查看: 2363|回复: 0
[新手导航] 安装homeassistant-supervised 1.4.2时无法拉容器
llvv 手机认证
发表于 2023-6-28 16:25:21 | 显示全部楼层 |阅读模式
这几天N1傻了,就重装了,换了个armbian 23系统,结果最后一步成这样了,希望各位大咖帮帮忙,指导一下
root@armbian:~# dpkg -i homeassistant-supervised.deb
Selecting previously unselected package homeassistant-supervised.
(Reading database ... 36300 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb ...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Adding 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised'
Adding 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised'
Adding 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised'
Adding 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised'
Unpacking homeassistant-supervised (1.4.2) ...
Setting up homeassistant-supervised (1.4.2) ...
[info] Restarting NetworkManager
[info] Restarting docker service
PING checkonline.home-assistant.io (104.26.5.238): 56 data bytes
64 bytes from 104.26.5.238: icmp_seq=0 ttl=1 time=215.147 ms
--- checkonline.home-assistant.io ping statistics ---
1 packets transmitted, 1 packets received, 0% packet loss
round-trip min/avg/max/stddev = 215.147/215.147/215.147/0.000 ms
[info] Install supervisor startup scripts
[info] Install AppArmor scripts
[info] Start Home Assistant Supervised
[info] Installing the 'ha' cli
[warn] Could not find /etc/default/grub or /boot/firmware/cmdline.txt failed to switch to cgroup v1
[info] Within a few minutes you will be able to reach Home Assistant at:
[info] http://homeassistant.local:8123 or using the IP address of your
[info] machine: http://10.11.22.7:8123
root@armbian:~# docker ps
CONTAINER ID   IMAGE                                                     COMMAND   CREATED         STATUS         PORTS     NAMES
cfbc4dea5f23   ghcr.io/home-assistant/aarch64-hassio-supervisor:latest   "/init"   4 minutes ago   Up 4 minutes             hassio_supervisor
root@armbian:~# ^C
真的搅不错了。。。。。。。。。。。。。。。。。。
错误代码
错误代码
GMT+8, 2025-12-16 20:00 , Processed in 0.762781 second(s), 15 queries , MemCached On.
