查看: 1134|回复: 0
[求助] 小米AI智能音箱,开机亮灯,无法联网,大神帮忙看看
发表于 2023-7-8 23:00:54 | 显示全部楼层 |阅读模式
U-Boot 2015.01 (Dec 24 2019 - 07:00:02), Build: jenkins-Mico_s12a_Please press Enter to activate this console.
ota_publisrS12A login: t_blk=32
nkey : phy_blk_addr=33, ec=0, phy_page_addr=0, timesta================================
mp=2pipe try (micocfg_sn)
nkey free list:
blockN=32, ec=0, dirty_flag=1
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
pipe try (micocfg_channel)
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=16
[ 1997.698396@3] pgd = ffffffc00dd2d000
[ 1997.701962@3] [aaaaaaa7] *pgd=0000000000000000, *pud=0000000000000000
nkey valid addr: 42000 ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=64
aml_nand_scan_rsv_info 1254
ndtb valid addr: 520000
tpl: off 8388608, size 8388608
NAND bbt detect factory Bad block at 4060000
aml_nand_add_partition:1794 factory bad addr=203
NAND bbt detect factory Bad block at 7fe0000
Creating 6 MTD partitions on "M Generation NAND 1Gib FS33ND01GS108TFI0":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001800000 : "boot0"
0x000001800000-0x000002000000 : "boot1"
0x000002000000-0x000004000000 : "system0"
0x000004000000-0x000006020000 : "system1"
0x000006020000-0x000008000000 : "data"
M Generation NAND 1Gib FS33ND01GS108TFI0 initialized ok
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 330000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 520000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      GZIP format, decompress...
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 5 dtbs.
        aml_dt soc: xiaomi platform: s12c variant: v02
        dtb 0 soc: xiaomi   plat: s12   vari: v1
        dtb 1 soc: xiaomi   plat: s12a   vari: v01
        dtb 2 soc: xiaomi   plat: s12c   vari: v01
        dtb 3 soc: xiaomi   plat: s12c   vari: v02
        dtb 4 soc: xiaomi   plat: s12c   vari: v03
      Find match dtb: 3
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 420000
[EFUSE_MSG]keynum is 4
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
release_free_node 61: bitmap=1fffff
release_free_node 74: bitmap=1ffff7
aml_nand_save_rsv_info:716,save info to 300000
aml_nand_write_rsv:520,write info to 300000
[burnup]Rd:Up sz 0x3ac440 to align 0x1000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f0344e0
copy done
load dtb from 0x1000000 ......
      Single dtb detected
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x017a7808
   Loading Ramdisk to 0eea7000, end 0f004b95 ... OK
   Loading Device Tree to 000000000ee9b000, end 000000000eea62bf ... OK
Starting kernel ...
uboot time: 1532159 us
domain-0 init dvfs: 4
[    0.270816@1] ff803000.serial: clock gate not found
[    1.193894@3] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    1.194015@3] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
get key is 0x00 , curr_boot is boot0
Booting from boot0
/dev/mtdblock4 is ready now.
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
4Please press Enter to activate this console.
(none) login: [    5.276490@1] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.277121@1] cyttsp 0-0008: Failed to update firmware;
[    6.985422@1] name: mac_wifi, size 17
[    7.003142@0] name: mac_bt, size 17
micocfg[982]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[982]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[982]: UNLOCK fd: 3.
micocfg[982]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[982]: cfg get: success: /data/etc/device.info k:sn v:18090/883175425
micocfg[983]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[983]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[983]: UNLOCK fd: 3.
micocfg[983]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[983]: cfg get: success: /data/etc/device.info k:mac_wifi v:E4B:6D:82:0C:87
micocfg[984]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[984]: cfg get: success: Please press Enter to activate this console.
/usr/share/mico/systesS12A login: uccess: /usr/share/mico/system.cfg k:model v:S12A
micocfg[993]: UNLOCK fd: 3.
micocfg[993]: LOCK:ret(0) fd(3), ================================
path(pipe try (micocfg_sn)
micocfg[993]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[994]: LOCK:ret(0) fd(3), path(25): /var/lock/spipe try (micocfg_channel)
ystem.cfg.lock.
micocfg[994]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[994]: UNLOCK fd: 3.
micocfg[994]: bt_enable_set  argv[1] 1[ 1998.263612@1] pgd = ffffffc00d9d0000
[ 1998.267148@1] [aaaaaaa7] *pgd=0000000000000000
                                                 micoc *pud=0000000000000000
fg[994]: LOCK:ret(0) fd(25): /var/lock/system.cfg.lock.
micocfg[995]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[995]: UNLOCK fd: 3.
micocfg[995]: LOCK:ret(0) fd(3), path(28): /var/lock/messaging.cfg.lock.
micocfg[995]: No 'super_admin' setting in configuration file '/data/etc/messaging.cfg'
micocfg[995]: funtion uid result empty
micocfg[997]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[997]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[997]: UNLOCK fd: 3.
micocfg[997]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
ledserver[1037]: Build Time: Nov 26 2021 08:16:09
ledserver[1037]: starting
ledserver[1037]: LOCK:ret(0) fd(8), path(28): /var/lock/nightmode.cfg.lock.
ledserver[1037]: cfg get: success: /data/etc/nightmode.cfg k:total v:night
ledserver[1037]: UNLOCK fd: 8.
ledserver[1037]: cfg get: success: /data/etc/nightmode.cfg k:light v:night
ledserver[1037]: cfg get: success: /data/etc/nightmode.cfg k:volume v:night
ledserver[1037]: cfg get: success: /data/etc/nightmode.cfg k:start v:22:00
ledserver[1037]: cfg get: success: /data/etc/nightmode.cfg k:stop v:06:00
ledserver[1037]: handle_show start
ledserver[1037]: start_show effect_id is 4 is_working is 0
ledserver[1037]: start_show end
ledserver[1037]: thread_push_led start
ledserver[1037]: handle_show stop
ledserver[1037]: thread_push_led end
crond[1059]: crond (busybox 1.27.2) started, log level 5
micocfg[1068]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1068]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[1068]: UNLOCK fd: 3.
