查看: 7269|回复: 15
[求助] docker 安装电费sgcc_electricity
xcf 手机认证
发表于 2023-7-4 10:44:06 | 显示全部楼层 |阅读模式
试了arm系统不行,就j1900的群晖docker 安装也不行,有懂得帮忙看下日志
谢谢各位大佬
2023-07-03 15:35:04  [INFO    ] ---- Webdriver initialized.
2023-07-03 15:35:38  [INFO    ] ---- Login successfully on https://www.95598.cn/osgweb/login
  File "/app/data_fetcher.py", line 30, in fetch
    return self._fetch()
  File "/app/data_fetcher.py", line 50, in _fetch
    user_id_list = self._get_user_ids(driver)
  File "/app/data_fetcher.py", line 184, in _get_user_ids
    self._click_button(driver, By.XPATH, "//div[@class='el-dropdown']/span")
  File "/app/data_fetcher.py", line 245, in _click_button
    click_element = driver.find_element(button_search_type, button_search_key)
2023-07-03 15:36:00  [ERROR   ] ---- Webdriver quit abnormly, reason: Message: no such element: Unable to locate element: {"method":"xpath","selector":"//div[@class='el-dropdown']/span"}
  (Session info: headless chrome=89.0.4389.114)
Stacktrace:
#0 0x005588063d48 <unknown>
#1 0x0055880066cc <unknown>
#2 0x005587d99d84 <unknown>
#3 0x005587dc6e08 <unknown>
  File "/usr/local/lib/python3.8/site-packages/selenium/webdriver/remote/webdriver.py", line 856, in find_element
    return self.execute(Command.FIND_ELEMENT, {
  File "/usr/local/lib/python3.8/site-packages/selenium/webdriver/remote/webdriver.py", line 429, in execute
    self.error_handler.check_response(response)
  File "/usr/local/lib/python3.8/site-packages/selenium/webdriver/remote/errorhandler.py", line 243, in check_response
    raise exception_class(message, screen, stacktrace)
#4 0x005587df4ac8 <unknown>
selenium.common.exceptions.NoSuchElementException: Message: no such element: Unable to locate element: {"method":"xpath","selector":"//div[@class='el-dropdown']/span"}
#5 0x005587dbdf50 <unknown>
#6 0x005587dbf3d4 <unknown>
#7 0x005588031ec8 <unknown>
Stacktrace:
#8 0x00558803faa0 <unknown>
#9 0x00558803f804 <unknown>
#10 0x005588043cbc <unknown>
#11 0x005588040240 <unknown>
#12 0x00558802816c <unknown>
#13 0x005588056b3c <unknown>
#14 0x00558806e398 <unknown>
#15 0x007fbd45d7e4 start_thread
#16 0x007fbcb1c70c <unknown>
. 2 retry times left.
2023-07-03 15:36:32  [INFO    ] ---- Webdriver initialized.
发表于 2023-7-5 20:03:21 | 显示全部楼层
请教  镜像下好了,部署容器命令怎么✍
xcf 手机认证
 楼主| 发表于 2023-7-6 14:41:50 | 显示全部楼层
lqf1206 发表于 2023-7-5 20:03
请教  镜像下好了,部署容器命令怎么✍
docker run --name sgcc_electricity -d -e PHONE_NUMBER="手机号" -e PASSWORD="登录密码" -e HASS_URL="http://ip:8123" -e HASS_TOKEN="你的令牌" --restart unless-stopped sgcc_electricity:1.1
发表于 2023-7-6 16:52:28 | 显示全部楼层
xcf 发表于 2023-7-6 14:41
docker run --name sgcc_electricity -d -e PHONE_NUMBER="手机号" -e PASSWORD="登录密码" -e HASS_URL= ...
不会写命令,我用addons安的
发表于 2023-7-14 15:18:45 | 显示全部楼层
你去这个地址注册认证把电表户号绑定就可以国
发表于 2023-7-14 18:07:01 | 显示全部楼层
lqf1206 发表于 2023-7-6 16:52
不会写命令,我用addons安的
这是什么卡片啊 请问是yml生成了实体   还是直接用的属性卡片
另外请教是汉化的还是纯粹的改了下仪表盘的名字
发表于 2023-7-14 19:56:37 | 显示全部楼层
另外请教是汉化的还是纯粹的改了下仪表盘的 ...
名字自己改的,就用了一天就失效了!还没学会! Screenshot_2023-07-14-19-57-48-555_io.homeassistant.companion.android.jpg
发表于 2023-7-14 20:43:31 | 显示全部楼层
在哪里学的  是哪个卡片  能告诉我吗  我应该会  你这个卡片很好看
发表于 2023-7-27 23:15:01 | 显示全部楼层
楼主用的是智趣盒子吗
发表于 2023-7-29 00:20:50 | 显示全部楼层
GMT+8, 2025-12-17 07:22 , Processed in 1.311638 second(s), 14 queries , MemCached On.
