查看: 3740|回复: 7
[技术探讨] ha里自定义传感器我想判断是昨天还是前天代码怎么写
发表于 2023-6-18 12:56:00 | 显示全部楼层 |阅读模式
我想根据某个设备的属性值的日期,判断是昨天还是前天,请问代码怎么写
{{state_attr('sensor.electricity_95598','last_date')}}
value_template: "{% if  %}昨天{% elif %}前天{% else %}未知{% endif %}
3万
发表于 2023-6-18 15:51:29 | 显示全部楼层
template:
  - sensor:
      - name: electricity_last_date_entity_jiandan
        unique_id: electricity_last_date_entity_jiandan
        state: >
          {% set now = as_timestamp(now()) %}
          {% set last_updated = as_timestamp(states('sensor.electricity_last_date_entity')) %}
          {% set diff = (now - last_updated) / 86400 %}
          {% if diff < 1 %}
            今天
          {% elif 1 <= diff < 2 %}
            昨天
          {% elif 2 <= diff < 3 %}
            前天
          {% elif 3 <= diff < 4 %}
            大前天
          {% else %}
            未知
          {% endif %}
  - trigger:
      - platform: event
        event_type: "state_changed"
        event_data:
          entity_id: sensor.electricity_95598
      - name: electricity_charge_balance_entity
        unique_id: electricity_charge_balance_entity
        state: "{{ states('sensor.electricity_95598') }}"
        unit_of_measurement: "CNY"
        device_class: monetary
      - name: electricity_balance_is_pay_entity
        unique_id: electricity_balance_is_pay_entity
        state: "{{ state_attr('sensor.electricity_95598', 'is_pay') }}"
      - name: last_electricity_usage_entity
        unique_id: last_electricity_usage_entity
        state: "{{ state_attr('sensor.electricity_95598', 'last_electricity_usage') }}"
        state_class: measurement
        unit_of_measurement: "kWh"
      - name: yearly_electricity_usage_entity
        unique_id: yearly_electricity_usage_entity
        state: "{{ state_attr('sensor.electricity_95598', 'yearly_electricity_usage') }}"
      - name: yearly_electricity_charge_entity
        unique_id: yearly_electricity_charge_entity
        state: "{{ state_attr('sensor.electricity_95598', 'yearly_electricity_charge') }}"
      - name: electricity_need_pay_3406665807552
        unique_id: electricity_need_pay_3406665807552
        state: "{{ state_attr('sensor.electricity_95598', 'need_pay') }}"
      - name: thismonth_electricity_usage_entity
        unique_id: thismonth_electricity_usage_entity
        state: "{{ state_attr('sensor.electricity_95598', 'thismonth_electricity_usage') }}"
        state: "{{ state_attr('sensor.electricity_95598', 'last_date') }}"
 楼主| 发表于 2023-6-18 17:31:07 | 显示全部楼层
谢谢大佬,按照你的方法搞定了
 楼主| 发表于 2023-6-18 17:33:31 | 显示全部楼层
还有个问题,我想请教下为什么你这里要加 trigger,我直接自定义 sensor,也是可以显示的,其实就是根据1个实体的属性值,创建1个 sensor,为什么要加trigger,好像不加,也是可以的,不知道有什么区别
3万
发表于 2023-6-19 00:56:16 | 显示全部楼层
bugensui 发表于 2023-6-18 17:33
还有个问题,我想请教下为什么你这里要加 trigger,我直接自定义 sensor,也是可以显示的,其实就是根据1 ...
其实这里最好是不加,但以原来trigger创建过的sensor的状态为值,保证实时更新是前天还是大前天。
其它几项模板实体需要加上trigger,这样重启ha后,而docker中的服务没有更新时,那些模板的值不会变成不可用。
 楼主| 发表于 2023-6-19 11:18:38 | 显示全部楼层
其它几 ...
好的,谢谢,学习了
发表于 2023-6-24 16:28:51 | 显示全部楼层
这个是什么用途?具体用在什么上面?谢谢
 楼主| 发表于 2023-6-24 16:31:30 | 显示全部楼层
13990973177 发表于 2023-6-24 16:28
这个是什么用途?具体用在什么上面?谢谢
电费获取上
GMT+8, 2026-1-17 00:50 , Processed in 0.052234 second(s), 9 queries , MemCached On.
