查看: 7010|回复: 4
[求助] 使用蓝牙播放TTS碰到的问题
发表于 2017-12-16 21:07:36 | 显示全部楼层 |阅读模式
使用插件ha-tts-bluetooth-speaker 配置好了蓝牙音箱,使用mplayer命令也能通过蓝牙音箱播放声音tts生成的MP3了,但是在ha中,却会报错
Dec 16 12:38:11 hassbian hass[1203]: 2017-12-16 12:38:11 INFO (Thread-9) [custom_components.media_player.tts_bluetooth_speaker] play_media: http://192.168.0.119:8123/api/tts_proxy/7d385d128cc4a59fa5ddb0211327c11b3f70f113_zh_-_baidu.mp3
Dec 16 12:38:11 hassbian hass[1203]: MPlayer 1.3.0 (Debian), built with gcc-6.2.1 (C) 2000-2016 MPlayer Team
Dec 16 12:38:11 hassbian hass[1203]: do_connect: could not connect to socket
Dec 16 12:38:11 hassbian hass[1203]: connect: No such file or directory
Dec 16 12:38:11 hassbian hass[1203]: Failed to open LIRC support. You will not be able to use your remote control.
Dec 16 12:38:11 hassbian hass[1203]: Terminal type `unknown' is not defined.
Dec 16 12:38:11 hassbian hass[1203]: Playing /home/homeassistant/.homeassistant/tts/7d385d128cc4a59fa5ddb0211327c11b3f70f113_zh_-_baidu.mp3.
Dec 16 12:38:11 hassbian hass[1203]: libavformat version 57.56.101 (external)
Dec 16 12:38:11 hassbian hass[1203]: Mismatching header version 57.56.100
Dec 16 12:38:11 hassbian hass[1203]: Audio only file format detected.
Dec 16 12:38:11 hassbian hass[1203]: Load subtitles in /home/homeassistant/.homeassistant/tts/
Dec 16 12:38:11 hassbian hass[1203]: ==========================================================================
Dec 16 12:38:11 hassbian hass[1203]: Opening audio decoder: [mpg123] MPEG 1.0/2.0/2.5 layers I, II, III
Dec 16 12:38:11 hassbian hass[1203]: AUDIO: 16000 Hz, 2 ch, s16le, 16.0 kbit/3.12% (ratio: 2000->64000)
Dec 16 12:38:11 hassbian hass[1203]: Selected audio codec: [mpg123] afm: mpg123 (MPEG 1.0/2.0/2.5 layers I, II, III)
Dec 16 12:38:11 hassbian hass[1203]: AO: [pulse] Init failed: No such entity
Dec 16 12:38:11 hassbian hass[1203]: Failed to initialize audio driver 'pulse::bluez_sink.96_13_5A_00_4E_1B.a2dp_sink'
Dec 16 12:38:11 hassbian hass[1203]: Could not open/initialize audio device -> no sound.
Dec 16 12:38:11 hassbian hass[1203]: Audio: no sound
Dec 16 12:38:11 hassbian hass[1203]: Video: no video
Dec 16 12:38:11 hassbian hass[1203]: Exiting... (End of file)
有高手能帮我看下吗
发表于 2017-12-16 22:29:39 | 显示全部楼层
https://bbs.hassbian.com/thread-1839-1-2.html 是这个帖子的吗?反正我是没成功。。。没声音。。。
 楼主| 发表于 2017-12-17 10:35:05 | 显示全部楼层
youzhu119 发表于 2017-12-16 22:29
https://bbs.hassbian.com/thread-1839-1-2.html 是这个帖子的吗?反正我是没成功。。。没声音。。。 ...
是啊,弄了一周 没成功
发表于 2017-12-18 10:54:52 | 显示全部楼层
萝卜大神也反馈给作者了。貌似是有问题,等着吧。。。。
发表于 2017-12-18 11:11:30 | 显示全部楼层
同样遇到问题。
GMT+8, 2025-12-25 13:55 , Processed in 0.297782 second(s), 7 queries , MemCached On.
