查看: 5733|回复: 16
[求助] 怎么将所有开启的灯自动集合到一个卡片自动显示
发表于 2023-6-10 02:36:17 | 显示全部楼层 |阅读模式
就是想方便查看管理设备:
如何显示ha已开启的灯自动显示到一个卡片上,不开启的不会被显示卡片上
扩展~那些提示电量低的设备自动显示到一个卡片上统一适用
谁知道怎么搞 谢谢~
发表于 2023-6-10 02:44:51 来自手机 | 显示全部楼层
auto-entities插件可以搞定
hyq
发表于 2023-6-10 07:37:51 | 显示全部楼层
type: entity-filter
entities:
  - light.tz3000_ywhqfbr4_ts0002_light_11
  - light.tz3000_ywhqfbr4_ts0002_light_12
  - light.tyzb01_phjeraqq_ts0001_light_2
  - light.tz3000_t0wsasu3_ts0001_light_7
  - light.smart_bulb_2
  - light.tz3000_ywhqfbr4_ts0002_light_15
  - light.tz3000_ywhqfbr4_ts0002_light_16
  - switch.2_2
  - switch.11_2
  - switch.12_2
  - switch.17_2
  - switch.18_2
  - light.tz3000_ywhqfbr4_ts0002_light_2
  - switch.wifi_bleqiang_bi_cha_zuo_sheng_ji_ban_socket_1
  - light.tz3000_k8kkhcik_ts0002_light
  - light.tz3000_k8kkhcik_ts0002_light_2
  - binary_sensor.liangba_chuifeng
  - binary_sensor.liangba_zhaoming
  - light.tz3000_hnkvd3kc_ts0004_light_13
  - light.tz3000_hnkvd3kc_ts0004_light_14
  - light.tz3000_hnkvd3kc_ts0004_light_16
  - light.tz3000_ywhqfbr4_ts0002_light_7
  - light.tz3000_ywhqfbr4_ts0002_light_8
  - light.tz3000_hnkvd3kc_ts0004_light_5
  - light.tz3000_hnkvd3kc_ts0004_light_6
  - light.tz3000_hnkvd3kc_ts0004_light_7
  - light.tz3000_hnkvd3kc_ts0004_light_8
  - light.tz3000_ywhqfbr4_ts0002_light_3
  - light.tz3000_rzspmwpm_ts0004_light
  - light.tz3000_rzspmwpm_ts0004_light_2
  - light.tz3000_rzspmwpm_ts0004_light_3
  - light.jiuguidengdai13
  - light.jiuguidengdai23
  - light.jiuguidengdai33
  - light.dengdaishang3
  - light.dengdaixia3
  - switch.beijingdengdaidianyuankaiguan
  - binary_sensor.tz3000_mq9f17dw_ts0203_iaszone
  - light.tz3000_hnkvd3kc_ts0004_light_29
  - light.tz3000_hnkvd3kc_ts0004_light_30
  - light.tz3000_hnkvd3kc_ts0004_light_31
  - light.tz3000_hnkvd3kc_ts0004_light_32
  - binary_sensor.ketds
  - light.ft_wf_ble_cw
  - light.tz3000_t0wsasu3_ts0001_light_4
  - light.tz3000_rzspmwpm_ts0004_light_5
  - light.tz3000_rzspmwpm_ts0004_light_8
  - light.tz3000_hnkvd3kc_ts0004_light_18
  - light.tz3000_hnkvd3kc_ts0004_light_19
  - light.tz3000_hnkvd3kc_ts0004_light_20
  - light.smart_bulb
  - light.tz3000_hnkvd3kc_ts0004_light_21
  - light.tz3000_hnkvd3kc_ts0004_light_22
  - light.tz3000_hnkvd3kc_ts0004_light_23
  - light.tz3000_hnkvd3kc_ts0004_light_24
  - light.tz3000_t0wsasu3_ts0001_light_6
  - switch.2
  - switch.11
  - switch.12
  - switch.17
  - switch.18
  - light.tz3000_t0wsasu3_ts0001_light_3
  - switch.si_lu_kai_guan_zigbee_6_switch_4
  - light.12deng
  - light.tz3000_ywhqfbr4_ts0002_light_5
  - light.tz3000_ywhqfbr4_ts0002_light_6
  - light.tyzb01_4tlksk8a_ts0001_light
  - switch.hexin
  - light.tz3000_t0wsasu3_ts0001_light_5
  - light.tz3000_t0wsasu3_ts0001_light_2
  - switch.dian_shi_bei_jing_deng_dai_cantingdengdai
  - light.leshi_wy0b01_0d40_light
  - light.ciwoxidingdeng_ciwoxidingdeng
state_filter:
  - 'on'
card:
  type: entities
  title: 开启的设备
type: entity-filter
entities:
  - sensor.tz3000_jjua3lql_ts0207_battery_4
  - sensor.tz3000_mcxw5ehu_ts0202_battery
  - sensor.tz2000_a476raq2_ts0201_battery
  - sensor.tuyatec_yx1cf5ka_rh3052_battery
  - sensor.tyzb01_tob46aoq_ts0205_battery_2
  - sensor.tuyatec_zjon5xgn_rh3001_battery
  - sensor.tyzb01_4mdqxxnn_ts0222_battery
  - sensor.tuyatec_aovdiasu_rh3040_battery
  - sensor.tz3000_mq9f17dw_ts0203_battery
  - sensor.tz3000_26fmupbb_ts0203_battery
  - sensor.tz3000_mcxw5ehu_ts0202_battery_3
  - sensor.tz3000_jjua3lql_ts0207_battery_3
  - sensor.tz3000_jjua3lql_ts0207_battery_2
  - sensor.ewelink_ms01_battery
  - sensor.ewelink_ms01_battery_2
  - sensor.tz3000_mcxw5ehu_ts0202_battery_4
  - sensor.tz3000_mcxw5ehu_ts0202_battery_2
  - binary_sensor.tz3000_mcxw5ehu_ts0202_iaszone_2
state_filter:
  - operator: <
    value: 20
card:
  type: entities
  title: 低电量显示
添加到仪表盘。仪表盘显示。
发表于 2023-6-10 10:55:44 | 显示全部楼层
hyq 发表于 2023-6-10 07:37
type: entity-filter
entities:
求问,能不用在entities里面逐个添加实体名称,只要是hass里面有的switch或者light就可以,或者用通配符,模板这样的方法在entities里面写,实现这个目的
hyq
发表于 2023-6-10 11:18:39 | 显示全部楼层
syhzjnbxs 发表于 2023-6-10 10:55
求问,能不用在entities里面逐个添加实体名称,只要是hass里面有的switch或者light就可以,或者用通配符 ...
不好意思!我都是小白。跟到官网来的!高端的我不会玩!
 楼主| 发表于 2023-6-10 12:13:51 | 显示全部楼层
这个不错,想楼上说的如果不用每个都添加就更好了,每个添加有点费事
发表于 2023-6-10 12:51:23 | 显示全部楼层
type: entity-filter
entities:
我也是只会这么写
发表于 2023-6-10 13:03:51 | 显示全部楼层
你说的可是这种
发表于 2023-6-10 23:02:33 | 显示全部楼层
这个怎么弄
 楼主| 发表于 2023-6-11 01:18:52 | 显示全部楼层
你这个不是我现在说的这个 不过我也看到过你这个 大分类管理也挺好! 可以分享出来大家学习研究吗
GMT+8, 2025-12-17 09:26 , Processed in 0.998103 second(s), 14 queries , MemCached On.