micocfg[1068]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
ledserver[1037]: light_show_control 4
ledserver[1037]: open_light start
ledserver[1037]: light_show_effect 4
[   10.904974@1] pdm_dclk is : 0
[   12.377495@0] invalid toddr src
[   12.407901@2] pgd = ffffffc00e2c7000
[   12.407934@2] [01052104] *pgd=000000000d915003, *pud=000000000d915003, *pmd=0000000000000000
[   12.427474@1] pgd = ffffffc00d899000
[   12.427505@1] [050382c4] *pgd=000000000d871003, *pud=000000000d871003, *pmd=0000000000000000
[   12.466328@1] pgd = ffffffc00daa0000
[   12.466437@1] [00008004] *pgd=000000000d8e6003, *pud=000000000d8e6003, *pmd=000000000d8e5003, *pte=0000000000000000
[   12.481315@1] pgd = ffffffc00daa0000
[   12.481346@1] [81010400] *pgd=0000000000000000, *pud=0000000000000000
[   12.487635@0] pgd = ffffffc00d9f8000
[   12.489196@0] [81530040] *pgd=0000000000000000, *pud=0000000000000000
[   12.824997@0] pgd = ffffffc00d849000
[   12.825029@0] [fed1de68] *pgd=000000000da4f003, *pud=000000000da4f003, *pmd=0000000000000000
[   12.831834@2] pgd = ffffffc00e279000
[   12.834916@2] [84156d38] *pgd=0000000000000000, *pud=0000000000000000
[   13.539066@0] pgd = ffffffc00e274000
[   13.539098@0] [2501165c] *pgd=000000000e2dc003, *pud=000000000e2dc003, *pmd=0000000000000000
^C[   18.487910@2] pgd = ffffffc00d885000
[   18.487942@2] [f314220c] *pgd=000000000d81f003, *pud=000000000d81f003, *pmd=0000000000000000
S12A login:
S12A login: [   23.515596@2] pgd = ffffffc00e3b4000
[   23.515628@2] [7241178c] *pgd=0000000000000000, *pud=0000000000000000
S12A login: 122
[   26.612691@2] pgd = ffffffc00e3b4000
[   26.612722@2] [fb058388] *pgd=000000000e34a003, *pud=000000000e34a003, *pmd=000000000Please press Enter to activate this console.
0000000
pipe try (micocfg_channel]S12A login:  [f63222c4] *pgd=000000000d915003, *pud=000000000d915003, *pmd=0000000000000000
[   62.559251@3] pgd = ffffffc00dd4f000
[   62.559282@3] [f2ab6648] *pgd=000000000d8ec003, *pud=000000000d8ec003, *pmd=0000000000000000
[   68.289873@2] pdm_dclk is : 0
[   68.332204@1] invalid toddr src
Login timed out after 60 seconds
S12A login:
S12A login:
S12A login:
S12A login:
S12A login:
S12A login:
S12A login:
S12A login:
S12A login:
S12A login: 123456
try get user:magic[release]: F5B0B044
get user:123456
user 1[  554.602253@2] pgd = ffffffc00f7a4000
[  554.605680@2] [aaaaaaa7] *pgd=0000000000000000, *pud=0000000000000000
S12A login: F5B0B044
get user:F5B0B044
user[  593.858747@0] pgd = ffffffc00dae9000
[  593.862261@0] [aaaaaaa7] *pgd=0000000000000000, *pud=0000000000000000
S12A login:
S12A login:
S12A login:
S12A login:
S12A login:
S12A login:
S12A login: exit
get user:exit
user exi[ 1230.478385@0] pgd = ffffffc00dab1000
[ 1230.481880@0] [aaaaaaa7] *pgd=0000000000000000, *pud=0000000000000000
quit
S12A login: break
get user:break
user bre[ 1237.000413@1] pgd = ffffffc00d885000
[ 1237.003973@1] [aaaaaaa7] *pgd=0000000000000000, *pud=0000000000000000
quit
S12A login: reboot
get user:reboot
user reb[ 1246.319083@3] pgd = ffffffc00f7b3000
[ 1246.322624@3] [aaaaaaa7] *pgd=0000000000000000, *pud=0000000000000000
sas
S12A login: root
get user:root
user try login root
password:
>>>>>>>>>password_in=w12345
sign2 hexdecode error
Login incorrect
S12A login: root
get user:root
user try login root
password:
>>>>>>>>>password_in=qwert
Login incorrect
S12A login:
S12A login: root
get user:root
user try login root
password:
>>>>>>>>>password_in=b8a83ffdb1652e
dsa verify sign len 14:b8a83ffdb1652e, magic(len 8) F5B0B044
dsa verify sign len 7, digest(len 8) F5B0B044
DSA_verify err error:0D07207B:lib(13):func(114):reason(123)!
dsa verify failed
Login incorrect
S12A login:
root@mico:/# dropbear -r /data/etc/dropbear/dropbear_rsa_host_key -Eroot@mico:/# dropbear -r /data/etc/dropbear/dropbear_rsa_host_key -E
S12A login: root@mico:/# dropbear -r /data/etc/dropbear/dropbear_rsa_host_key -E
S12A login: ^@
get user:
user  try lo[ 2020.685477@3] pgd = ffffffc00db18000
[ 2020.688965@3] [aaaaaaa7] *pgd=0000000000000000, *pud=0000000000000000
AXG:BL1:d1dbf2:a4926f;FEAT:E0DC318C:2000OC:F;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
sdio debug board detected
TE: 23492
BL2 Built : 18:30:39, Aug 28 2018. axg g56303a2-dirty - liang.yang@droid11-sz
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 6
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 2d 0a 51 36 14 59 2a 06 4f 35 13 58 00 00 00 00 00 00 00 00 00 00 00 00 650   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
page0 page0->bbt:
0000000000000000000000000000000000000000000000000000000000000000
page0 bbt:
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x43
17 8d b0 63 59 1 ca 82 5d 50 52 f0 bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014529 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Dec 24 2019 - 07:00:02), Build: jenkins-Mico_s12a_ota_publish-379
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89690
NAND:  nand id: 0xec 0xf1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: ec f1 0 95 42 c6
NAND device: Manufacturer ID: 0xec, Chip ID: 0xec (Samsung M Generation NAND 1Gib FS33ND01GS108TFI0)
oob avail size 6
Creating 1 MTD partitions on "M Generation NAND 1Gib FS33ND01GS108TFI0":
0x000000000000-0x000000200000 : "bootloader"
nand id: 0xec 0xf1
PLANE change!
aml_nand_init obmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x400 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
nbbt valid addr: 280000
aml_nand_bbt_check 1389 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=24, ec=118, phy_page_addr=0, timestamp=239
nenv free list:
blockN=25, ec=117, dirty_flag=1
blockN=26, ec=1, dirty_flag=1
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=32
nenv valid addr: 300000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=33, ec=0, phy_page_addr=0, timestamp=2
nkey free list:
nkey valid addr: 420000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=41, ec=1, phy_page_addr=0, timestamp=4
ndtb free list:
blockN=40, ec=1, dirty_flag=1
blockN=42, ec=-1, dirty_flag=0
aml_key_init 170
MMC:
aml_nand_read_rsv_info:397,read nenv info to 300000
In:    serial
Out:   serial
Err:   serial
sub cmd dtb
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
      Multi dtb detected
      Support 5 dtbs.
