查看: 3676|回复: 6
[硬件DIY] N1盒子坏了,改一个室内环境检测器吧
发表于 2023-6-2 21:01:31 | 显示全部楼层 |阅读模式
1.所需硬件,n1盒子尸体一个,pm2.5传感器一个,甲醛浓度检测模块一个,环境光线检测模块一个,温湿度模块一个,esp32模块一个,tm1637两个,如果闲显示太小可以自己换一个0.8寸的
代码比较简单,如下:
esphome:
  friendly_name: room-sensor
  includes:
    - winsen_ze08.h
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: 00000000000000
  password: 0000000000000
  ap:
    ssid: "room-sensor"
    password: "0000000000000"
captive_portal:
web_server:
  port: 80
i2c:
 #定义温湿度、光线传感器总线
   - id: bus_a
     sda: GPIO21
     scl: GPIO22
     scan: true
uart:
#定义pms颗粒物传感器数据脚
  - id: uart_pm
    rx_pin: GPIO13
    tx_pin: GPIO14
    baud_rate: 9600
#定有机物传感器数据脚
  - id: uart_ze08
    tx_pin: GPIO25
    rx_pin: GPIO26
    baud_rate: 9600
#室内温湿度测量
  - platform: aht10
    temperature:
      name: "Room Temperature"
    humidity:
      name: "Room Humidity"
    update_interval: 60s
#室内颗粒物测量
  - platform: pmsx003
    uart_id: uart_pm
    type: PMSX003
    pm_1_0:
      name: "Room pm <1.0µm"
    pm_2_5:
      name: "Room pm <2.5µm"
    pm_10_0:
      name: "Room pm <10.0µm"
#室内有机物测量
  - platform: template
    name: "Room Formaldehyde"
    unit_of_measurement: ppb
    accuracy_decimals: 0
#光线测量
  - platform: bh1750
    name: "Room Illuminance"
    address: 0x23
custom_component:
  - lambda: |-
      auto ze08 = new WinsenZE08Sensor(id(uart_ze08), id(ze08_ch2o));
      App.register_component(ze08);
      return {ze08};
#时间显示+粉尘传感器定时
time:
  - platform: homeassistant
    on_time:
      # Every 5 minutes
      - seconds: 0
        minutes: /10
        then:
          - switch.turn_on: relay
display:
  - platform: tm1637
    clk_pin: GPIO19
    dio_pin: GPIO18
    update_interval: 500ms
    lambda: |-
      static int i = 0;
      i++;
      if ((i % 2) == 0)
        it.strftime("%H.%M", id(homeassistant_time).now());
      else
        it.strftime("%H%M", id(homeassistant_time).now());
  - platform: tm1637
    clk_pin: GPIO18
    dio_pin: GPIO19
    update_interval: 2s
    lambda: |-
      static int i = 0;
      i++;
      if ((i % 2) == 0)
       it.strftime("%m.%d", id(homeassistant_time).now());
      else
        it.printf(0, "%.1fC", id(temp).state);
 #       it.printf(2, "%.0f",  id(humi).state);
#粉尘传感器控制
switch:
  - platform: gpio
    pin: GPIO27
    name: "Room PSM sw"
    icon: "mdi:weather-dust"
    on_turn_on:
    - delay: 60s
    - switch.turn_off: relay
参与人数 2金钱 +20 收起 理由
sorrypqa + 10 大神666!
wormshow + 10 厉害了word楼主!
发表于 2023-6-2 21:11:25 | 显示全部楼层
废物利用
发表于 2023-6-2 21:12:03 | 显示全部楼层
会玩lambda的都是大神,膜拜一下。
发表于 2023-6-4 16:42:31 | 显示全部楼层
太会玩了,不错哦
Ari 手机认证
发表于 2023-6-5 09:23:16 | 显示全部楼层
牛逼。感谢分享
dlx
发表于 2023-7-3 20:06:36 | 显示全部楼层
膜拜一下
dlx
发表于 2023-7-3 20:07:53 | 显示全部楼层
想入手个主机有没有低功耗的麻大神烦推荐个谢谢啊
GMT+8, 2026-1-16 23:03 , Processed in 0.221459 second(s), 17 queries , MemCached On.
