查看: 3103|回复: 16
通过编码器控制老吊扇,控制三挡
发表于 2023-6-1 13:57:14 | 显示全部楼层 |阅读模式
一直想把老吊扇拆了,老婆大人不同意,说最实用的就是它,夏天用风很大,很凉快。算了改造一下吧!1.材料,旋转编码器一个,四联继电器模块,8266.吊扇调速电容
用旋转编码器替换波段开关,需要电路基础
2.实现功能,小爱接入,三挡调速,多余的引脚顺便控制了灯
3.代码如下:
esphome:
  friendly_name: living-room
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "0000000000000"
wifi:
  ssid: 0000000000000
  password: 000000000000
  ap:
    ssid: "living_room Fallback Hotspot"
captive_portal:
web_server:
  port: 80 # web端口
binary_sensor:
  # 继电器高档二进制取反
  - platform: template
    lambda: |-
      if (id(relay3).state) {
        return false;
      } else {
        return true;
 # 继电器中档二进制取反
    lambda: |-
      if (id(relay2).state) {
        return false;
      } else {
        return true;
  # 开关机、调速
  - platform: gpio
    #是否对外隐藏(true/false)
    #internal: true
    pin:
      number: GPIO13
      mode: INPUT_PULLUP
    # on_press:
    #   - switch.toggle: switch0
    filters:
      - invert:
      - delayed_on_off: 40ms
    on_press:
        then:
  - platform: gpio
    #是否对外隐藏(true/false)
    internal: true
    pin:
      number: GPIO14
      mode: INPUT_PULLUP
    # on_press:
    #   - switch.toggle: switch1
    filters:
      - invert:
      - delayed_on_off: 100ms
    on_press:
  - platform: gpio
    pin:
      number: GPIO0
      mode:
        input: true
        pullup: true
      inverted: true
    on_press:
      - switch.toggle: relay4
switch:
    icon: "mdi:fan-speed-3"
    lambda: |-
      if (id(relay1).state && id(relay2).state && id(relay3).state) {
        return true;
      } else {
        return false;
    turn_on_action:
      - switch.turn_on: relay1
      - switch.turn_on: relay2
      - switch.turn_on: relay3
    turn_off_action:
      - switch.turn_off: relay1
      - switch.turn_off: relay2
      - switch.turn_off: relay3
    icon: "mdi:fan-speed-2"
    lambda: |-
      if (id(relay1).state && id(relay2).state && id(sw3).state) {
        return true;
      } else {
        return false;
    turn_on_action:
    turn_off_action:
    icon: "mdi:fan-speed-1"
    lambda: |-
      if (id(relay1).state && id(sw2).state && id(sw3).state) {
        return true;
      } else {
        return false;
    turn_on_action:
    turn_off_action:
    icon: "mdi:ceiling-fan"
    turn_on_action:
      then:
       - if:
          condition:
            and:
             - switch.is_off: relay1
             - switch.is_off: relay2
             - switch.is_off: relay3
          then:
          else:
            - if:
                condition:
                  and:
                   - switch.is_on: relay1
                then:
                else:
                 - if:
                    condition:
                      and:
                       - switch.is_on: relay2
                    then:
                    else:
                      - if:
                         condition:
                            and:
                             - switch.is_on: relay3
                         then:
    #全部关闭
    #output: realy0
    icon: "mdi:fan-off"
    turn_on_action:
      - lambda: |-
            id(relay2).turn_off();
            id(relay3).turn_off();
            id(relay1).turn_off();
    turn_off_action:
      - lambda: |-
  - platform: gpio
    pin: 5
    icon: "mdi:fan"
    restore_mode: ALWAYS_OFF
  - platform: gpio
    pin: 4
    icon: "mdi:fan"
  - platform: gpio
    pin: 15
    icon: "mdi:fan"
  - platform: gpio
    pin: 12
    icon: "mdi:wall-sconce-flat"
  - platform: restart
参与人数 1金钱 +8 收起 理由
kaka0992 + 8 论坛有你更精彩!
Ari 手机认证
发表于 2023-6-1 14:12:44 | 显示全部楼层
大佬的都是实用性diy,准备多多学习
发表于 2023-6-1 15:09:15 | 显示全部楼层
这就是个旋转的档位开关啊,不是编码器啊
发表于 2023-6-1 15:10:52 | 显示全部楼层
花落花空 发表于 2023-6-1 15:09
这就是个旋转的档位开关啊,不是编码器啊
yaml里没看见编码器部分啊
 楼主| 发表于 2023-6-1 15:35:03 | 显示全部楼层
这就是个旋转的档位开关啊,不是编码器啊
没错,就是利用了编码器的开关特性
发表于 2023-6-1 16:14:03 | 显示全部楼层
LZ连发很多干货
 楼主| 发表于 2023-6-1 21:50:44 | 显示全部楼层
就是业余爱好,希望对大家有帮助
发表于 2023-6-14 15:14:06 | 显示全部楼层
为什么不是pwm
 楼主| 发表于 2023-6-14 16:36:11 | 显示全部楼层
交流风扇,适配的pwm模块有点小贵
发表于 2023-6-15 14:03:37 | 显示全部楼层
shadowba 发表于 2023-6-14 16:36
交流风扇,适配的pwm模块有点小贵
ESPHome不是可控硅调速组件吗?可控硅不贵呀!
GMT+8, 2026-1-17 21:39 , Processed in 0.076272 second(s), 12 queries , MemCached On.