      Find match dtb: 3
InUsbBurn
noSof
HAVE SN Code ...
aml_nand_save_rsv_info:716,save info to 310000
aml_nand_write_rsv:520,write info to 310000
save_power_post ...
reloc_addr =f0344e0
copy done
      Single dtb detected
Starting kernel ...
uboot time: 1771314 us
[    0.278276@3] ff803000.serial: clock gate not found
Booting from boot0
[    1.685457@0] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    1.685578@0] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
[    5.301343@2] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.302016@2] cyttsp 0-0008: Failed to update firmware;
[    7.007802@1] name: mac_wifi, size 17
[    7.025322@3] name: mac_bt, size 17
micocfg[981]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[981]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[981]: UNLOCK fd: 3.
micocfg[981]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[981]: cfg get: success: /data/etc/device.info k:sn v:18090/883175425
micocfg[982]: cfg get: success: /data/etc/device.info k:mac_wifi v:E4B:6D:82:0C:87
micocfg[983]: cfg get: success: /data/etc/device.info k:mac_bt v:E4B:6D:A0:91:07
micocfg[984]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[984]: UNLOCK fd: 3.
micocfg[984]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[984]: cfg get: success: /data/etc/device.info k:miio_did v:152051881
micocfg[985]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[985]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[985]: UNLOCK fd: 3.
micocfg[985]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[985]: cfg get: success: /data/etc/device.info k:miio_key v:e1ER7bQod6KFYjxQ
micocfg[986]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[986]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[986]: UNLOCK fd: 3.
micocfg[986]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[986]: cfg get: success: /data/etc/device.info k:board_id v:6
micocfg[990]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[990]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[990]: UNLOCK fd: 3.
micocfg[990]: cfg get: success: /usr/share/mico/system.cfg k:buildts v:1637912798
micocfg[992]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[992]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[992]: UNLOCK fd: 3.
micocfg[993]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[993]: bt_enable_set  argv[1] 1
micocfg[993]: LOCK:ret(0) fd(3), path(28): /var/lock/bluetooth.cfg.lock.
micocfg[993]: cfg update success: /data/bt/bluetooth.cfg k:enable v:1
micocfg[994]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[994]: LOCK:ret(0) fd(3), path(28): /var/lock/messaging.cfg.lock.
micocfg[994]: No 'super_admin' setting in configuration file '/data/etc/messaging.cfg'
micocfg[994]: funtion uid result empty
micocfg[996]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[996]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[996]: UNLOCK fd: 3.
micocfg[996]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
[   10.883306@3] pdm_dclk is : 0
[   12.290259@1] invalid toddr src
[   12.457629@0] pgd = ffffffc00da51000
[   12.457664@0] [f785e0a0] *pgd=000000000d9cd003, *pud=000000000d9cd003, *pmd=0000000000000000
[   12.483684@2] pgd = ffffffc00d8b3000
[   12.483718@2] [570a6040] *pgd=0000000000000000, *pud=0000000000000000
[   12.569691@1] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.571221@1] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.579589@0] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.585283@1] pgd = ffffffc00daae000
[   12.588724@1] [0004c8f0] *pgd=000000000e355003, *pud=000000000e355003, *pmd=000000000e28a003, *pte=0000000000000000
[   12.601323@3] VFS: brelse: Trying to free free buffer
[   12.607211@3] VFS: brelse: Trying to free free buffer
[   12.612411@3] VFS: brelse: Trying to free free buffer
[   12.617499@3] VFS: brelse: Trying to free free buffer
[   12.622466@3] VFS: brelse: Trying to free free buffer
[   12.627402@3] VFS: brelse: Trying to free free buffer
[   12.632483@3] VFS: brelse: Trying to free free buffer
[   12.637433@3] VFS: brelse: Trying to free free buffer
[   12.642298@3] VFS: brelse: Trying to free free buffer
[   12.647556@3] VFS: brelse: Trying to free free buffer
[   12.652540@3] VFS: brelse: Trying to free free buffer
[   12.657331@3] VFS: brelse: Trying to free free buffer
[   12.662545@2] VFS: brelse: Trying to free free buffer
[   12.667422@2] VFS: brelse: Trying to free free buffer
[   12.672411@2] VFS: brelse: Trying to free free buffer
[   12.677279@2] VFS: brelse: Trying to free free buffer
[   12.682466@2] VFS: brelse: Trying to free free buffer
[   12.687389@2] VFS: brelse: Trying to free free buffer
[   12.692961@2] VFS: brelse: Trying to free free buffer
[   12.697443@2] VFS: brelse: Trying to free free buffer
[   12.702447@2] VFS: brelse: Trying to free free buffer
[   12.707521@2] VFS: brelse: Trying to free free buffer
[   12.712457@2] VFS: brelse: Trying to free free buffer
[   12.717436@2] VFS: brelse: Trying to free free buffer
[   12.722845@2] VFS: brelse: Trying to free free buffer
[   12.727423@2] VFS: brelse: Trying to free free buffer
[   12.732364@2] VFS: brelse: Trying to free free buffer
[   12.737341@2] VFS: brelse: Trying to free free buffer
[   12.742575@2] VFS: brelse: Trying to free free buffer
[   12.747480@2] VFS: brelse: Trying to free free buffer
[   12.760620@2] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.762191@3] pgd = ffffffc00d891000
[   12.765601@2] [0004c8f0] *pgd=000000000da0d003, *pud=000000000da0d003, *pmd=000000000d80a003, *pte=0000000000000000
[   12.778275@3] VFS: brelse: Trying to free free buffer
[   12.784489@3] VFS: brelse: Trying to free free buffer
[   12.789228@3] VFS: brelse: Trying to free free buffer
[   12.794535@3] VFS: brelse: Trying to free free buffer
[   12.796470@0] pgd = ffffffc00e67a000
[   12.796629@1] pgd = ffffffc00daae000
[   12.796632@1] [00412edc] *pgd=000000000d8b0003
[   12.798288@3] VFS: brelse: Trying to free free buffer
[   12.800378@3] VFS: brelse: Trying to free free buffer
[   12.802434@3] VFS: brelse: Trying to free free buffer
[   12.803172@2] pgd = ffffffc00e67a000
[   12.803175@2] [00002500] *pgd=000000000e3b9003
[   12.804611@3] VFS: brelse: Trying to free free buffer
[   12.806665@3] VFS: brelse: Trying to free free buffer
[   12.808727@3] VFS: brelse: Trying to free free buffer
** 54 printk messages dropped ** [   12.810771@3] VFS: brelse: Trying to free free buffer
** 547 printk messages dropped ** [   12.812830@3] VFS: brelse: Trying to free free buffer
[   12.814840@3] VFS: brelse: Trying to free free buffer
** 813 printk messages dropped ** [   12.816796@3] VFS: brelse: Trying to free free buffer
** 3345 printk messages dropped ** [   12.824786@3] VFS: brelse: Trying to free free buffer
** 3560 printk messages dropped ** [   12.834888@3] VFS: brelse: Trying to free free buffer
** 2540 printk messages dropped ** [   12.842734@3] VFS: brelse: Trying to free free buffer
** 1518 printk messages dropped ** [   12.846478@3] VFS: brelse: Trying to free free buffer
[   12.856573@3] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.856709@3] pgd = ffffffc00d891000
[   12.856713@3] [0004c8f0] *pgd=000000000d8a7003
[   12.857843@0] pgd = ffffffc00e4e4000
[   12.857846@0] [a14c4f54] *pgd=0000000000000000
[   12.861740@0] VFS: brelse: Trying to free free buffer
[   12.863811@0] VFS: brelse: Trying to free free buffer
[   12.865987@0] VFS: brelse: Trying to free free buffer
[   12.868238@0] VFS: brelse: Trying to free free buffer
[   12.870270@0] VFS: brelse: Trying to free free buffer
[   12.872387@0] VFS: brelse: Trying to free free buffer
[   12.874405@0] VFS: brelse: Trying to free free buffer
[   12.876580@0] VFS: brelse: Trying to free free buffer
[   12.878621@0] VFS: brelse: Trying to free free buffer
[   12.880703@0] VFS: brelse: Trying to free free buffer
[   12.883000@0] VFS: brelse: Trying to free free buffer
[   12.884969@0] VFS: brelse: Trying to free free buffer
[   12.886989@0] VFS: brelse: Trying to free free buffer
[   12.889262@0] VFS: brelse: Trying to free free buffer
[   12.891269@0] VFS: brelse: Trying to free free buffer
[   12.893446@0] VFS: brelse: Trying to free free buffer
[   12.908693@0] pgd = ffffffc00e4e4000
[   12.908696@0] [76114624] *pgd=0000000000000000
[   13.017018@2] [00002500] *pgd=000000000e3b9003
[   13.091618@0] reboot: Restarting system
bl31 reboot reason: 0xd
bl31 reboot reason: 0x1
system cmd  1.
