查看: 5397|回复: 10
[技术探讨] HA更新到2023.6.1后,ZHA崩了
发表于 2023-6-9 19:13:50 | 显示全部楼层 |阅读模式
ZHA始终处于无法启动的状态。
贴上代码
Logger: zigpy.application
Source: /usr/local/lib/python3.11/site-packages/zigpy/application.py:196
First occurred: 18:59:12 (9 occurrences)
Last logged: 19:06:23
Couldn't start application
  File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 193, in startup
    await self.connect()
  File "/usr/local/lib/python3.11/site-packages/zigpy_znp/zigbee/application.py", line 107, in connect
    await znp.connect()
  File "/usr/local/lib/python3.11/site-packages/zigpy_znp/api.py", line 709, in connect
    self._uart = await uart.connect(self._config[conf.CONF_DEVICE], self)
  File "/usr/local/lib/python3.11/site-packages/zigpy_znp/uart.py", line 170, in connect
    _, protocol = await zigpy.serial.create_serial_connection(
  File "/usr/local/lib/python3.11/site-packages/zigpy/serial.py", line 31, in create_serial_connection
    transport, protocol = await loop.create_connection(
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1085, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1069, in create_connection
    sock = await self._connect_sock(
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 973, in _connect_sock
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 634, in sock_connect
    return await fut
  File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 674, in _sock_connect_cb
    raise OSError(err, f'Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed ('192.168.xx', 8888)
发表于 2023-6-9 21:23:16 | 显示全部楼层
2023.6.1 改动很大,底层python版本从10升到了11,建议不要着急升,开发者好多插件都要更新才支持
 楼主| 发表于 2023-6-10 08:25:50 | 显示全部楼层
25989406 发表于 2023-6-9 21:23
2023.6.1 改动很大,底层python版本从10升到了11,建议不要着急升,开发者好多插件都要更新才支持 ...
哎,没有备份,现在觉得挺无语的
发表于 2023-6-10 19:48:21 | 显示全部楼层
lexcao 发表于 2023-6-10 08:25
哎,没有备份,现在觉得挺无语的
回滚到上个版本不就好了,有啥可无语的
hyq
发表于 2023-6-10 20:02:01 | 显示全部楼层
25989406 发表于 2023-6-10 19:48
回滚到上个版本不就好了,有啥可无语的
好像这次不能回滚!我试过没回滚回去
发表于 2023-6-10 20:24:46 | 显示全部楼层
hyq 发表于 2023-6-10 20:02
好像这次不能回滚!我试过没回滚回去
可以,我都回滚可以   不过新版不影响我使用
发表于 2023-6-11 10:41:25 | 显示全部楼层
毫无影响
发表于 2023-6-11 11:40:00 | 显示全部楼层
ZHA早上升级啦
发表于 2023-6-11 12:27:08 | 显示全部楼层
毫无影响+1
发表于 2023-6-11 14:58:23 | 显示全部楼层
毫无影响+1
GMT+8, 2026-1-17 00:50 , Processed in 0.053150 second(s), 9 queries , MemCached On.
