查看: 5827|回复: 11
[技术探讨] 升级6.0后的问题
发表于 2023-6-8 15:31:34 | 显示全部楼层 |阅读模式
升级6.0后command line生成传感器的配置文件变了,请问integration key是哪里,新版的配置文件应该放在那儿?
3万
发表于 2023-6-8 16:47:18 | 显示全部楼层
The Command Line integration changes its YAML configuration format from an old-style platform configuration to a more modern integration-style configuration format.
For example, if you have a binary sensor configured previously as:
# Example configuration.yaml entry
binary_sensor:
  - platform: command_line
    command: "cat /proc/sys/net/ipv4/ip_forward"
That same binary sensor is now configured under the command_line integration configuration as:
command_line:
  - binary_sensor:
Note: While this is currently not yet a breaking change, it did raise questions during our beta testing period. Hence we have added this as a breaking change to provide more context.
(@gjohansson-ST - #92824) (documentation)
Ari 手机认证
发表于 2023-6-8 18:19:16 | 显示全部楼层
dscao 发表于 2023-6-8 16:47
The Command Line integration changes its YAML configuration format from an old-style platform config ...
奔溃,要改太多东西了
发表于 2023-6-9 06:08:56 来自手机 | 显示全部楼层
解决了吗
发表于 2023-6-9 08:50:22 | 显示全部楼层
升级6.0 后,空调面板卡片翻译有问题了。
发表于 2023-6-9 09:05:26 | 显示全部楼层
谁不是更新之后死一片
发表于 2023-6-9 14:48:40 | 显示全部楼层
怕了,缓缓在更新
发表于 2023-6-9 16:47:59 | 显示全部楼层
它这英文提示有误导,说是 move。。。。应该说成 change 更好
发表于 2023-6-9 17:45:54 | 显示全部楼层
升级到6以后,MQTT无法加载了,你们的是这样吗?是怎么处理的呀。
发表于 2023-6-9 18:53:19 | 显示全部楼层
ZHA崩了……
GMT+8, 2026-1-17 00:49 , Processed in 0.372249 second(s), 10 queries , MemCached On.