TE: 23745
set vcck to 1140 mv
Board ID = 6
CPU clk: 1200MHz
bist_test rank: 0 2e 0b 51 35 13 57 2a 06 4f 34 13 55 00 00 00 00 00 00 00 00 00 00 00 00 650   - PASS
AddrBus test pass!
NAND init
page0 page0->bbt:
page0 bbt:
OPS=0x43
bl30:axg thermal0
[0.014523 Inits done]
secure task start!
high task start!
low task start!
DRAM:  256 MiB
oob avail size 6
nand id: 0xec 0xf1
PLANE change!
oob avail size 8
nbbt free list:
nenv free list:
nenv valid addr: 310000
nkey free list:
ndtb free list:
aml_key_init 170
MMC:
aml_nand_read_rsv_info:397,read nenv info to 310000
In:    serial
Out:   serial
Err:   serial
sub cmd dtb
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
      Multi dtb detected
      Support 5 dtbs.
      Find match dtb: 3
aml_nand_save_rsv_info:716,save info to 320000
aml_nand_write_rsv:520,write info to 320000
save_power_post ...
reloc_addr =f0344e0
copy done
      Single dtb detected
   Loading Ramdisk to 0eea7000, end 0f004b7b ... OK
Starting kernel ...
uboot time: 1529291 us
[    0.297840@3] ff803000.serial: clock gate not found
get key is 0x00 , curr_boot is boot1
Booting from boot1
/dev/mtdblock5 is ready now.
[    2.017734@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    2.017861@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
rm: can't remove '/tmp/tmp.gIKOv1': No such file or directory
[    5.338350@3] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.338985@3] cyttsp 0-0008: Failed to update firmware;
[    7.039087@2] name: mac_wifi, size 17
[    7.056586@2] name: mac_bt, size 17
micocfg[984]: cfg get: success: /data/etc/device.info k:mac_bt v:E4B:6D:A0:91:07
micocfg[985]: cfg get: success: /data/etc/device.info k:miio_did v:152051881
micocfg[986]: cfg get: success: /data/etc/device.info k:miio_key v:e1ER7bQod6KFYjxQ
micocfg[987]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[987]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[987]: UNLOCK fd: 3.
micocfg[987]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[987]: cfg get: success: /data/etc/device.info k:board_id v:6
micocfg[991]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[991]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[991]: UNLOCK fd: 3.
micocfg[991]: cfg get: success: /usr/share/mico/system.cfg k:buildts v:1633919466
micocfg[994]: LOCK:ret(0) fd(3), path(28): /var/lock/bluetooth.cfg.lock.
micocfg[994]: cfg update success: /data/bt/bluetooth.cfg k:enable v:1
micocfg[995]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
ledserver[1037]: Build Time: Oct 11 2021 02:58:54
[   10.805438@1] pdm_dclk is : 0
[   12.288816@2] invalid toddr src
[   12.479544@1] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.498318@2] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.501350@2] pgd = ffffffc00dffd000
[   12.503271@2] [8100a404] *pgd=0000000000000000, *pud=0000000000000000
[   12.512623@1] pgd = ffffffc00d823000
[   12.513291@1] [8100a404] *pgd=0000000000000000, *pud=0000000000000000
[   12.522156@1] pgd = ffffffc00e257000
[   12.523123@1] [80470154] *pgd=0000000000000000, *pud=0000000000000000
[   12.544631@3] pgd = ffffffc00e45f000
[   12.544661@3] [a416dbcc] *pgd=0000000000000000, *pud=0000000000000000
[   12.560356@3] pgd = ffffffc00e45f000
[   12.560387@3] [a1084585] *pgd=0000000000000000, *pud=0000000000000000
[   12.574713@2] VFS: brelse: Trying to free free buffer
[   12.578019@2] VFS: brelse: Trying to free free buffer
[   12.592804@3] pgd = ffffffc00e45f000
[   12.592836@3] [98010cd1] *pgd=0000000000000000, *pud=0000000000000000
[   12.599501@2] pgd = ffffffc00e5b4000
[   12.600684@2] [f3fa4818] *pgd=000000000ddc3003, *pud=000000000ddc3003, *pmd=0000000000000000
[   12.786330@1] pgd = ffffffc00da87000
[   12.786361@1] [04102414] *pgd=000000000da24003, *pud=000000000da24003, *pmd=0000000000000000
[   12.865163@0] reboot: Restarting system
system cmd  1.
TE: 23503
set vcck to 1140 mv
Board ID = 6
CPU clk: 1200MHz
bist_test rank: 0 2e 0b 52 35 13 58 2c 08 50 34 13 56 00 00 00 00 00 00 00 00 00 00 00 00 650   - PASS
AddrBus test pass!
NAND init
page0 page0->bbt:
page0 bbt:
OPS=0x43
bl30:axg thermal0
[0.014520 Inits done]
secure task start!
high task start!
low task start!
