstate: 80000145
[   12.526060@2] sp : ffffffc00de5fcc0
[   12.529511@2] x29: ffffffc00de5fcc0 x28: ffffff8009779350
[   12.534953@2] x27: ffffff8009676838 x26: ffffff80097a5e5b
[   12.540379@2] x25: 0000000000000001 [   12.540791@0] sh[1265]: unhandled level 2 translation fault (11) at 0x20000100, esr 0x92000006
[   12.540797@0] pgd = ffffffc00c437000
[   12.540800@0] [20000100] *pgd=000000000dac5003
[   12.540802@0] , *pud=000000000dac5003, *pmd=0000000000000000
[   12.540816@0] CPU: 0 PID: 1265 Comm: sh Not tainted 4.9.61 #1
[   12.540818@0] Hardware name: Amlogic (DT)
[   12.540822@0] task: ffffffc00d9c1000 task.stack: ffffffc00c464000
[   12.540830@0] PC is at 0xf7719cfc
[   12.540833@0] LR is at 0xf7719d08
[   12.540836@0] pc : [<00000000f7719cfc>] lr : [<00000000f7719d08>] pstate: 200f0010
[   12.540838@0] sp : 00000000ff8538f0
[   12.540840@0] x12: 00000000ffffffff
[   12.540844@0] x11: 0000000000000000
[   12.540846@0] x10: 00000000f762dc84 x9 : 00000000f75df175
[   12.540852@0] x8 : 00000000f7737638 x7 : 0000000000000001
[   12.540858@0] x6 : 00000000f7736b98 x5 : 00000000f762e159
[   12.540863@0] x4 : 0000000020000100 x3 : 0000000060000000
[   12.540869@0] x2 : 000000008d85ce60 x1 : 00000000f77378a4
[   12.540875@0] x0 : 000000000000002d
[   12.542309@3] MdsIotdcmConnec[1170]: unhandled level 1 translation fault (11) at 0x7ec46c70, esr 0x92000005
[   12.542315@3] pgd = ffffffc00e333000
[   12.542318@3] [7ec46c70] *pgd=0000000000000000
[   12.542320@3] , *pud=0000000000000000
[   12.542332@3] CPU: 3 PID: 1170 Comm: MdsIotdcmConnec Not tainted 4.9.61 #1
[   12.542334@3] Hardware name: Amlogic (DT)
[   12.542338@3] task: ffffffc00d9cf000 task.stack: ffffffc00da04000
[   12.542345@3] PC is at 0xf64d3070
[   12.542348@3] LR is at 0xf64d2ff8
[   12.542351@3] pc : [<00000000f64d3070>] lr : [<00000000f64d2ff8>] pstate: 200f0010
[   12.542353@3] sp : 00000000f44fe1e0
[   12.542355@3] x12: 00000000ffffffff
[   12.542359@3] x11: 00000000f44fe238
[   12.542361@3] x10: 00000000f44fe418 x9 : 00000000f65c2190
[   12.542367@3] x8 : 00000000ffffffff x7 : 00000000f65c1fe8
[   12.542372@3] x6 : 0000000000000049 x5 : 000000007ec46c70
[   12.542378@3] x4 : 00000000f65de000 x3 : 00000000f65dfb58
[   12.542384@3] x2 : 000000000000004c x1 : 00000000f65c1fe8
[   12.542389@3] x0 : 0000000000000012
[   12.730128@2] x24: ffffffc00e406a80 x23: ffffffc00e5ab000 x22: 000000000000000a
[   12.737458@2] x21: 0000000000000000 x20: 0000000000011c00
[   12.742892@2] x19: 0000000000000400 x18: 0000000000000000
[   12.748326@2] x17: 0000000000000000 x16: 0000000000000000
[   12.753759@2] x15: 0000000000000000 x14: b48aa6fef4ea9f78
[   12.759194@2] x13: 6a8df10042f92f14 x12: 94fd0f0e9b7bf47e
[   12.764627@2] x11: 0000000000000008 x10: 0101010101010101
[   12.770061@2] x9 : 0000000000000010 x8 : 7f7f7f7f7f7f7f7f
[   12.775494@2] x7 : 000000000000000f x6 : 0000000000000000
[   12.780928@2] x5 : 0000000000000002 x4 : 0000000000000000
[   12.786362@2] x3 : 0000000000000001 x2 : ffffffc00e5ab0a0
[   12.791796@2] x1 : ffffffc00e5ab000 x0 : fafe5fc0afeb7940
[   12.797232@2]
[   12.797232@2] SP: 0xffffffc00de5fc40:
