楼主: d380025303
[插件集成] GPSLogger 增强 (集成高德地图地址 v5.1.1_20230803)
发表于 2023-7-13 12:52:10 | 显示全部楼层
d380025303 发表于 2023-7-13 10:29
路径代码会自动拼好...
开启debug模式? 然后重启一下HA再看下日志?
报告大佬,我不知道我开启的DEBUG对不对,我去查的HA的官方文档。
分别是在集成里选择了调试模式和加了:
logger:
  default: info
  logs:
    custom_components.ha_gaode_server: debug
按你说的关键字得到结果(个人瞎猜的可能有问题的顺序排列):
Async_setup
Home Assistant Core
2023-07-13 12:36:55.338 INFO (MainThread) [custom_components.ha_gaode_server] async_setup....
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 328, in _async_setup_platform
table
TypeError: 'NoneType' object is not subscriptable
Search
2023-07-13 12:48:56.956 INFO (MainThread) [homeassistant.setup] Setting up search
2023-07-13 12:48:56.957 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2023-07-13 12:49:08.249 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'sun', 'homeassistant_alerts', 'xiaomi_gateway3', 'group', 'tts', 'media_source', 'mobile_app', 'midea_ac_lan', 'auth', 'persistent_notification', 'bodymiscale', 'gpslogger', 'my', 'assist_pipeline', 'input_number', 'counter', 'sensor', 'input_datetime', 'application_credentials', 'mqtt', 'hacs', 'bemfa', 'file_upload', 'weather', 'stream', 'stt', 'config', 'onboarding', 'auto_backup', 'image_upload', 'template', 'input_text', 'switch', 'aqara_gateway', 'device_automation', 'browser_mod', 'xiaomi_ble', 'ffmpeg', 'script', 'colorfulclouds', 'system_health', 'conversation', 'repairs', 'lovelace', 'zone', 'nodered', 'bluetooth_adapters', 'history', 'automation', 'logbook', 'tag', 'input_select', 'search', 'default_config', 'ble_monitor', 'trace', 'met', 'hardware', 'unified_remote', 'scene', 'esphome', 'timer', 'radio_browser', 'person', 'esxi_stats', 'energy', 'input_button', 'ha_file_explorer', 'schedule', 'analytics', 'map', 'qweather', 'ikuai', 'blueprint', 'ha_gaode_server', 'diagnostics', 'input_boolean', 'panel_custom', 'xiaomi_miot'}
发表于 2023-7-13 13:01:07 | 显示全部楼层
学习学习
 楼主| 发表于 2023-7-13 13:25:39 | 显示全部楼层
分别是在集成里选择了调试模式和加了:
知道了
你版本不对, 日志有个async_setup...., 这个在我添加db的配置后才去掉的, 你现在还是会输出这个日志, 说明版本太老了
最好换成5.X版本,,,
发表于 2023-7-13 13:27:31 | 显示全部楼层
界面排版不太对啊
发表于 2023-7-13 13:44:44 | 显示全部楼层
d380025303 发表于 2023-7-13 13:25
知道了
你版本不对, 日志有个async_setup...., 这个在我添加db的配置后才去掉的, 你现在还是会输出这个日 ...
太感谢大佬了。我竟然完全忘记了。
我更新了最新版,马上就有了.db文件。。。。。乌龙了。。。。。
因为地图那个前端和这个是分着装的。我看地图那个里面有HACS说明,这个没有完成不知道能不能HACS安装。我就手动装的
但是我记反了。。我收藏的也是那个。。。。我还手动更新了那个前端- -我以为这个是HACS装的。因为HACS我一直都有更新的。。。。。。。
 楼主| 发表于 2023-7-13 13:58:09 | 显示全部楼层
PerryLayne 发表于 2023-7-13 13:44
太感谢大佬了。我竟然完全忘记了。
解决了就好
发表于 2023-7-14 11:32:09 | 显示全部楼层
感谢大神分享
发表于 2023-7-14 12:32:04 | 显示全部楼层
感谢lz的热情分享谢谢
发表于 2023-7-14 17:58:22 | 显示全部楼层
发表于 2023-7-16 10:26:50 | 显示全部楼层
膜拜大神!
GMT+8, 2025-9-17 03:09 , Processed in 0.877896 second(s), 12 queries , MemCached On.
