查看: 11859|回复: 13
[技术探讨] 安装加载项失败 'AddonManager.install' blocked from execution, no host ...
em90
发表于 2023-6-24 15:22:35 | 显示全部楼层 |阅读模式
安装加载项失败'AddonManager.install' blocked from execution, no host internet connection
卸载esphome后安装所有插件提示错误以上错误,求大佬帮忙解决一下,树莓派安装的HA
发表于 2023-6-26 08:26:24 | 显示全部楼层
重启,在加载项里面删除没有完全安装的addon。然后再重装。没办法,失败后不停的重装。我试过在早晨成功率大一些。
发表于 2023-6-26 13:57:30 | 显示全部楼层
同问,supervisor和OS两个版本都报这个错误。
23-06-26 13:16:34 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-06-26 13:31:34 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-06-26 13:31:39 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-06-26 13:46:34 INFO (MainThread) [supervisor.jobs] 'MountManager.reload' blocked from execution, mounting not supported on system
23-06-26 13:52:20 WARNING (MainThread) [supervisor.jobs] 'AddonManager.update' blocked from execution, no host internet connection
23-06-26 13:52:32 WARNING (MainThread) [supervisor.jobs] 'AddonManager.update' blocked from execution, no host internet connection
发表于 2023-6-26 14:24:21 | 显示全部楼层
要么  ha jobs options --ignore-conditions internet_host  忽略检测
要么 把 registry.hub.docker.com 挂上科学
发表于 2023-6-27 11:54:36 | 显示全部楼层
要么 把 registry.hub.docker.com  ...
感谢大佬,通过忽略检测已解决问题,安装完使用 ha jobs reset重置,重启supervisor,不然会一直报错。
发表于 2023-6-27 14:21:52 | 显示全部楼层
lemon6878 发表于 2023-6-27 11:54
感谢大佬,通过忽略检测已解决问题,安装完使用 ha jobs reset重置,重启supervisor,不然会一直报错。 ...
我执行了命令,也重启了,还是报这个错
发表于 2023-9-14 13:32:02 | 显示全部楼层
请问这俩玩意在哪里设置
发表于 2023-10-18 10:27:55 | 显示全部楼层
jy00295017 发表于 2023-9-14 13:32
请问这俩玩意在哪里设置
同问我刚用虚拟机安装的ha,也遇到了这个,不知道在哪设置
发表于 2024-5-19 19:11:48 | 显示全部楼层
收藏下,经常会这样
发表于 2024-5-28 23:00:56 | 显示全部楼层
具体怎么操作?
GMT+8, 2025-11-30 19:09 , Processed in 1.177521 second(s), 12 queries , MemCached On.
