查看: 10417|回复: 28
[经验分享] 群晖DSM 7.1自编译USB蓝牙内核模块可以docker HA继续使用蓝牙
发表于 2023-5-29 10:59:01 | 显示全部楼层 |阅读模式
#建个目录在DSM上构建编译环境
mkdir /volume1/synology_dev/env_7.1
cd /volume1/synology_dev/env_7.1
wget -O base_env-7.1.txz https://cndl.synology.cn/downloa ... se/base_env-7.1.txz
wget -O ds.apollolake-7.1.dev.txz https://cndl.synology.cn/downloa ... llolake-7.1.dev.txz
wget -O ds.apollolake-7.1.env.txz https://cndl.synology.cn/downloa ... llolake-7.1.env.txz
wget -O apollolake-gcc750_glibc226_x86_64-GPL.txz https://cndl.synology.cn/downloa ... c226_x86_64-GPL.txzwget -O linux-4.4.180.tar.xz https://cdn.kernel.org/pub/linux/kernel/v4.x/linux-4.4.180.tar.xz
tar -xf base_env-7.1.txz && tar -xf ds.apollolake-7.1.env.txz
tar -xf ds.apollolake-7.1.dev.txz && tar -xf apollolake-gcc750_glibc226_x86_64-GPL.txz
tar -zxvf linux-4.4.180.tar.xz
ln -s /volume1/synology_dev/env_7.1/usr/local/x86_64-pc-linux-gnu/x86_64-pc-linux-gnu/sys-root/usr/lib/modules/DSM-7.1/build /lib/modules/4.4.180+/build
#compile bluetooth.ko
#modify /volume1/synology_dev/env_7.1/linux-4.4.180/net/bluetooth/Makefile from "obj-$(CONFIG_BT)   += bluetooth.o"(嵌入内核) to "obj-m   += bluetooth.o"(作为ko独立模块加载)
/volume1/synology_dev/env_7.1/./bin/make ARCH=x86_64 CROSS_COMPILE=/volume1/synology_dev/env_7.1/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu- -C /lib/modules/4.4.180+/build M=/volume1/synology_dev/env_7.1/linuxux-4.4.180/net/bluetooth modules
#DSM bc not found issue
cp /volume1/synology_dev/env_7.1/bin/bc /bin/bc
cp /volume1/synology_dev/env_7.1/usr/lib/libncursesw.so.5* /usr/lib/
cp /volume1/synology_dev/env_7.1/usr/lib/libreadline.so.6* /usr/lib/
#compile btusb.ko
#modify /volume1/synology_dev/env_7.1/linux-4.4.180/drivers/bluetooth/Makefile from "obj-$(CONFIG_BT_HCIBTUSB)  += btusb.o" to "obj-m  += btusb.o"
/volume1/synology_dev/env_7.1/./bin/make ARCH=x86_64 CROSS_COMPILE=/volume1/synology_dev/env_7.1/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu- -C /lib/modules/4.4.180+/build M=/volume1/synology_dev/env_7.1/linuxux-4.4.180/drivers/bluetooth modules
cp /volume1/synology_dev/env_7.1/linux-4.4.180/net/bluetooth/bluetooth.ko /lib/modules/
cp /volume1/synology_dev/env_7.1/linux-4.4.180/drivers/bluetooth/btusb.ko /lib/modules/
echo -e '#!/bin/sh\ncase $1 in\n start)\n insmod /lib/modules/bluetooth.ko > /dev/null 2>&1\n insmod /lib/modules/btusb.ko > /dev/null 2>&1\n ;;\n stop)\n exit 0\n ;;\n *)\n exit 1\n ;;\nesac' | sudo tee /usr/l/local/etc/rc.d/bluetooth-modules.sh
sudo chmod 755 /usr/local/etc/rc.d/bluetooth-modules.sh
sudo /usr/local/etc/rc.d/bluetooth-modules.sh start
#test mod installed
lsmod | grep bt
lsmod | grep bluetooth
#参考资料
https://community.home-assistant ... logy-dsm-7-1/549248
https://vircloud.net/exp/dsm-dri ... ion-443.137-443.228
发表于 2023-5-29 16:21:09 | 显示全部楼层
我用的群晖虚拟机VMM安装的homeassistant OS,USB蓝牙可以用
发表于 2023-5-29 16:48:52 | 显示全部楼层
虚拟机的话,usb蓝牙自动识别么
发表于 2023-5-29 22:59:30 | 显示全部楼层
具体怎么操作没看懂
发表于 2023-5-30 15:39:25 | 显示全部楼层
briansun92 发表于 2023-5-29 16:48
虚拟机的话,usb蓝牙自动识别么
群晖是可以识别的,但是在群晖系统里面没法用,
在VMM中分配给虚拟机,虚拟机就可以用了,很简单
发表于 2023-5-30 15:41:06 | 显示全部楼层
DSM 7.2可以吗?我升级了7.2
发表于 2023-5-30 18:57:29 | 显示全部楼层
在VMM中分配给虚拟机,虚拟机就可以用了,很简单 ...
我分配给虚拟机了,也还是找不到蓝牙设备。。。
 楼主| 发表于 2023-5-30 19:31:54 | 显示全部楼层
fenglou777 发表于 2023-5-30 15:41
DSM 7.2可以吗?我升级了7.2
原理一样的,下载对应的内核版本编译USB蓝牙驱动打上去就可以了
发表于 2023-5-31 15:42:49 | 显示全部楼层
发表于 2023-6-1 10:20:40 | 显示全部楼层
我是这样挂载的。虚拟机还是找不到
GMT+8, 2026-1-15 06:39 , Processed in 0.270302 second(s), 13 queries , MemCached On.