DRAM:  256 MiB
oob avail size 6
nand id: 0xec 0xf1
PLANE change!
oob avail size 8
nbbt free list:
nenv : phy_blk_addr=25, ec=118, phy_page_addr=0, timestamp=240
nenv free list:
blockN=24, ec=118, dirty_flag=1
nenv valid addr: 320000
nkey free list:
ndtb free list:
aml_key_init 170
MMC:
aml_nand_read_rsv_info:397,read nenv info to 320000
In:    serial
Out:   serial
Err:   serial
sub cmd dtb
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
      Multi dtb detected
      Support 5 dtbs.
      Find match dtb: 3
aml_nand_save_rsv_info:716,save info to 330000
aml_nand_write_rsv:520,write info to 330000
save_power_post ...
reloc_addr =f0344e0
copy done
      Single dtb detected
Starting kernel ...
uboot time: 1518866 us
[    0.274510@0] ff803000.serial: clock gate not found
Booting from boot0
[    1.345628@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    1.345753@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
rm: can't remove '/tmp/tmp.Wjck4Y': No such file or directory
[    5.292397@1] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.293024@1] cyttsp 0-0008: Failed to update firmware;
[    7.002156@2] name: mac_wifi, size 17
[    7.019631@1] name: mac_bt, size 17
micocfg[991]: cfg get: success: /usr/share/mico/system.cfg k:buildts v:1637912798
crond[1058]: crond (busybox 1.27.2) started, log level 5
micocfg[1067]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1067]: cfg get: success: /usr/share/mico/system.cfg k:model v:S12A
micocfg[1067]: UNLOCK fd: 3.
micocfg[1067]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
[   10.875071@1] pdm_dclk is : 0
[   12.307727@1] invalid toddr src
[   12.420852@1] pgd = ffffffc00d4d3000
[   12.420889@1] [f8108708] *pgd=000000000de56003, *pud=000000000de56003, *pmd=0000000000000000
[   12.444284@3] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.465927@0] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.467422@1] pgd = ffffffc00de77000
[   12.470965@1] [0003c778] *pgd=000000000d518003, *pud=000000000d518003, *pmd=000000000d66c003, *pte=0000000000000000
[   12.483599@1] VFS: brelse: Trying to free free buffer
[   12.489454@1] VFS: brelse: Trying to free free buffer
[   12.494696@1] VFS: brelse: Trying to free free buffer
[   12.499654@1] VFS: brelse: Trying to free free buffer
[   12.504820@1] VFS: brelse: Trying to free free buffer
[   12.510288@1] VFS: brelse: Trying to free free buffer
[   12.514747@1] VFS: brelse: Trying to free free buffer
[   12.519747@1] VFS: brelse: Trying to free free buffer
[   12.524607@1] VFS: brelse: Trying to free free buffer
[   12.529726@1] VFS: brelse: Trying to free free buffer
[   12.534645@1] VFS: brelse: Trying to free free buffer
[   12.540212@1] VFS: brelse: Trying to free free buffer
[   12.544725@1] VFS: brelse: Trying to free free buffer
[   12.549690@1] VFS: brelse: Trying to free free buffer
[   12.554701@1] VFS: brelse: Trying to free free buffer
[   12.559773@1] VFS: brelse: Trying to free free buffer
[   12.564757@1] VFS: brelse: Trying to free free buffer
[   12.570185@1] VFS: brelse: Trying to free free buffer
[   12.574822@2] VFS: brelse: Trying to free free buffer
[   12.579633@2] VFS: brelse: Trying to free free buffer
[   12.584715@2] VFS: brelse: Trying to free free buffer
[   12.589646@2] VFS: brelse: Trying to free free buffer
[   12.594677@2] VFS: brelse: Trying to free free buffer
[   12.599677@2] VFS: brelse: Trying to free free buffer
[   12.604645@2] VFS: brelse: Trying to free free buffer
[   12.609619@2] VFS: brelse: Trying to free free buffer
[   12.614714@2] VFS: brelse: Trying to free free buffer
[   12.619607@2] VFS: brelse: Trying to free free buffer
[   12.624734@2] VFS: brelse: Trying to free free buffer
[   12.629733@2] VFS: brelse: Trying to free free buffer
[   12.634749@2] VFS: brelse: Trying to free free buffer
[   12.639625@2] VFS: brelse: Trying to free free buffer
[   12.644736@2] VFS: brelse: Trying to free free buffer
[   12.649605@2] VFS: brelse: Trying to free free buffer
[   12.654751@2] VFS: brelse: Trying to free free buffer
[   12.659741@2] VFS: brelse: Trying to free free buffer
[   12.664801@2] VFS: brelse: Trying to free free buffer
[   12.669811@2] VFS: brelse: Trying to free free buffer
[   12.674718@2] VFS: brelse: Trying to free free buffer
[   12.679761@2] VFS: brelse: Trying to free free buffer
[   12.684776@2] VFS: brelse: Trying to free free buffer
[   12.689771@2] VFS: brelse: Trying to free free buffer
[   12.694781@2] VFS: brelse: Trying to free free buffer
[   12.699790@2] VFS: brelse: Trying to free free buffer
[   12.704687@2] VFS: brelse: Trying to free free buffer
[   12.709793@2] VFS: brelse: Trying to free free buffer
[   12.714673@2] VFS: brelse: Trying to free free buffer
[   12.719792@2] VFS: brelse: Trying to free free buffer
[   12.724671@2] VFS: brelse: Trying to free free buffer
[   12.729839@2] VFS: brelse: Trying to free free buffer
[   12.734787@2] VFS: brelse: Trying to free free buffer
[   12.739696@2] VFS: brelse: Trying to free free buffer
[   12.744775@2] VFS: brelse: Trying to free free buffer
[   12.752869@2] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.754393@3] pgd = ffffffc00de77000
[   12.757866@2] [0003c778] *pgd=000000000d4d3003, *pud=000000000d4d3003, *pmd=000000000d4e8003, *pte=0000000000000000
[   12.770471@3] VFS: brelse: Trying to free free buffer
[   12.776622@3] VFS: brelse: Trying to free free buffer
[   12.781549@3] VFS: brelse: Trying to free free buffer
[   12.786665@3] VFS: brelse: Trying to free free buffer
[   12.790322@1] pgd = ffffffc00de6c000
[   12.791173@3] VFS: brelse: Trying to free free buffer
[   12.793221@3] VFS: brelse: Trying to free free buffer
[   12.795301@3] VFS: brelse: Trying to free free buffer
