查看: 1184|回复: 0
[技术探讨] zigbee2mqtt抽风问题请教
发表于 2023-7-7 07:32:34 | 显示全部楼层 |阅读模式
插件版本1.32  配置如下:
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  server: mqtt://core-mosquitto:1883
  user: mqtt
  password: mqtt
serial:
  port: /dev/ttyUSB0
刚开始正常,过一会以后就会抽风,随机选择一个开关不停的发送指令,z2m log如下:
Zigbee2MQTT:info  2023-07-07 07:26:19: MQTT publish: topic 'zigbee2mqtt/餐厅开关', payload '{"linkquality":43,"power_on_behavior_l1":null,"power_on_behavior_l2":null,"power_on_behavior_l3":null,"power_on_behavior_l4":null,"state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":null}'
Zigbee2MQTT:info  2023-07-07 07:26:20: MQTT publish: topic 'zigbee2mqtt/餐厅开关', payload '{"linkquality":43,"power_on_behavior_l1":null,"power_on_behavior_l2":null,"power_on_behavior_l3":null,"power_on_behavior_l4":null,"state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":null}'
Zigbee2MQTT:info  2023-07-07 07:26:21: MQTT publish: topic 'zigbee2mqtt/餐厅开关', payload '{"linkquality":43,"power_on_behavior_l1":null,"power_on_behavior_l2":null,"power_on_behavior_l3":null,"power_on_behavior_l4":null,"state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":null}'
Zigbee2MQTT:info  2023-07-07 07:26:22: MQTT publish: topic 'zigbee2mqtt/餐厅开关', payload '{"linkquality":43,"power_on_behavior_l1":null,"power_on_behavior_l2":null,"power_on_behavior_l3":null,"power_on_behavior_l4":null,"state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":null}'
Zigbee2MQTT:info  2023-07-07 07:26:23: MQTT publish: topic 'zigbee2mqtt/餐厅开关', payload '{"linkquality":43,"power_on_behavior_l1":null,"power_on_behavior_l2":null,"power_on_behavior_l3":null,"power_on_behavior_l4":null,"state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":null}'
Zigbee2MQTT:info  2023-07-07 07:26:24: MQTT publish: topic 'zigbee2mqtt/餐厅开关', payload '{"linkquality":43,"power_on_behavior_l1":null,"power_on_behavior_l2":null,"power_on_behavior_l3":null,"power_on_behavior_l4":null,"state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":null}'
Zigbee2MQTT:info  2023-07-07 07:26:25: MQTT publish: topic 'zigbee2mqtt/餐厅开关', payload '{"linkquality":43,"power_on_behavior_l1":null,"power_on_behavior_l2":null,"power_on_behavior_l3":null,"power_on_behavior_l4":null,"state_l1":"OFF","state_l2":"ON","state_l3":"OFF","state_l4":null}'
看提示是mqtt publish消息导致  mqtt配置如下:
logins:
  - username: mqtt
    password: mqtt
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
  active: false
  folder: mosquitto
不知是哪里的问题,请教各位给判断判断
GMT+8, 2026-1-16 23:03 , Processed in 0.158795 second(s), 11 queries , MemCached On.