[   12.802491@2] fc40  0000000a 00000000 0e5ab000 ffffffc0 0e406a80 ffffffc0 00000001 00000000
[   12.810770@2] fc60  097a5e5b ffffff80 09676838 ffffff80 09779350 ffffff80 0de5fcc0 ffffffc0
[   12.819050@2] fc80  092435b0 ffffff80 0de5fcc0 ffffffc0 09091e40 ffffff80 80000145 00000000
[   12.827330@2] fca0  014c5e00 00000000 0dc9f768 ffffffc0 ffffffff ffffffff 09309660 ffffff80
[   12.835610@2] fcc0  0de5fd20 ffffffc0 09309680 ffffff80 00000000 00000000 0ba87000 ffffffc0
[   12.843890@2] fce0  09779350 ffffff80 0000a630 00000000 0ddc3c00 ffffffc0 0e6b79d8 ffffffc0
[   12.852170@2] fd00  0dc9f768 ffffffc0 0ddc3c20 ffffffc0 096bc000 ffffff80 00000200 00000000
[   12.860450@2] fd20  0de5fd80 ffffffc0 090ace60 ffffff80 0ddc3c80 ffffffc0 0de19240 ffffffc0
[   12.868732@2]
[   12.868732@2] X1: 0xffffffc00e5aaf80:
[   12.873992@2] af80  5cfce04c 3feede7b 3b51a72f 3c8507c2 6067718b bfc6cc82 dbfc430f 3c6d00ca
[   12.882271@2] afa0  4fbf6fe8 bfd10bb0 53749c72 3c321748 699a36ad 3fc47046 3994d40c bc63924c
[   12.890551@2] afc0  0dfb7483 3fbb6338 42ee5820 bfc15bb5 385194fc bf9f879b 57d040e9 3fbbaa05
[   12.898831@2] afe0  ada71ca0 bf895566 00000000 3fc90000 e2879c29 3fc8b06e 30308c4f bc6118cd
[   12.907111@2] b000  0feb3fc0 ffffffc0 00000c00 00000400 0feb5740 ffffffc0 00001000 00000000
[   12.915391@2] b020  0feb5780 ffffffc0 00001000 00000000 0feb57c0 ffffffc0 00001000 00000000
[   12.923671@2] b040  0feb5800 ffffffc0 00001000 00000000 0feb5840 ffffffc0 00001000 00000000
[   12.931951@2] b060  0feb5880 ffffffc0 00001000 00000000 0feb58c0 ffffffc0 00001000 00000000
[   12.940233@2]
[   12.940233@2] X2: 0xffffffc00e5ab020:
[   12.945493@2] b020  0feb5780 ffffffc0 00001000 00000000 0feb57c0 ffffffc0 00001000 00000000
[   12.953773@2] b040  0feb5800 ffffffc0 00001000 00000000 0feb5840 ffffffc0 00001000 00000000
[   12.962053@2] b060  0feb5880 ffffffc0 00001000 00000000 0feb58c0 ffffffc0 00001000 00000000
[   12.970333@2] b080  0feb5900 ffffffc0 00001000 00000000 0feb5940 ffffffc0 00000c00 00000000
[   12.978613@2] b0a0  afeb7940 fafe5fc0 00000400 00000c00 0feb5980 ffffffc0 00001000 00000000
[   12.986893@2] b0c0  0feb59c0 ffffffc0 00001000 00000000 0feb5a00 ffffffc0 00001000 00000000
[   12.995173@2] b0e0  0feb5a40 ffffffc0 00001000 00000000 0feb5a80 ffffffc0 00001000 00000000
[   13.003453@2] b100  0feb5ac0 ffffffc0 00001000 00000000 0feb5b00 ffffffc0 00001000 00000000
[   13.011741@2]
[   13.011741@2] X23: 0xffffffc00e5aaf80:
[   13.017080@2] af80  5cfce04c 3feede7b 3b51a72f 3c8507c2 6067718b bfc6cc82 dbfc430f 3c6d00ca
[   13.025360@2] afa0  4fbf6fe8 bfd10bb0 53749c72 3c321748 699a36ad 3fc47046 3994d40c bc63924c
[   13.033640@2] afc0  0dfb7483 3fbb6338 42ee5820 bfc15bb5 385194fc bf9f879b 57d040e9 3fbbaa05
[   13.041920@2] afe0  ada71ca0 bf895566 00000000 3fc90000 e2879c29 3fc8b06e 30308c4f bc6118cd
[   13.050200@2] b000  0feb3fc0 ffffffc0 00000c00 00000400 0feb5740 ffffffc0 00001000 00000000
[   13.058480@2] b020  0feb5780 ffffffc0 00001000 00000000 0feb57c0 ffffffc0 00001000 00000000
[   13.066760@2] b040  0feb5800 ffffffc0 00001000 00000000 0feb5840 ffffffc0 00001000 00000000
[   13.075040@2] b060  0feb5880 ffffffc0 00001000 00000000 0feb58c0 ffffffc0 00001000 00000000