[   12.797310@3] VFS: brelse: Trying to free free buffer
[   12.799320@3] VFS: brelse: Trying to free free buffer
[   12.801302@3] VFS: brelse: Trying to free free buffer
[   12.803460@3] VFS: brelse: Trying to free free buffer
[   12.805467@3] VFS: brelse: Trying to free free buffer
[   12.807364@3] VFS: brelse: Trying to free free buffer
[   12.809193@3] VFS: brelse: Trying to free free buffer
[   12.811149@3] VFS: brelse: Trying to free free buffer
[   12.813122@3] VFS: brelse: Trying to free free buffer
** 1395 printk messages dropped ** [   12.817034@3] VFS: brelse: Trying to free free buffer
** 3085 printk messages dropped ** [   12.824752@3] VFS: brelse: Trying to free free buffer
** 3091 printk messages dropped ** [   12.832601@3] VFS: brelse: Trying to free free buffer
** 2230 printk messages dropped ** [   12.838532@3] VFS: brelse: Trying to free free buffer
[   12.840372@3] VFS: brelse: Trying to free free buffer
[   12.842376@3] VFS: brelse: Trying to free free buffer
[   12.844334@3] VFS: brelse: Trying to free free buffer
[   12.846238@3] VFS: brelse: Trying to free free buffer
[   12.848059@3] VFS: brelse: Trying to free free buffer
[   12.849890@3] VFS: brelse: Trying to free free buffer
[   12.851734@3] VFS: brelse: Trying to free free buffer
[   12.853666@3] VFS: brelse: Trying to free free buffer
[   12.855627@3] VFS: brelse: Trying to free free buffer
[   12.857674@3] VFS: brelse: Trying to free free buffer
[   12.859751@3] VFS: brelse: Trying to free free buffer
[   12.861709@3] VFS: brelse: Trying to free free buffer
[   12.863664@3] VFS: brelse: Trying to free free buffer
[   12.865637@3] VFS: brelse: Trying to free free buffer
[   12.867713@2] VFS: brelse: Trying to free free buffer
[   12.869867@2] VFS: brelse: Trying to free free buffer
[   12.871813@2] VFS: brelse: Trying to free free buffer
[   12.879040@0] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.879180@2] pgd = ffffffc00de77000
[   12.879183@2] [0003c778] *pgd=000000000d4c6003
[   12.886899@0] pgd = ffffffc00d4fe000
[   12.886903@0] [a4008000] *pgd=0000000000000000
[   12.899618@0] pgd = ffffffc00d4f1000
[   12.899622@0] [2000a000] *pgd=000000000d44c003
[   12.900743@0] pgd = ffffffc00e55e000
[   12.900748@0] [0110f3ac] *pgd=000000000e6dd003
[   12.966801@0] pgd = ffffffc00d673000
[   12.966805@0] [81092880] *pgd=0000000000000000
[   13.008357@0] pgd = ffffffc00d4fe000
[   13.008360@0] [04091195] *pgd=000000000d5e0003
[   13.023529@1] [e28dd00c] *pgd=000000000e3cd003
system cmd  1.
TE: 23503
set vcck to 1140 mv
Board ID = 6
CPU clk: 1200MHz
bist_test rank: 0 2e 0b 52 35 13 57 2b 08 4f 34 12 56 00 00 00 00 00 00 00 00 00 00 00 00 650   - PASS
AddrBus test pass!
NAND init
page0 page0->bbt:
page0 bbt:
OPS=0x43
bl30:axg thermal0
secure task start!
high task start!
low task start!
DRAM:  256 MiB
oob avail size 6
nand id: 0xec 0xf1
PLANE change!
oob avail size 8
nbbt free list:
nenv : phy_blk_addr=24, ec=119, phy_page_addr=0, timestamp=241
nenv free list:
blockN=25, ec=118, dirty_flag=1
nkey free list:
ndtb free list:
aml_key_init 170
MMC:
In:    serial
Out:   serial
Err:   serial
sub cmd dtb
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
      Multi dtb detected
      Support 5 dtbs.
      Find match dtb: 3
save_power_post ...
reloc_addr =f0344e0
copy done
      Single dtb detected
Starting kernel ...
uboot time: 1520042 us
[    0.279976@1] ff803000.serial: clock gate not found
Booting from boot0
[    1.568178@1] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    1.568301@1] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
rm: can't remove '/tmp/tmp.4Zu8AZ': No such file or directory
[    5.277932@0] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.278565@0] cyttsp 0-0008: Failed to update firmware;
[    6.949215@2] name: mac_wifi, size 17
[    6.966935@0] name: mac_bt, size 17
[   10.807801@3] pdm_dclk is : 0
[   12.227964@2] invalid toddr src
[   12.384956@2] pgd = ffffffc00d8d2000
[   12.384998@2] [0107dda8] *pgd=000000000da34003, *pud=000000000da34003, *pmd=0000000000000000
[   12.393167@1] pgd = ffffffc00d861000
[   12.394847@1] [172c80f5] *pgd=000000000d822003, *pud=000000000d822003, *pmd=0000000000000000
[   12.408795@1] pgd = ffffffc00d861000
[   12.408830@1] [f763c390] *pgd=000000000d9e5003, *pud=000000000d9e5003, *pmd=000000000d9e2003, *pte=0000000000000000
[   12.444059@0] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.459738@1] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.461224@2] pgd = ffffffc00da9c000
[   12.465300@2] [0004c8f0] *pgd=000000000da20003, *pud=000000000da20003, *pmd=000000000da9d003, *pte=0000000000000000
[   12.477820@2] VFS: brelse: Trying to free free buffer
[   12.483332@2] VFS: brelse: Trying to free free buffer
[   12.488399@2] VFS: brelse: Trying to free free buffer
[   12.493521@2] VFS: brelse: Trying to free free buffer
[   12.498473@2] VFS: brelse: Trying to free free buffer
[   12.503379@2] VFS: brelse: Trying to free free buffer
[   12.508535@2] VFS: brelse: Trying to free free buffer
[   12.513379@2] VFS: brelse: Trying to free free buffer
[   12.518601@2] VFS: brelse: Trying to free free buffer
[   12.523509@2] VFS: brelse: Trying to free free buffer
[   12.528528@2] VFS: brelse: Trying to free free buffer
[   12.533480@2] VFS: brelse: Trying to free free buffer
[   12.538471@2] VFS: brelse: Trying to free free buffer
[   12.543618@2] VFS: brelse: Trying to free free buffer
[   12.548365@2] VFS: brelse: Trying to free free buffer
[   12.553528@2] VFS: brelse: Trying to free free buffer
[   12.558514@2] VFS: brelse: Trying to free free buffer
[   12.563446@2] VFS: brelse: Trying to free free buffer
[   12.568533@2] VFS: brelse: Trying to free free buffer
