查看: 2643|回复: 1
[求助] 8266刷esphme接1306屏幕的问题
发表于 2023-5-20 20:44:29 | 显示全部楼层 |阅读模式
8266刷esphme接接ha测空气温湿度,想接个屏幕显示,屏幕只亮一小条  大神帮忙看看代码哪里有问题
esphome:
  friendly_name: ESPHome Web 5915f1
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
   ssid: "Esphome-Web-5915F1"
   password: ""
captive_portal:
i2c:
  sda: D2
  scl: D1
  setup_priority: -100
font:
  - file: 'slkscr-2.ttf'
  - file: 'slkscrb-3.ttf'
  - file: 'slkscre-4.ttf'
  - platform: dht
    pin: D6
    temperature:
      name: "Living Room Temperature"
    humidity:
      name: "Living Room Humidity"
    update_interval: 60s
    model: DHT11
  - platform: adc
    #unit_of_measurement: "%"
    #icon: "mdi:flower-outline"
    #accuracy_decimals: 0
    pin: A0
    filters:
      - lambda: |-
            return x;
    update_interval: 5s
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128X64"
    invert: false
    address: 0x3C
    #external_vcc: true
    offset_x: -10
    lambda: |-
      it.print(0, 0, id(font1), "H");
    update_interval: 1s
发表于 2023-5-21 09:43:50 | 显示全部楼层
把这个参数注释掉试试。offset_x: -10
GMT+8, 2025-12-17 14:05 , Processed in 0.701690 second(s), 9 queries , MemCached On.
