查看: 8513|回复: 3
[技术探讨] 用Arduino IDE给sonoff刷ESP Easy固件碰到问题,请求帮助解惑。
发表于 2017-12-22 17:48:06 | 显示全部楼层 |阅读模式
使用的教程地址:
https://www.letscontrolit.com/wi ... ino_Firmware_Upload
碰到两个问题:
1、怎么没有1M的那个选项。
2、教程中有下面这么一段,因为E文水平不好搞不懂,似乎是要把以下脚本中的蓝色行前面的“//”注释符删去,我不太确定到底该不该删去。
Selecting the plugin sets
In version ESPEasy v2 or higher its possible to select different plugin sets. Since we're using Arduino IDE instead of Platformio, its neccesary to select them in ESPEasy.ino.
In the top of the .ino file you find the defines you can uncomment to enable a plugin set:
//build all the normal stable plugins
//#define PLUGIN_BUILD_NORMAL
//build all plugins that are in test stadium
//#define PLUGIN_BUILD_TESTING
//build all plugins that still are being developed and are broken or incomplete
//#define PLUGIN_BUILD_DEV
Remove the // from the plugin sets that you want to enable.
27hh
教程狂人论坛风云人物
发表于 2017-12-22 18:49:23 | 显示全部楼层
第一个问题应该是教程有问题,它应该会提供几个文件,替换后菜单中才会出现所需的选项;第二个意思是取消注释你想使用的插件,是把 //#define PLUGIN_BUILD_NORMAL 取消注释就行
发表于 2017-12-27 10:23:22 | 显示全部楼层
开发板选esp8266
不要选nodeMCU
发表于 2019-8-1 20:57:13 | 显示全部楼层
感觉教程是错误的!!!
GMT+8, 2026-1-1 11:51 , Processed in 1.344075 second(s), 15 queries , MemCached On.