[   12.573424@2] VFS: brelse: Trying to free free buffer
[   12.578468@2] VFS: brelse: Trying to free free buffer
[   12.583555@2] VFS: brelse: Trying to free free buffer
[   12.588583@2] VFS: brelse: Trying to free free buffer
[   12.593441@2] VFS: brelse: Trying to free free buffer
[   12.598522@2] VFS: brelse: Trying to free free buffer
[   12.603489@2] VFS: brelse: Trying to free free buffer
[   12.608498@2] VFS: brelse: Trying to free free buffer
[   12.613582@2] VFS: brelse: Trying to free free buffer
[   12.618430@2] VFS: brelse: Trying to free free buffer
[   12.623471@2] VFS: brelse: Trying to free free buffer
[   12.628644@2] VFS: brelse: Trying to free free buffer
[   12.633502@2] VFS: brelse: Trying to free free buffer
[   12.638514@2] VFS: brelse: Trying to free free buffer
[   12.643554@2] VFS: brelse: Trying to free free buffer
[   12.648450@2] VFS: brelse: Trying to free free buffer
[   12.653628@2] VFS: brelse: Trying to free free buffer
[   12.658489@2] VFS: brelse: Trying to free free buffer
[   12.663519@2] VFS: brelse: Trying to free free buffer
[   12.668602@2] VFS: brelse: Trying to free free buffer
[   12.673476@2] VFS: brelse: Trying to free free buffer
[   12.678566@2] VFS: brelse: Trying to free free buffer
[   12.683687@2] VFS: brelse: Trying to free free buffer
[   12.688646@2] VFS: brelse: Trying to free free buffer
[   12.693485@2] VFS: brelse: Trying to free free buffer
[   12.698555@2] VFS: brelse: Trying to free free buffer
[   12.703591@2] VFS: brelse: Trying to free free buffer
[   12.722963@2] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.723405@0] pgd = ffffffc00dfc0000
[   12.723415@0] [d4e15c74] *pgd=000000000dd7d003, *pud=000000000dd7d003, *pmd=0000000000000000
[   12.736413@1] pgd = ffffffc00da9c000
[   12.739882@2] [0004c8f0] *pgd=000000000da36003, *pud=000000000da36003, *pmd=000000000da2b003, *pte=0000000000000000
[   12.752361@3] VFS: brelse: Trying to free free buffer
[   12.758742@3] VFS: brelse: Trying to free free buffer
[   12.763487@3] VFS: brelse: Trying to free free buffer
[   12.768583@3] VFS: brelse: Trying to free free buffer
[   12.773587@3] VFS: brelse: Trying to free free buffer
[   12.778586@3] VFS: brelse: Trying to free free buffer
[   12.783622@3] VFS: brelse: Trying to free free buffer
[   12.788628@3] VFS: brelse: Trying to free free buffer
[   12.793614@3] VFS: brelse: Trying to free free buffer
[   12.798512@3] VFS: brelse: Trying to free free buffer
[   12.803709@3] VFS: brelse: Trying to free free buffer
[   12.808483@3] VFS: brelse: Trying to free free buffer
[   12.813585@3] VFS: brelse: Trying to free free buffer
[   12.818582@3] VFS: brelse: Trying to free free buffer
[   12.823629@3] VFS: brelse: Trying to free free buffer
[   12.828570@3] VFS: brelse: Trying to free free buffer
[   12.833586@3] VFS: brelse: Trying to free free buffer
[   12.838581@3] VFS: brelse: Trying to free free buffer
[   12.843514@3] VFS: brelse: Trying to free free buffer
[   12.848617@3] VFS: brelse: Trying to free free buffer
[   12.853592@3] VFS: brelse: Trying to free free buffer
[   12.858470@3] VFS: brelse: Trying to free free buffer
[   12.863604@3] VFS: brelse: Trying to free free buffer
[   12.868585@3] VFS: brelse: Trying to free free buffer
[   12.873594@3] VFS: brelse: Trying to free free buffer
[   12.878493@3] VFS: brelse: Trying to free free buffer
[   12.883627@3] VFS: brelse: Trying to free free buffer
[   12.888607@3] VFS: brelse: Trying to free free buffer
[   12.893594@3] VFS: brelse: Trying to free free buffer
[   12.898619@3] VFS: brelse: Trying to free free buffer
[   12.903633@3] VFS: brelse: Trying to free free buffer
[   12.908607@3] VFS: brelse: Trying to free free buffer
[   12.913505@3] VFS: brelse: Trying to free free buffer
[   12.918504@3] VFS: brelse: Trying to free free buffer
[   12.923638@3] VFS: brelse: Trying to free free buffer
[   12.928618@3] VFS: brelse: Trying to free free buffer
[   12.933510@3] VFS: brelse: Trying to free free buffer
[   12.938624@3] VFS: brelse: Trying to free free buffer
[   12.943646@3] VFS: brelse: Trying to free free buffer
[   12.948633@3] VFS: brelse: Trying to free free buffer
[   12.953534@3] VFS: brelse: Trying to free free buffer
[   12.958641@3] VFS: brelse: Trying to free free buffer
[   12.963678@3] VFS: brelse: Trying to free free buffer
[   12.968639@3] VFS: brelse: Trying to free free buffer
[   12.973553@3] VFS: brelse: Trying to free free buffer
[   12.978636@3] VFS: brelse: Trying to free free buffer
[   12.997608@3] SQUASHFS error: xz decompression failed, data probably corrupt
[   12.999170@1] pgd = ffffffc00d85c000
[   13.002554@3] [0004c8f0] *pgd=000000000d83c003, *pud=000000000d83c003, *pmd=000000000da4d003, *pte=0000000000000000
[   13.013811@3] pgd = ffffffc00e575000
[   13.016478@3] [a0532454] *pgd=0000000000000000, *pud=0000000000000000
[   13.122390@3] VFS: brelse: Trying to free free buffer
^C[   13.125356@3] VFS: brelse: Trying to free free buffer
[   13.130647@3] VFS: brelse: Trying to free free buffer
[   13.136374@3] VFS: brelse: Trying to free free buffer
[   13.140979@3] VFS: brelse: Trying to free free buffer
[   13.146000@3] VFS: brelse: Trying to free free buffer
[   13.151000@3] VFS: brelse: Trying to free free buffer
[   13.155986@3] VFS: brelse: Trying to free free buffer
[   13.161076@3] VFS: brelse: Trying to free free buffer
[   13.165972@3] VFS: brelse: Trying to free free buffer
[   13.171011@3] VFS: brelse: Trying to free free buffer
[   13.175946@3] VFS: brelse: Trying to free free buffer
[   13.180973@3] VFS: brelse: Trying to free free buffer
[   13.185975@3] VFS: brelse: Trying to free free buffer
[   13.190980@3] VFS: brelse: Trying to free free buffer
