查看: 2553|回复: 4
[求助] 条件卡片的条件语法
发表于 2023-6-7 20:01:10 | 显示全部楼层 |阅读模式
如题,有种情况目前不知道怎么设置
1.电量实体的状态小于10的时候显示
2.设备实体的电量属性小于10的时候显示
3.A电量实体和B电量实体,其中一个状态小于10的时候显示
type: conditional
conditions:
card:
  type: entities
  entities:
    - entity: sensor.dreamebot_s10_filter_left
    - entity: sensor.dreamebot_s10_filter_time_left
    - entity: button.dreamebot_s10_reset_filter
hyq
发表于 2023-6-7 21:21:28 | 显示全部楼层
type: entity-filter
entities:
  - sensor.tz3000_jjua3lql_ts0207_battery_4
  - sensor.tz3000_mcxw5ehu_ts0202_battery
  - sensor.tz2000_a476raq2_ts0201_battery
  - sensor.tuyatec_yx1cf5ka_rh3052_battery
  - sensor.tyzb01_tob46aoq_ts0205_battery_2
  - sensor.tuyatec_zjon5xgn_rh3001_battery
  - sensor.tyzb01_4mdqxxnn_ts0222_battery
  - sensor.tuyatec_aovdiasu_rh3040_battery
  - sensor.tz3000_mq9f17dw_ts0203_battery
  - sensor.tz3000_26fmupbb_ts0203_battery
  - sensor.tz3000_mcxw5ehu_ts0202_battery_3
  - sensor.tz3000_jjua3lql_ts0207_battery_3
  - sensor.tz3000_jjua3lql_ts0207_battery_2
  - sensor.ewelink_ms01_battery
  - sensor.ewelink_ms01_battery_2
  - sensor.tz3000_mcxw5ehu_ts0202_battery_4
  - sensor.tz3000_mcxw5ehu_ts0202_battery_2
  - binary_sensor.tz3000_mcxw5ehu_ts0202_iaszone_2
state_filter:
  - operator: <
    value: 20
card:
  type: entities
  title: 低电量显示
不知道你是否是想要这种?
 楼主| 发表于 2023-6-7 22:02:46 | 显示全部楼层
hyq 发表于 2023-6-7 21:21
type: entity-filter
entities:
不是这个噢,你这个是实体筛选卡片,一个卡片里显示满足条件的实体。我说的是条件卡片,是满足条件显示整张卡片。这个卡片也是官方的卡片,就叫条件。
 楼主| 发表于 2023-6-8 13:31:24 | 显示全部楼层
type: conditional
conditions:
  - condition: template
    value_template: "{{ (state_attr('vacuum.dreamebot_s10', 'filter_left')|int) > 50 }}"
card:
  type: entities
  entities:
搞了三天了,文档里写的都试了不行,感觉实现不了了。没这个功能放弃了
hhh. 手机认证
发表于 2024-2-20 22:49:12 | 显示全部楼层
type: conditional
conditions:
  - condition: numeric_state
    entity: sensor.battery
    below: 20
card:
  type: entities
  entities:
当sensor.battery的值低于20,就显示卡片
GMT+8, 2025-12-17 09:28 , Processed in 1.025616 second(s), 6 queries , MemCached On.