[   13.083321@2]
[   13.083321@2] X24: 0xffffffc00e406a00:
[   13.088668@2] 6a00  00004000 00000001 091d69b0 ffffff80 0e2554c0 ffffffc0 00130005 00000001
[   13.096948@2] 6a20  0e56f800 ffffffc0 0e68ec80 ffffffc0 00000000 00000000 ffffffff ffffffff
[   13.105228@2] 6a40  00000000 00000000 09762128 ffffff80 0e70bd00 ffffffc0 00000000 00000000
[   13.113508@2] 6a60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   13.121788@2] 6a80  00000000 00000000 0e803300 ffffffc0 00000000 00000000 00005002 00000000
[   13.130068@2] 6aa0  0000a62a 00000000 0001b400 00000000 00000000 00000000 00000005 00000c00
[   13.138348@2] 6ac0  00001800 00000001 091d69b0 ffffff80 0e255500 ffffffc0 006e001d 00000001
[   13.146628@2] 6ae0  0e5ab000 ffffffc0 0e68ec80 ffffffc0 0ebe7888 ffffffc0 0ebe7b60 ffffffc0
[   13.154910@2]
[   13.154910@2] X29: 0xffffffc00de5fc40:
[   13.160255@2] fc40  0000000a 00000000 0e5ab000 ffffffc0 0e406a80 ffffffc0 00000001 00000000
[   13.168535@2] fc60  097a5e5b ffffff80 09676838 ffffff80 09779350 ffffff80 0de5fcc0 ffffffc0
[   13.176815@2] fc80  092435b0 ffffff80 0de5fcc0 ffffffc0 09091e40 ffffff80 80000145 00000000
[   13.185095@2] fca0  014c5e00 00000000 0dc9f768 ffffffc0 ffffffff ffffffff 09309660 ffffff80
[   13.193375@2] fcc0  0de5fd20 ffffffc0 09309680 ffffff80 00000000 00000000 0ba87000 ffffffc0
[   13.201655@2] fce0  09779350 ffffff80 0000a630 00000000 0ddc3c00 ffffffc0 0e6b79d8 ffffffc0
[   13.209936@2] fd00  0dc9f768 ffffffc0 0ddc3c20 ffffffc0 096bc000 ffffff80 00000200 00000000
[   13.218215@2] fd20  0de5fd80 ffffffc0 090ace60 ffffff80 0ddc3c80 ffffffc0 0de19240 ffffffc0
[   13.226495@2]
[   13.228137@2] Process kworker/2:1 (pid: 541, stack limit = 0xffffffc00de5c020)
[   13.235295@2] Stack: (0xffffffc00de5fcc0 to 0xffffffc00de60000)
[   13.241162@2] fcc0: ffffffc00de5fd20 ffffff8009309680 0000000000000000 ffffffc00ba87000
[   13.249096@2] fce0: ffffff8009779350 000000000000a630 ffffffc00ddc3c00 ffffffc00e6b79d8
[   13.257031@2] fd00: ffffffc00dc9f768 ffffffc00ddc3c20 ffffff80096bc000 0000000000000200
[   13.264966@2] fd20: ffffffc00de5fd80 ffffff80090ace60 ffffffc00ddc3c80 ffffffc00de19240
[   13.272901@2] fd40: ffffffc00fba96c0 ffffffc00fbb0400 0000000000000000 0000000000000000
[   13.280836@2] fd60: ffffff80097625e0 0000000000000000 ffffff8009756000 0000000000000000
[   13.288771@2] fd80: ffffffc00de5fdc0 ffffff80090ad264 ffffffc00de19240 ffffff8009756000
[   13.296706@2] fda0: ffffffc00fba96c0 ffffffc00de19270 ffffffc00fba96e0 ffffffc00de5c000
[   13.304641@2] fdc0: ffffffc00de5fe20 ffffff80090b2b58 ffffffc00f594d40 ffffff80097ac4d0
[   13.312576@2] fde0: ffffff800965e970 ffffffc00de19240 ffffff80090acfc8 0000000000000000
[   13.320511@2] fe00: 0000000000000000 0000000000000000 0000000000000000 ffffffc00de19240
[   13.328446@2] fe20: 0000000000000000 ffffff8009082680 ffffff80090b2a68 ffffffc00f594d40
[   13.336381@2] fe40: 0000000000000000 0000000000000000 0000000000000000 ffffff8009555508
[   13.344316@2] fe60: ffffffc00de5fe70 0000000000000000 ffffffc00de5fea0 ffffffc00de19240
[   13.352251@2] fe80: ffffff8000000000 ffffffc000000000 ffffffc00de5fe90 ffffffc00de5fe90
