查看: 9101|回复: 4
[求助] 調用HA 屬性一問
发表于 2017-12-18 13:19:48 | 显示全部楼层 |阅读模式
想調用HA中電視頻道, 觸發自動化.
但不懂寫配置, 求大神們 指教一下, 謝謝
- alias: Ch.81
  initial_state: true
  hide_entity: true
  trigger:
    - platform: state
      data_template: {{ states.media_player.sony_bravia_tv.attributes.source_list '翡翠台' }}
      to: 'on'
  action:
    - service: script.turn_on
      entity_id: script.tv2
发表于 2017-12-18 13:33:35 | 显示全部楼层
{{ states.media_player.sony_bravia_tv.attributes.source_list['翡翠台']}}
 楼主| 发表于 2017-12-18 13:48:09 | 显示全部楼层
謝謝ching回覆!!但HA報錯,求指教~~
2017-12-18 13:43:54 ERROR (Thread-2) [homeassistant.util.yaml] while parsing a flow mapping
  in "/home/homeassistant/.homeassistant/automation.yaml", line 168, column 23
expected ',' or '}', but got '['
  in "/home/homeassistant/.homeassistant/automation.yaml", line 168, column 82
2017-12-18 13:43:54 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a flow mapping
发表于 2017-12-18 14:58:34 | 显示全部楼层
2017-12-18 13:43:54 ERROR (Thread-2) [homeassistant.util.ya ...
你语法不对,建议弄一个template sensor,读取属性的值,然后根据template sensor的值的变化,来触发自动化。
 楼主| 发表于 2017-12-18 15:11:10 | 显示全部楼层
Jones 发表于 2017-12-18 14:58
你语法不对,建议弄一个template sensor,读取属性的值,然后根据template sensor的值的变化,来触发自动 ...
ching, 我只搜索到這個教學,可以提供一些配置學習一下?謝謝
https://bbs.hassbian.com/thread-839-1-1.html
GMT+8, 2025-12-25 13:55 , Processed in 0.068456 second(s), 6 queries , MemCached On.