[   13.195984@3] VFS: brelse: Trying to free free buffer
[   13.241111@1] VFS: brelse: Trying to free free buffer
[   13.244184@1] VFS: brelse: Trying to free free buffer
[   13.253263@1] VFS: brelse: Trying to free free buffer
[   13.261300@0] VFS: brelse: Trying to free free buffer
[   13.264696@0] VFS: brelse: Trying to free free buffer
[   13.270022@0] VFS: brelse: Trying to free free buffer
[   13.273843@0] VFS: brelse: Trying to free free buffer
[   13.279507@0] VFS: brelse: Trying to free free buffer
[   13.301574@0] pgd = ffffffc00f58c000
[   13.301605@0] [767c4140] *pgd=0000000000000000, *pud=0000000000000000
[   13.307550@2] VFS: brelse: Trying to free free buffer
[   13.314531@2] VFS: brelse: Trying to free free buffer
[   13.319663@2] VFS: brelse: Trying to free free buffer
[   13.324629@2] VFS: brelse: Trying to free free buffer
[   13.331467@2] VFS: brelse: Trying to free free buffer
[   13.335112@2] VFS: brelse: Trying to free free buffer
[   13.339581@2] VFS: brelse: Trying to free free buffer
[   13.344562@2] VFS: brelse: Trying to free free buffer
[   13.349576@2] VFS: brelse: Trying to free free buffer
[   13.361367@2] VFS: brelse: Trying to free free buffer
[   13.364694@2] VFS: brelse: Trying to free free buffer
[   13.369993@2] VFS: brelse: Trying to free free buffer
[   13.375098@2] VFS: brelse: Trying to free free buffer
[   13.379762@2] VFS: brelse: Trying to free free buffer
[   13.384764@2] VFS: brelse: Trying to free free buffer
[   13.391746@0] VFS: brelse: Trying to free free buffer
[   13.395974@0] VFS: brelse: Trying to free free buffer
[   13.399876@0] VFS: brelse: Trying to free free buffer
[   13.404847@0] VFS: brelse: Trying to free free buffer
[   13.409876@0] VFS: brelse: Trying to free free buffer
[   13.414879@0] VFS: brelse: Trying to free free buffer
[   13.419842@0] VFS: brelse: Trying to free free buffer
[   13.424833@0] VFS: brelse: Trying to free free buffer
[   13.430401@0] VFS: brelse: Trying to free free buffer
[   13.434874@0] VFS: brelse: Trying to free free buffer
[   13.439846@0] VFS: brelse: Trying to free free buffer
[   13.460984@1] VFS: brelse: Trying to free free buffer
[   13.464434@1] VFS: brelse: Trying to free free buffer
[   13.469044@1] VFS: brelse: Trying to free free buffer
[   13.474914@1] VFS: brelse: Trying to free free buffer
[   13.478998@1] VFS: brelse: Trying to free free buffer
[   13.484046@1] VFS: brelse: Trying to free free buffer
[   13.489042@1] VFS: brelse: Trying to free free buffer
[   13.494002@1] VFS: brelse: Trying to free free buffer
[   13.499094@1] VFS: brelse: Trying to free free buffer
[   13.504001@1] VFS: brelse: Trying to free free buffer
[   13.508999@1] VFS: brelse: Trying to free free buffer
[   13.514116@1] VFS: brelse: Trying to free free buffer
[   13.519191@1] VFS: brelse: Trying to free free buffer
[   14.380280@1] pgd = ffffffc00d87d000
[   14.380316@1] [811639cc] *pgd=0000000000000000, *pud=0000000000000000
^CPlease press Enter to activate this console.
[   15.630328@0] SQUASHFS error: xz decompression failed, data probably corrupt
[   15.631823@0] SQUASHFS error: squashfs_read_data failed to read block 0x77414a
[   15.639540@0] SQUASHFS error: Unable to read fragment cache entry [77414a]
[   15.645796@0] SQUASHFS error: Unable to read page, block 77414a, size 7974
[   18.237514@0] pgd = ffffffc00d801000
[   18.237546@0] [d22280e1] *pgd=000000000d87e003, *pud=000000000d87e003, *pmd=0000000000000000
^C[   18.399139@3] pgd = ffffffc00dac2000
[   18.399171@3] [0100a454] *pgd=000000000d85c003, *pud=000000000d85c003, *pmd=0000000000000000
[   18.518516@2] VFS: brelse: Trying to free free buffer
^C[   19.266854@3] pgd = ffffffc00db15000
[   19.266886@3] [76021968] *pgd=0000000000000000, *pud=0000000000000000
^C^C^CPlease press Enter to activate this console.
[   20.543339@3] pdm_dclk is : 0
[   20.586923@0] invalid toddr src
[   21.220229@0] VFS: brelse: Trying to free free buffer
[   21.223493@0] VFS: brelse: Trying to free free buffer
[   21.229435@0] VFS: brelse: Trying to free free buffer
[   21.236429@0] VFS: brelse: Trying to free free buffer
[   21.240755@0] VFS: brelse: Trying to free free buffer
[   21.245851@0] VFS: brelse: Trying to free free buffer
[   21.249718@0] VFS: brelse: Trying to free free buffer
[   21.254854@0] VFS: brelse: Trying to free free buffer
S12A login:
S12A login: [   21.447016@3] pgd = ffffffc00dacc000
[   21.447047@3] [f7ebad70] *pgd=000000000da5e003, *pud=000000000da5e003, *pmd=0000000000000000
S12A login:
S12A login:
S12A login:
[  161.201741@3] pgd = ffffffc00daf6000
[  161.201773@3] [7eef7c00] *pgd=0000000000000000, *pud=0000000000000000
[  183.123176@2] pdm_dclk is : 0
[  183.165699@0] invalid toddr src
[  210.021469@0] VFS: brelse: Trying to free free buffer
[  210.024907@0] VFS: brelse: Trying to free free buffer
[  210.029557@0] VFS: brelse: Trying to free free buffer
[  210.034414@0] VFS: brelse: Trying to free free buffer
[  210.040016@0] VFS: brelse: Trying to free free buffer
[  210.044442@0] VFS: brelse: Trying to free free buffer
[  210.049605@0] VFS: brelse: Trying to free free buffer
[  210.054320@0] VFS: brelse: Trying to free free buffer
[  389.741942@1] pgd = ffffffc00dad9000
[  389.741973@1] [81000100] *pgd=0000000000000000, *pud=0000000000000000
[  390.129178@2] pgd = ffffffc00d85d000
[  390.129210@2] [d74c7880] *pgd=000000000b03b003, *pud=000000000b03b003, *pmd=0000000000000000
[  390.153730@3] pgd = ffffffc00db6c000
[  390.153785@3] [d6749084] *pgd=000000000e342003, *pud=000000000e342003, *pmd=0000000000000000
[  390.169441@0] pgd = ffffffc00b04c000
[  390.169474@0] [5656c6cc] *pgd=0000000000000000, *pud=0000000000000000
GMT+8, 2025-12-18 14:12 , Processed in 0.081807 second(s), 8 queries , MemCached On.
