查看: 2852|回复: 0
[已解决] 重启后蓝牙网关无法启动
发表于 2023-7-5 17:00:43 | 显示全部楼层 |阅读模式
盒子自带蓝牙网关
某一次重启后,蓝牙网关就出问题了
日志是:
2023-07-05 16:47:41.508 WARNING (MainThread) [bluetooth_auto_recovery.recover] Could not cycle the Bluetooth adapter hci0 [6C:B8:81:5F:60:0B]: [Errno 93] Protocol not supported
2023-07-05 16:47:46.527 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [6C:B8:81:5F:60:0B] could not be reset:
2023-07-05 16:47:46.536 WARNING (MainThread) [homeassistant.config_entries] Config entry '6C:B8:81:5F:60:0B' for bluetooth integration not ready yet: hci0 (6C:B8:81:5F:60:0B): Failed to start Bluetooth: [org.bluez.Error.NotReady] Resource Not Ready; Retrying in background
2023-07-05 16:48:15.014 WARNING (MainThread) [bluetooth_auto_recovery.recover] Could not cycle the Bluetooth adapter hci0 [6C:B8:81:5F:60:0B]: [Errno 93] Protocol not supported
2023-07-05 16:48:20.022 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [6C:B8:81:5F:60:0B] could not be reset:
集成删除之后,又可以自动被发现,但是重新配置后,问题依旧
求教各位吴彦祖~
配置后出现问题
配置后出现问题
集成删除后可以被发现
集成删除后可以被发现
GMT+8, 2025-12-18 14:10 , Processed in 1.124696 second(s), 15 queries , MemCached On.