[   13.360186@2] fea0: 0000000000000000 ffffff8000000000 ffffffc00de5feb0 ffffffc00de5feb0
[   13.368121@2] fec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.376056@2] fee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.383991@2] ff00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.391926@2] ff20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.399861@2] ff40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.407796@2] ff60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.415731@2] ff80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.423666@2] ffa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   13.431601@2] ffc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
[   13.439536@2] ffe0: 0000000000000000 0000000000000000 ffffff80090b4cb0 0000000000000000
[   13.447469@2] Call trace:
[   13.450059@2] Exception stack(0xffffffc00de5faf0 to 0xffffffc00de5fc20)
[   13.456613@2] fae0:                                   0000000000000400 0000008000000000
[   13.464549@2] fb00: ffffffc00de5fcc0 ffffff8009091e40 ffffffc00de5fb40 ffffff800908a78c
[   13.472483@2] fb20: 0000000000000001 ffffff8009555180 ffffffc00de5fb80 ffffff80090cff5c
[   13.480418@2] fb40: ffffff8009846450 0000000000000140 0000000000000003 0000000000000001
[   13.488354@2] fb60: ffffffc00de5fb70 ffffff80095554c8 ffffffc00de5fb80 ffffff80090cff68
[   13.496288@2] fb80: ffffffc00de5fbc0 ffffff800930b61c fafe5fc0afeb7940 ffffffc00e5ab000
[   13.504223@2] fba0: ffffffc00e5ab0a0 0000000000000001 0000000000000000 0000000000000002
[   13.512158@2] fbc0: 0000000000000000 000000000000000f 7f7f7f7f7f7f7f7f 0000000000000010
[   13.520093@2] fbe0: 0101010101010101 0000000000000008 94fd0f0e9b7bf47e 6a8df10042f92f14
[   13.528029@2] fc00: b48aa6fef4ea9f78 0000000000000000 0000000000000000 0000000000000000
[   13.535971@2] [<ffffff8009091e40>] flush_dcache_page+0x0/0x30
[   13.541657@2] [<ffffff8009309680>] mtd_blktrans_work+0x210/0x340
[   13.547609@2] [<ffffff80090ace60>] process_one_work+0x1e0/0x348
[   13.553472@2] [<ffffff80090ad264>] worker_thread+0x29c/0x4b8
[   13.559080@2] [<ffffff80090b2b58>] kthread+0xf0/0xf8
[   13.563996@2] [<ffffff8009082680>] ret_from_fork+0x10/0x50
[   13.569431@2] Code: 940741cc a8c17bfd d65f03c0 00000000 (f9400001)
[   13.575742@2] ---[ end trace b07b18411c4f595d ]---
[   13.576021@1] wl_android_wifi_on: Success
[   13.590164@0] modprobe[1267]: unhandled level 2 translation fault (11) at 0x24002400, esr 0x92000006
[   13.593667@0] pgd = ffffffc00dac5000
[   13.595777@2] Unable to handle kernel paging request at virtual address ffffffffffffffd8
[   13.595781@2] pgd = ffffffc00e333000
[   13.595788@2] [ffffffffffffffd8] *pgd=0000000000000000, *pud=0000000000000000
[   13.595793@2] Internal error: Oops: 96000005 [#2] PREEMPT SMP
[   13.595837@2] Modules linked in: dhd iptable_mangle iptable_filter ipt_REJECT ip_tables xt_time xt_tcpudp xt_multiport xt_mark xt_mac xt_limit xt_comment xt_TCPMSS xt_LOG x_tables uinput nf_reject_ipv4 nf_log_ipv4 nf_log_common hci_uart btusb btintel cyttsp_button snd_compress snd_pcm_oss snd_mixer_oss miso is31fl3236a
GMT+8, 2026-1-22 16:56 , Processed in 0.401771 second(s), 10 queries , MemCached On.
