查看: 2911|回复: 2
[求助] Zigbee2MQTT 启动失败
发表于 2023-6-10 22:19:22 | 显示全部楼层 |阅读模式
之前配置好正常运行了一年多,今天发现突然报错,尝试重启及卸载安装均无法正常使用,对命令和权限不太清楚,但是出问题的时候没有更改过此类设置,希望能帮看看是什么原因
[backcolor=rgb(222, 236, 252) !important]
Start container addon_45df7312_zigbee2mqtt failed: {"message":"path /volume1/docker/hass.io/share is mounted on /volume1 but it is not a shared or slave mount"}.
2023-06-10 21:37:56
Error
qyl1931
Can't start addon_45df7312_zigbee2mqtt: 500 Server Error for http+docker://localhost/v1.41/containers/74048ee62090ca8660fc384feeafd7f24ed19f0994894c6678b1954b2c0a1764/start: Internal Server Error ("path /volume1/docker/hass.io/share is mounted on /volume1 but it is not a shared or slave mount")
发表于 2023-6-10 22:41:11 | 显示全部楼层
shafashafa
发表于 2023-8-11 10:50:08 | 显示全部楼层
同问 我被搞了好几个月了
GMT+8, 2025-12-17 07:21 , Processed in 1.095214 second(s), 9 queries , MemCached On.
