查看: 2367|回复: 2
[已解决] 请问在node-red怎样处理http request返回数据?
发表于 2023-5-29 01:08:10 | 显示全部楼层 |阅读模式
我的流程是这样的
http request执行后返回数值
{"Message":"","Data":[{"DeviceId":"826e7238c021424c9c74c890ab5c5446","DeviceStatus":"[0,0,1,0,0,0,42.000,32,8,0,0,0,32,0,17,31,0,0,80,38,0,0,0,0,32,18,0,16,12,1,0,0,0,0,0,0]","OnlineStatus":true}],"Code":200}
我想要获取 2.JPG 中第二个“0”,请问在“数据处理”里的代码怎么样写呢?
 楼主| 发表于 2023-5-29 02:21:31 | 显示全部楼层
let jsonData = msg.payload;
let deviceStatus = JSON.parse(jsonData.Data[0].DeviceStatus); // 将DeviceStatus从字符串转换为数组
let secondZero = deviceStatus[1]; // 获取数组中第二个元素的值
msg.payload = secondZero;
return msg;
自己解决,本来想一行解决,错误了,分开写就好写了
发表于 2023-5-29 14:42:48 | 显示全部楼层
response = '{"Message":"","Data":[{"DeviceId":"826e7238c021424c9c74c890ab5c5446","DeviceStatus":"[0,0,1,0,0,0,42.000,32,8,0,0,0,32,0,17,31,0,0,80,38,0,0,0,0,32,18,0,16,12,1,0,0,0,0,0,0]","OnlineStatus":true}],"Code":200}'
# 解析JSON数据
data = json.loads(response)
# 获取第一个设备的状态信息
device_status = data["Data"][0]["DeviceStatus"]
# 将状态信息转化为列表
status_list = json.loads(device_status)
# 获取第二个数值
second_value = status_list[1]
print(second_value)
GMT+8, 2025-12-16 21:13 , Processed in 1.048604 second(s), 7 queries , MemCached On.
